Cloyes double roller 9-3145
Does onyone have an idea whats going on with this? I am haveing a problem with the bolts in the cam gear being to small. The cam gear fits sloppy. No way to center the cam gear on the cam. Is there something I am missing?
Does your cam gear have the recess in the back to fit the groove on the cam?
Once it is seated , there is no slack.
Possibly wrong gear in box ?
No issues with block clearance or cover clearance? Like Ultraviolet70 had with his Cloyes dbl roller 1145?
See this thread.
See this thread.
Because I had one on the shelf I just tried it on the cam outside of the engine to sort his problem out.
Sometimes parts get swapped at the parts shop and you don't end up with what you should have.
The cloyes was a PITA to fit. You will have to clearance a bunch of metal from the timing cover. I was able to get it to clear though. The cam retainer bolts are also very close. I just went through this a couple of months ago on my 95.
Thanks guy's! I got. I feel like a fool. I didn't think of the recess in back of it.
I also had to clearance the cover but it was behind the cam gear not the crank gear.
Now, on to other problems with the windage tray.
Rick, maybe your crank gear wasn't fully seated when you were doing the test fit, or you didn't have the timing cover gasket in place? I have never seen that much material taken out to clearance for the Cloyes double roller.
