Is anybody here running a trans. cooler ?
B&M 70264
Pretty good !
You can attach it in front of the radiator with plastic ziplocks and it has some brackets,nuts and bolts too,but its pretty safe where i installed it.
Pretty good !
I put one in the location of the front booster fan.
- No i don't have but i can take for you when i get to the car this week
- I haven't got the time to solve the idle problem,im waiting for a new coil,module,and dist cap,i will finish some works this days and when i get free time i will play around the vette with this new items hehehe thanks for asking !
I am running one with a fan and thermostat and mounted it where the spare tire use to be. Here is some pics when I first installed it. I am having a tubular mount being made up to replace the mount that is holding it up right now. I have had 0 problems with it I just wanted it to look a lttle neater.
B&M 70266
I bypassed the radiator passage and went straight into the cooler only. Trans temps may be running too low now for certain climates.
http://www.bmracing.com/PRODUCTS/Uni...BTU-11x8x1-1-2
I'm using the B&M Super Cooler in series wih the stock cooler in a new radiator. The install looks just like Rickreeves1. My trans temp stays around 160 in normal driving. I have seen it at 180 in some spirited driving.
But you don't have to use the stock cooler. You can just bypass it. The B&M kit comes with all the hardware to use the stock cooler if you want to.
