1985 Crate Engines
Old 10-09-2012, 07:46 PM
mikeman902
Cruising
mikeman902's Avatar
Default 1985 Crate Engines
I have a 1985 corvette L98 and im looking for a new engine. Some thing ranging between 475 hp - 575 hp. any suggestions?
Old 10-09-2012, 07:50 PM
vetteoz
vetteoz's Avatar
Budget?
How much left over to upgrade the rest of your driveline to handle the increase in Hp from stock 245 HP? New trans/ diff .......
Crank or RWHP?
Old 10-09-2012, 08:04 PM
mikeman902
Cruising
mikeman902's Avatar
RWHP and probably nothing over $12,000. i finished the interior 2 week ago now just looking for a new engine to give it some more HP
Old 10-09-2012, 08:09 PM
vetteoz
vetteoz's Avatar
RWHP
I suspect you are looking at some kind of LSX conversion for those power levels
The old school SBC way
http://www.hotrod.com/techarticles/e...e/viewall.html
Old 10-09-2012, 08:47 PM
ch@0s
ch@0s's Avatar
That is sweet
They also have the Mowtown Ls block it allows you to run Ls heads and SBC stuff.. a SBC LS hybrid if you will.
http://www.worldcastings.com/product...ron-block.html
Old 10-09-2012, 08:52 PM
JrRifleCoach
JrRifleCoach's Avatar
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
I agree. The costs involved would be best spent with a LS conversion rather than messing with the old small block.
Higher reving, more tunablility and lots of parts.
Old 10-09-2012, 09:40 PM
cv67
cv67's Avatar
Received 3,043 Likes on 2,602 Posts
St. Jude Donor '05
I assume you are ditching the TPI
you keeping it injected or Carbd?
For a Gen 1 try Joe Sherman racing engines. Dynoed tuned etc.
tpi421vette here does a bang up job on strokers around here.
Old 10-09-2012, 09:54 PM
mikeman902
Cruising
mikeman902's Avatar
carbd
Old 10-09-2012, 10:11 PM
mcm95403
Support Corvetteforum!
mcm95403's Avatar
No replacement for displacement.
http://www.summitracing.com/search/D...Size/8-2L-502/
Old 10-09-2012, 10:52 PM
cv67
cv67's Avatar
St. Jude Donor '05
Check into GMPP crate LSx carbed series motors.
Some pretty nice stuff.
Old 10-09-2012, 11:15 PM
Caboboy
Caboboy's Avatar
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22
'23-'24
I don't see 500 RWHP and driveline upgrades happening under any circumstances with that budget. Maybe if you sourced your parts carefully and did everything yourself, but even then it would be tight.
It would be interesting to see the costs involved on some of our forum's LS swaps though.
Old 10-10-2012, 01:55 AM
coupeguy2001
coupeguy2001's Avatar
2021 C4 of the Year - Modified Finalist
In my opinion,
You wouldn't be able to put all that power to the ground.
Torque is what you want to build. Torque comes in earlier than HP anyway.
You would be best served doing suspension/tire/wheel mods, then building an engine for it.
Sit back and ask yourself what you want the car to do.
Why did you buy the thing in the first place? Great corner carver?
Do you want a drag car? a road racer? a car for long distance cruising?
Look at your neighborhood gas pump, read the price per gallon, and then rethink
what you want out of the car.
If you want a drag car, gas prices have no bearing. If that is the case, then no griping about the cost per gallon.
If you want a road racer, same thing.
But if you want to be comfortable in traffic, have air, go to your distant cousin's house occasionally, build it mild.
With a mild 383, I can hardly keep the tires from spinning as is.
I estimate my HP to be around 360-370 with torque around 420.
Use that as a yardstick.
Course my rear tires are a couple years old.
And I couldn't keep the tires on the ground when they were new.
I need to switch to 307 rear, as the power band is 1000 RPM above the cruising RPM of 1700-1800 at 75-80 mph.
