Vette Tech Tri-Y header update
Last winter I installed my headers along with 1.6 RR W/springs.Rather than go to a Dyno I thought it would be fun the go to the track.It was the first time at the track for me so I did'nt do so good but the vette did.I made three runs my best time was 13.394 weight 3350 =276 HP.I'm thinking 36 hp gain,20 for headers 16 for RR??? Sorry for the wrong data in the original thread I see the errors,to many sleepless nights.
I installed the same headers this past Christmas, and the one thing I am happy with is the sound. Can't really comment on power, as it took a while to get everything clearanced so I could push it.
However, looking back I would NOT do it again. The fitment issues I had are completely inexcusable for a production exhaust header. I just hope it all becomes worth it once I put it on a dyno...
Yes, your real time is 13.394. You don't subtract the R/T. What was your MPH?
Thanks for sharing. It's nice to know everyone is happy with their results after all the fist pounding is done. (That's why I decided to keep mine + I'm convinced the Tri-Y design is a good one. Just not sure if Dassani's aren't a better way to go!
BTW: Did you install or have them installed? How much of a PITA were they for you?
I installed them,after the "fix" there was a clearance issue w/number 8 tube.Beside that they went in easy.I followed the long saga in the forum and was pre warned,kinda like having instaltion instructions. THANKS TO ALL
Most everything is documented in 2 threads about them. The main problem areas:
-#8 tube hits the evaporator housing. Has to be flattened pretty substantially to clear and provide some heat buffer.
-#2 tube gets REALLY close to the upper control arm. For stock camber settings it's ok, but has to be banged in to dial in more than about 0.5* negative camber, depending on the car.
-The passenger collector hits the heat shield on the passenger foot well. I solved this by just removing the heat shield and putting some aluminum tape on the footwell.
Other things I had to do:
-#3 tube bent forward immediately from the head, not giving enough room to stick a bolt in the hole. So, I had to flatten the tube where it attaches to the head.
-I hooked it up to a Corsa exhaust, with cats. Basically, the shop I had attach the two had to cut the Corsa off just in front of the H-pipe and put the 2 cats at a pretty extreme angle connecting the headers to the Corsa. It can't be good for performance, but without eliminating the H-pipe from the Corsa, it's the only way to have cats.
Never bought a set of headers that did anything that did not need some minor banging.
We don't get a lot of choices in performance headers, this is most likely the reason. Tough fit.
TJM
TJM
