LTCC , Come inside....
Bob Bailey is a mad scientist..
Katech coil re-location brackets, although it seems I ended up with
LS1/LS6 brackets, but we will see what Katech will do to help out.
Yeah, I held off until I could find the appropriate brackets for the coils, it seems that Katech just started making this style.
Also this is about to be a sprayed and boosted setup.
Premium Supporting Vendor
KAT-A4667 is for LS2/LS3/LS7/"LS2 truck" coils
KAT-A4669 is for round truck coils
The type of coil is laser etched into the bracket. Verify that you have the correct bracket.
Passenger side has a hose from the throttle body for emissions, pop it out and use a tranny funnel. Better pictures are coming.
Those valve covers are not buy and bolt on, I have a lot of work in them, but little money.
Dynaspark for the optical eye.
I would be embarrassed if it was all priced out, I have been piecing this together for a year and a half.
And there is a lot of wrench time and fab time in it.
More pictures>>
CLOYES 9-3145
SLIGHT CONTACT BY THE CAM GEAR, NO GASKET INSTALLED AT THE TIME.
NO CONTACT BY THE CRANK GEAR OR CHAIN. CLOYES TRUE ROLLER.
TPIS 58mm
95 CAMARO Z28 THROTTLE CABLE, ASR DELETED, STILL HUNTING CC CABLE>>>MORE TO COME.
CLOYES 9-3145
TPIS 58mm
It was worth every dime.
Runs twice as good as it did before the tear down.
Now to hunt down a dyno tuner in GA.
