Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-06-2009, 12:36 AM   #1
Stingraynut
CF Senior Member
Stingraynut's Avatar
Default weatherstripping - glue or not glue?
I've read a lot of forum posts over the years about glueing on the weatherstripping, but when I spoke to a spraypainter today he asked me why I'd want to glue it on - it made me think.
Perhaps not all the bits of weatherstrip need glueing?
I had planned to glue it all, to help guarantee against leaks, but when I thought about it, one side of the strip isn't glued, so why should the other?
The painter suggested that if it needed to be glued in certain areas, to use dabs of superglue to hold it in place.
What do other members think?
Stingraynut is offline   Reply With Quote
Old 05-06-2009, 12:41 AM   #2
Binski
CF Senior Member
Binski's Avatar
I have been using regular 3M black glue made for weatherstrip. I would rather take this extra step, spend a few bucks more and be sure I don't have to redo. This has worked well for me.
Binski is offline   Reply With Quote
Old 05-06-2009, 01:12 AM   #3
grinditout
CF Senior Member
It needs to be glued to be water tight, get all body work out of the way; then glue it down with 3M weatherstrip adhesive.
grinditout is offline   Reply With Quote
Old 05-06-2009, 01:16 AM   #4
96GS#007
96GS#007's Avatar
Depends on what piece of weatherstripping. Some pieces need to be glued, others do not.
__________________
Jim
'96 Grand Sport #007
A few mods here and there
96GS#007 is offline   Reply With Quote
Old 05-06-2009, 01:18 AM   #5
slickfx3
CF Senior Member
slickfx3's Avatar
Quote:
My Hatch strip peeled off and I cleaned under it, I doesn't need glue on the bottom what else?
slickfx3 is offline   Reply With Quote
Old 05-06-2009, 03:57 AM   #6
Stingraynut
CF Senior Member
96GS - aha, thats what I was wondering - which bits DO need glue and which don't?
grinditout - I sort of agree with you, but the weather-stripping is not glued to both sides, otherwise we couldn't open the door etc - so it makes me wonder if one side is waterproff without glue, why not both?
Old 05-06-2009, 06:14 AM   #7
65Z01
CF Senior Member
Cruise-In II Veteran
65Z01's Avatar
Send a message via AIM to 65Z01
If you mean the strip that runs around the hatch opening and against which the hatch glass seals, my OEM WS had a yellow slipery substance under it so I used lithium grease when installing the new WS.
For one thing the adhesive keeps the WS in position and prevents it from "moving around" when a moving part contacts it. Plus the OEM WS was frimly glued down and that's good enough for me.
65Z01 is online now   Reply With Quote
Old 05-06-2009, 07:35 AM   #8
pianoguy
CF Senior Member
pianoguy's Avatar
I replaced my A and B pillar weatherstripping and didn't glue it - no problems so far.
pianoguy is offline   Reply With Quote
Old 05-06-2009, 08:12 AM   #9
PAINTER MAN
CF Senior Member
Send a message via ICQ to PAINTER MAN Send a message via AIM to PAINTER MAN
Quote:
I agree. I replace these two areas on my car 6 years ago. No glue and no leaks. I did clean the channel very well.
PAINTER MAN is offline   Reply With Quote
Old 05-06-2009, 09:39 AM   #10
pianoguy
CF Senior Member
pianoguy's Avatar
Quote:
Ditto - I took a lot of time getting the channels clean. The new stuff fits in there quite snugly.
Old 05-06-2009, 11:18 AM   #11
Steve59
CF Senior Member
Steve59's Avatar
I just did the hatch ws on my 87 coupe. When I removed the old ws, there was very little glue and that was only in the corners. I used a Wilcox replacement ws. I had not centered it correctly under the third eye and had to remove it and re-install it. That's when I realized that there is grease of some type inside that ws to help seal it. I assume that that grease would also prevent any glue from sealing that area.
Steve59 is offline   Reply With Quote
Old 05-06-2009, 11:55 AM   #12
PLRX
C4 Bomber Run Coordinator
St. Jude Donor '09-'10-'11-'12
Support Corvetteforum!
PLRX's Avatar
Few members did not use glue and they are satisfied with their work. I have the entire kit for my CE LT4 and I will not use glue.
PLRX is offline   Reply With Quote
Old 05-06-2009, 03:42 PM   #13
skybolt31
CF Senior Member
skybolt31's Avatar
On my 86, I did the A pillar without glue and am going to do the 95 A&B pillars and have no intention of using glue. Lots of people glue and have no issues and lots of people don't glue and have no issues. In all of the WS posts that I have read, I have never seen one where someone says that they didn't glue and it leaked, they went back and glued and it fixed it. So the choice is yours, but gluing is not necessary, at leas on the A&B pillars.
skybolt31 is offline   Reply With Quote
Old 05-06-2009, 07:36 PM   #14
Stingraynut
CF Senior Member
Wow, some interesting replies here.
Until yesterday I had not considered the idea of not glueing, now I am.
Old 05-10-2009, 08:15 PM   #15
Stingraynut
CF Senior Member
OK I am going to follow the advice of the paintshop and not glue except for any obvious corners.
The guy at the paintshop also says he uses supa glue to hold the W/S in places where it won't stay - sounds like a good idea. he says then if the W/s need removing it's easier, and I have read posts where the W/S has not been put on right and needed to be moved.
I live in the tropics and during the wet season (Jan-April) we can get up to 4" of rain an HOUR!! That will be a good test. I'll post back with the results .
Old 05-10-2009, 11:23 PM   #16
tim32920
CF Senior Member
tim32920's Avatar
Send a message via Yahoo to tim32920
I redone all the weatherstripping on my 92 and I only put 3m glue on it and only on the corners and NONE of it leaks.I read through alot of posts on here before I started and I suggest you do the same,it will help you alot.
tim32920 is offline   Reply With Quote
Old 05-11-2009, 12:28 AM   #17
PLRX
PLRX's Avatar
No Glue
Old 05-11-2009, 09:28 AM   #18
PGLT1
CF Member
PGLT1's Avatar
I did my hatch WS last fall. I left it in the rain with a paper towel in the corners to check. Bone dry after two days!! So my take is no glue unless needed.
PGLT1 is offline   Reply With Quote
Old 05-11-2009, 10:10 AM   #19
pitchadude
CF Senior Member
pitchadude's Avatar
What about car shows? How will it effect judging?
pitchadude is offline   Reply With Quote
Old 05-11-2009, 10:19 AM   #20
flynn508
CF Senior Member
flynn508's Avatar
I will soon be redoing all my weatherstrip on my 86. I figured that the pressure of the doors, glass, etc. on the strip when its closed up would keep things dry. I also assume that the strip needs some 'breathing room' to expand and contract in the heat/cold and if it was glued in wouldn't that cause it to split or break?
__________________
"There is no limit to what a man can do if he doesn't care who gets the credit."-Ronald Wilson Reagan
flynn508 is offline   Reply With Quote
Reload this Page weatherstripping - glue or not glue?
Tags
1997, 2003, b, c5, corvette, hatch, infocom, oem, pillar, replace, stripping, weather, weatherstrip, weatherstripping, wwwc3
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C5 Weatherstripping...Take 2 cjlaw73 C5 General 13 12-23-2004 10:16 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
