c4 oil change
c4 oil change
I have an 88 corvette with 35000 miles on it and I drive it about 5 miles a day at most. The last time i changed the oil was about 2 years ago (probaly 1000-2000 miles MAXIMUM) with mobil 1. Is this acceptable? Or should i change it more often?
yes i am planning on changing it within the next week, however, I would like to know if i still should change it every 6 months as is reccommended?
Received 2,485 Likes
St. Jude Donor '15
"In honor of jpee"
as to every six months, may not be necessary but it won't hurt anything.
Slingshot
Om a further note, you really need to enjoy that thing more. An '88 or any C4 for that matter is never really going acheive a "collector" status. So there really is no reason not to drive it. On top of that, inactivity will cause soft things like gaskets and bushing to dry rot.
Received 4,505 Likes
U.S. Air Force
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
You really need to change it more often. I would do it at least twice a year for your driving habits. Mainly because if your only driving 5 miles a day, your heating up the engine but the oil is not getting hot enough to burn off the condensation, so the water will cause the oil to sludge. Eventually this create an early demise of your engine.
Om a further note, you really need to enjoy that thing more. An '88 or any C4 for that matter is never really going achieve a "collector" status. So there really is no reason not to drive it. On top of that, inactivity will cause soft things like gaskets and bushing to dry rot.
oil change
"You really need to change it more often. I would do it at least twice a year for your driving habits. Mainly because if your only driving 5 miles a day, your heating up the engine but the oil is not getting hot enough to burn off the condensation, so the water will cause the oil to sludge. Eventually this create an early demise of your engine."
Contrary to the old belief that it's a mint car because "it was just driven to church on Sundays by an old lady" is dead wrong. That's the worse kind of treatment you can give a car. If the oil is not taken to full operating temperature for a spell the oil gets diluted with contaminants, is less lubricating and therefore should be changed more often not less.
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
My opinion: Drive your Vette or sell it
St. Jude Donor '10-'11
