Lowering Front: Sanding Bushings
Hi!
Awhile ago I posted a question on lowering the front end on my '89, and several of you mentioned that you had simply sanded the front spring cushion/bushing down, rather than using one of those replacement wedge kits that you see for sale by all the catalog companies. This sounds like the way to go, and I am wondering if those of you who did this could give me some guidelines on how much to sand/leave (I was thinking of using one of the replacement wedges as some sort of guide, although it's made out of polyuerethane instead of rubber, which might compress more), and whether you had any suggestions/pointers or things to be careful of etc., or any subsequent problems. I am only looking to lower the front by about 3/4s to 1 inch.
Many thanks!
/s/ Chris Kennedy
Many thanks!
/s/ Chris Kennedy
Thanks,
/s/ Chris
