1995 Coolant Leak Right Side of Block
Hi All,
I have a major coolant leak out of the right side of the block. It looks like it is coming from above the starter. Any thoughts? It's not the knock sensor, that's easy to see. I can see another sensor around the exhaust manifold between the back two cylinders.
Thanks,
Larry
Thanks,
Larry
There is a "cross over" tube between the heads back there, try to determine if it's leaking at the fitting on the back of the head, otherwise, thats right where my head gasket blew (alot of coolant came out too). Check out the oil too, to make sure you don't have coolant circulating in it.
Thanks,
Larry
Pulled the starter out and the freeze plug hit me in the head. That's why I was draining all of the fluid. Trying to figure out the best way to get it back in now.
BTW - GM puts the starter bolts in the best location. Just kidding...
-Larry
-Larry