Just shifting down really helps, but I need to be about 500 RPM closer to the power band entry RPM.
Old 10-10-2012, 05:02 AM
gerardvg
gerardvg's Avatar
Originally Posted by coupeguy2001
In my opinion,
Great advice
I have a supercharged 383 with only a mild camshaft and i have a lot of trouble putting the power down to the ground.
I have snapped the aluminum half shafts and have had steel ones made, the auto trans needs a lot of money spent on it and that wont guarantee it will have a normal life span. But it still has great fuel economy being supercharged and only a mild camshaft profile, you keep the low down torque and good manners easy start and smooth idle.
But it isn't cheap either way a blown engine or high revving screamer cost money to build, so think about how you want to use your vette.
Old 10-10-2012, 09:06 AM
ch@0s
ch@0s's Avatar
My swap cost me right at 5K using a low mileage pull out of a totaled Z28. I was able to sell all my old stuff for over 3K. That is just LS motor,trans, wiring,and PCM. It's running now but the converter went out and blew the trans.
Here is a break down:
Engine, Ecu and wiring $1300
Transmission and converter $1750
Racetronix 255 Fuel pump kit $120
Speehound motor mounts $100
Advanced Adapters 4L60E to 700R4 tail shaft adapter $214
A/C compressor high mount adapter $150
Corvette power steering pump,bracket and pulley $140
Corvettte alternator $100
Powerbond balancer $145
98 Corvette Batwing oil pan and C5 manifolds $50
Oil pan gasket $50
Starter from fleabay $56
Balancer bolt $14 gm
Hoses, and fuse block $80.00
TB cable $50
Tuning $100
Two O2 sensors $120
wirring and terminals $60
Transmission cooler and lines $220
Fuel lines and fittings $70
Radom Tech Cat cons $200
Dual spring kit $300
I might need to get a couple of Dakota Digital boxes
A/C lines and Compressor
Spent $5389.00 and some of this stuff is optional.. for example you dont have to spend $550 on a converter
So far I have made $2945 to offset the cost from sales of my old stuff. I still have a few parts lying around.
Old 10-10-2012, 12:07 PM
btr85vette
btr85vette's Avatar
I love my '85, but you can get a C5 for $12K...
Old 10-10-2012, 12:31 PM
ch@0s
ch@0s's Avatar
With that mentality all old corvettes would be in the graveyard.
For some of us newer is not better. I like the C5s but I like my C4.
Old 10-10-2012, 08:41 PM
mikeman902
Cruising
mikeman902's Avatar
i have track tire on it now so im thinking they wont spin with more hp you just have to control it but it gonna be a track car so it wont be much of a big deal unless i deciede to go to the strip for the day
To 1985 Crate Engines
Old 10-10-2012, 09:19 PM
rodj
rodj's Avatar
Good luck
Your going from maybe 200 RWHP to the 500HP you say you want and expect traction?
I can easily spin my MT Drag radials ( a soft and sticky compound ) with 400RWHP on a coarse road surface with little throttle
If you have to baby the car to 60 mph before you can put your foot down little point in having all that power available ( unless you are going to Bonneville)
Old 10-11-2012, 10:37 PM
Caboboy
Caboboy's Avatar
'23-'24
Oil pan gasket $50
TB cable $50
Tuning $100
Two O2 sensors $120
That is amazing, congrats on not only your motor, but your cash management as well!
Old 10-11-2012, 11:10 PM
leesvet
leesvet's Avatar
Good luck with dat !
I spent $10,000 around 12 yrs ago...and barely got to 400. That was quite a while back. Now, that same end result will cost 15-$20,000.
Trust me, these guys here are trying to keep your expectations realistic.
HP does not come as easily as the aftermarket bolt-on stuff claims.
REAL hp cost BIG money. Then, you will spend that much again on drive-train.
Better get comfy with 350...........and just lie to your friends !
Quick Reply: 1985 Crate Engines
