Short vid of startup
Complete rebuild, boiled the block, new bearings, new freeze plugs, clearanced the block for the rods, hone, new 4340 forged crank, new 4340 H beams, new cam 293/300 @.006, new SFI balancer/damper, ported the HSR top side, new Kevco model 1074, 7" deep oil pan, converted back to the stock 85 clutch, BH and hydraulics.
Fired right up, idle is currently set at 1000/1100rpm, gonna do a short ring break in tonight and then drain the oil and wash the car.
Ready for a couple of legs of the Hot Rod Power Tour!
So, that's what woke me up last night...
Sounds great, Larry. Very responsive to the throttle.
Thanks guys! I took it slow on this one, and it turned out really well so far, can wait to get that spring ride SOTP wake up!
Hey Johnny, can you drive over to teh Dayton Ohio HOt Rod Power
tour for a day in June?
Wednesday, June 10
Dayton, OH
University of Dayton Arena
Wednesday, June 10
Dayton, OH
Thanks guys
I just seated the rings, did an oil change and checked the timing, it was waaay advanced and now it is set to 6 degrees,,, and has a little more lope.......
