Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-02-2009, 11:28 AM   #1
JimiHendrix
CF Senior Member
Default Best Street/Strip Cam for LT1 383
Hi guys,
Im looking for an agressive street cam. Let me tell you a little about my build.
I have a 1996 Lt1 coupe. It has a completely forged bottom end, six inch rods, and SRP forged pistons. Compression will be 10.5 to 1 with a standard head gasket. Stall is 2400, with a beefed up tranny. I also have a 3:07 D-36 rear.
The heads........wwweeeellllll. . . . due to time and cost restrictions, I am reinstalling stockers which will have bowl work and a new valve job. I have the old heads out for porting (expected 260ish CFM at 550.), but wont have em back for at least a month and a half.
I am installing beehive springs (918's) now to handle any lift up to .600.
I need to install the cam to go with the later heads. I can handle any emissions issues. Also, I have shorty headers.
I was looking at the Gm847, the Comp XFI 280H , the Lunati 60122 and others. Any recommendations.
JimiHendrix is offline   Reply With Quote
Old 06-02-2009, 11:42 AM   #2
rickreeves1
CF Senior Member
rickreeves1's Avatar
Send a message via AIM to rickreeves1
Why not go with a custom cam. Tell them exactly what you are looking for. I chose LE. They have done tons of these setups and can get you exactly what you are looking for.
__________________
95-Lt1-auto-Polo-Conv, 125hp ZEX N2O dry, LE Cam 226/234 565/565 109LSA, Comp Pro Mag 1.6rr, Patriot Xtreme Springs, PCMFORLESS tune, K&N, AO Ram Air, 52mm TB, EM LT Headers, No Muffler, X-pipe, Meziere HD EWP, Vigil 2800 Conv, TransGo Shift Kit, Pro-Built 4L60E Trans., 24lb SVO's, MSD Coil & 8.5mm wires, NGK TR6 plugs, B&M TransCooler, Dewitt Radiator, 160 therm, TB AirFoil, 3.07 Rear Axle, LT4 KM, S&D Rotors, SS BrakeLines, Hawk HPS Pads, ZR1 rims 275/315. 1967-Firebird-conv-2spd-326ci
rickreeves1 is offline   Reply With Quote
Old 06-02-2009, 11:53 AM   #3
cuisinartvette
CF Senior Member
St. Jude Donor '05
Those cams are a little big for a 3.07 gear
cuisinartvette is offline   Reply With Quote
Old 06-02-2009, 12:05 PM   #4
JimiHendrix
CF Senior Member
Any recommendations then?
Also, what if I go up to a 3000 stall torque converter?
Old 06-02-2009, 02:18 PM   #5
92ZR1WANNABE
CF Senior Member
Support Corvetteforum!
Send a message via ICQ to 92ZR1WANNABE
Here is a link to some pretty good cam selection information for the LT1.
http://www.ls1lt1.com/forum/showthread.php?t=25032
It should be able to answer most of the questions you have.
**Edit**
Come to think if it you should read the last 8 words in my sig, something tells me your going to be in the same boat.
__________________
1992 - A4 - White w Black GS Stripe
ZR1 Rims - SLP Triple Claw Cold Air Intake - Cat Deletes - Corsa Catback - 3.07 Diff - MSD Opti - MSD Coil - MSD Wires - Performance 700R4 Rebuild - 2800 RPM Stall 9.5in PeteK Converter - TCI MAX Cool Trans Cooler - PCMForLess Tune
In Progress - 355 - Scat crank - Ported Heads - Ported Intake - 1.6 RR - CC503 Cam - 32Lb FIC injectors - blah blah ect ect
Best Et: 13.059 @ 103.41 MPH - 1.83 60'(Corrected for 2000Ft DA)
92ZR1WANNABE is offline   Reply With Quote
Old 06-02-2009, 02:39 PM   #6
96lt4c4
CF Senior Member
96lt4c4's Avatar
check my sig, car was capable of mid 11 seconds
__________________
1999 Hugger Orange SS (HOSS) 1 of 374 SS, 6 speed, T-Tops, Charcoal Leather.
96lt4c4 is offline   Reply With Quote
Old 06-02-2009, 03:00 PM   #7
biggrizzly
CF Senior Member
biggrizzly's Avatar
After you get your flow numbers back for the heads, talk to Lloyd or Brett Bauer and give them your car's specs and what you want and see what kind of cam those guys recomend. Simple as that.
__________________
Don Haller
President
Corvette Club of America
NCCC ER-001
http://www.corvetteclubofamerica.org
Chesapeake Beach, MD
Jackson Racing Engines 383 stroker, CompCam 224/230, .566/.577 113LSA , Ported LT1 heads, 2.05 Int 1.60 Ex, Pro Mag 1.6 Roller Rockers, Champ Road Racing Pan, 58mm TB, 30lb SVO Injectors, MSD Optispark, Exotic Muscle Long Tube Headers, Random Tech Cats, Magnaflow 3", 3000stall, 3.54 rear.
biggrizzly is offline   Reply With Quote
Reload this Page Best Street/Strip Cam for LT1 383
Tags
383, 467, 550, 60122, cam, comp, heads, horsepower, lift, lt1, lunati, peak, radiators, street, stroker
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C4 Technical Summary and FAQ - Please Read on a Regular Basis. bogus C4 Tech/Performance 82 09-15-2011 12:07 PM
Head Porting - How much flow is too much? Langadorf C4 Tech/Performance 12 08-21-2002 09:34 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
