Aftermarket gauge company!!
Came across this link in car craft mag, http://vettaid.com/
I think it looks pretty dam good.
I havent looked into pricing or anything but i think this may be exactly what some of you are looking for.
and no, i dont work for the company
Definitely looks interesting, but there are some key things that appear to be missing such as any sort of digital anything to display average MPG or Range functions. It would be good to do a compare and contrast between this setup vs the Dakota Digital setup that was made for our cars.
Ron
Ron
Pretty pizz poor marketing on their part.
Have yet to see a single advert from them in any vette mag or forum, just that ad in CarCraft.
Considering the huge lead time in magazine advertising you would think they would have had scads of time to get the word out on the internet.
Then look at their webiste...
Virtuall no information on the unit.
One artsy craftsy angle pic of the cluster.
No details on anything.
And best of all, no pricing.
Bozo bin for them...
It says six different options, I'd bet one is a speedo that goes higher. Anyone email them for cost? I'd be curious.
hahah great I just made my analog gauge pod with the same gauges (Autometer sport comp) lol. I would have seriously considered these guys if I knew about them a couple months ago.
keep your GM car all GM
88 firebird gauges in reworked bird housing...hi/lo selector switch for 150 mph max in lo range, 300 mph max in hi range...no sensor changes...plugs into vette dash harness with no wire cutting, returns to oem atari dash in 45 min.
apologies for reflections on the new lexan faceplate, as it ages and gets a few scratches that will stop.
Tell us more. Looks better than the Vetteaid cluster.
the vette dash harness has a connector that plugs into the vette digidash...bird gauges must be wired to a matching connector that can be ripped from many late 80's ecms...bird clusters come with a flexible snap-on plastic printed circuit that actually idents the gauge connections, bird gauges are mounted to the cluster rear housing by screws that also are the elec conns...modded bird cluster uses 'spaghetti' (wires) vs oem printed cuircuit.
the oem bird cluster assy is wider than the vette digidash space...i chopped the bird rear housing and rearranged the gauges to fit the oem vette space as i did not want to chop the vette center console/air outlets to fit a whole bird cluster...another forum member, vinny's87, made his own housing/faceplate/lens...''chopped'' rear housing vs oem:
oem bird 'bezel' (front of cluster) might be re-used, but i chose to have a machine shop cut holes in a 1/8" alum plate and made a new front 'lens plate' from 'homie depot' .090 lexan.
bird gauges will work with 84-89 vette sensors, don't even need to open the hood.
v-6 bird gauge tach will read 1/3 fast when used in vette (i.e. 6k rpm will read 8k), v-8 cluster tach reads right on, gauge clusters have an external paper tag sez 6 or 8 cylinder, tach face has hidden 6 or 8 cyl perm label... 'elec' bird speedos come in several 'max' mph scales and all are good, can add 'hi-lo' select switch to double up (i.e. 80 mph x 2 = 160, 120 mph x2 = 240, new 'hi' mph 'numbers' should be added)
Click the link below. This one is all good to go.
http://forums.corvetteforum.com/c4-p...digi-dash.html
