Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-26-2009, 05:50 PM   #1
KBRVETTE93
CF Senior Member
KBRVETTE93's Avatar
Default MAF Screen
Has anyone removed the screen in the MAF. Any performance gain?
Ditto for throttlebody bypass? Any real gain?
KBRVETTE93 is offline   Reply With Quote
Old 03-26-2009, 08:31 PM   #2
floridamale
CF Senior Member
floridamale's Avatar
I kind of looked at these as feel good mods no real seat of pants gains. But the by-pass cleans up the front area.
floridamale is offline   Reply With Quote
Old 03-26-2009, 08:35 PM   #3
Qiken
CF Senior Member
Qiken's Avatar
From memory the Corvette challenge guys used to remove them,added a few more cfm flow.
Qiken is offline   Reply With Quote
Old 03-26-2009, 09:17 PM   #4
steven mack
CF Senior Member
steven mack's Avatar
I've heard different stories.One is the screens are there to straiten out the airflow past the wire sensor to get a more accurate flow reading.The other is to keep debris away from wires inside.I'd leave them in.The mafs an expensive piece.
steven mack is offline   Reply With Quote
Old 03-26-2009, 11:10 PM   #5
LT4BUD
CF Senior Member
LT4BUD's Avatar
Done both....small gains from each, but every little bit adds up..
LT4BUD is offline   Reply With Quote
Old 03-27-2009, 08:04 AM   #6
pcolt94
CF Senior Member
pcolt94's Avatar
Quote:
I believe this is the correct technical answer. The screens are used to have an uniform air flow past the resistors (wires). The computer (ECM/PCM) is expecting certain data based on the specifications of the MAF in computing A/F mixture.
I won't disagree about increased air flow. You have to decide if the gain is worth it to you. All I have read about mods falling into two categories of what works (worth it) and what doesn’t, that mod fell into the does not part of the list.
pcolt94 is offline   Reply With Quote
Old 03-27-2009, 09:18 AM   #7
Iroc57
CF Senior Member
Iroc57's Avatar
Quote:
There is no such thing as a free lunch. You can do all of the "free" mods found on the forum and in the end only have a few hours of your life missing.
Just my $.02
Iroc57 is offline   Reply With Quote
Old 03-27-2009, 09:37 AM   #8
floridamale
CF Senior Member
You might throw the cut air box lid into this category as well.
The only what I would call free mods if you can do your own work that is, would be some porting of your intake system plenum, runners, base manifold. HP & torque gains are not great but it dose seem to move the gains into the mid range of your RPM band. With out head & exhaust work not sure that is worth it either. But if it makes you feel good do it.
Old 03-27-2009, 09:38 AM   #9
SuperL98
CF Senior Member
SuperL98's Avatar
Recently, I was playing with a Flow Illustrator and decided to do a rough model of a MAF with & without screens.
Interesting to see, and probably what you would expect
http://www.youtube.com/watch?v=0_-7ggnURSc
http://www.youtube.com/watch?v=R1y0O-3RNVg
SuperL98 is offline   Reply With Quote
Old 03-27-2009, 09:46 AM   #10
floridamale
CF Senior Member
Interesting, did you do one including the rear screen as well.
Old 03-27-2009, 01:51 PM   #11
steven mack
CF Senior Member
My experience with removing the screens from my 85 was a decrease in the stability of my idle.
Old 03-27-2009, 01:56 PM   #12
BrianCunningham
CF Senior Member
BrianCunningham's Avatar
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
I pulled mine when I dynoed it
2hp ~<1%
BrianCunningham is offline   Reply With Quote
Old 03-27-2009, 02:01 PM   #13
Demonic85
CF Senior Member
Demonic85's Avatar
I removed mine with no change whatsoever. I did have to replace the MAF a few months later though, hmmm.
Demonic85 is offline   Reply With Quote
Old 03-27-2009, 02:49 PM   #14
WW7
CF Senior Member
WW7's Avatar
If the MAF didn't need the screens, would GM spend the money putting them on???
WW7 is offline   Reply With Quote
Old 03-27-2009, 03:28 PM   #15
BrianCunningham
CF Senior Member
Quote:
Because the other cars it's mounted on aren't a straight shot, there's an elbow, it's used to straighten the flow.
__________________
Polo Green 95 LT1 6-spd
383 LT1/Vortech Supercharger/AFR heads/Rod end suspension/Penske-Hardbar dual rate coilovers/Wilwood 6pot brakes
NCCC Governor/Membership/WebMaster: www.baystatecorvetteclub.com
Old 03-27-2009, 03:42 PM   #16
floridamale
CF Senior Member
Seeing as I believe it was a Boch design I doubt GM did much engineering on that part.
But I do like the explanation of "Because the other cars it's mounted on aren't a straight shot, there's an elbow, it's used to straighten the flow."
I think also they did it to keep things out of the MAF and destroying the wires.
Old 03-27-2009, 03:53 PM   #17
Aardwolf
CF Senior Member
Aardwolf's Avatar
The wire is pretty strong, and the air filter stops debris. Without an air filter something large enough to damage could get in there but otherwise, no way.
The MAF flows something like 200 CFM more without the screens. They've been out of my car for years, and the TB coolant bypassed as well.
Aardwolf is offline   Reply With Quote
Old 03-27-2009, 04:51 PM   #18
floridamale
CF Senior Member
I have mine out also along with the by pass & cut lid, but I do think GM has to build cars for idiots. We all know the guys who just say why do I need a air box or cleaner or one that has been in there for 100k miles.
Old 03-27-2009, 07:13 PM   #19
SuperL98
CF Senior Member
SuperL98's Avatar
I have a little spread sheet I use to calculate and size exhaust systems.
But it's good for looking at the intake also.
The MAF sensor and code will only read up to 254 grams/sec.
That works out to about 451 CFM and 313 FWHP.
After that the MAF is out of the picture, and you have to tune with the WOT tables.
In the old TPIS "Insider Hints" book, they tested the stock MAF @ 529 CFM, Screens Out @ 711 CFM, and Fully Ported @ 750 CFM.
So I get roughly,
Fully stock 529 CFM would support 367 FWHP
Screen Removed 711 CFM would support 494 FWHP
Fully Ported & Screens Removed would support 520 FWHP
So your FWHP in relation to those numbers, would determine if removing the screens would help or be a waste of time.
I have both a completely stock (I use for emission testing) and a fully ported & no screens MAF.
I have an old school Paxton SC, and around 450 FWHP.
The fully modified MAF runs a little over 1-1/2 mph faster, in the quarter mile, than the stock one.
But even with heavily modified MAF tables, my engine does hunt at idle, and part throttle response isn't as good
Old 03-27-2009, 07:23 PM   #20
SuperL98
CF Senior Member
SuperL98's Avatar
I just realized, some of us are talking L98's and some Lt1's.
My comments only apply to the old L98 MAF's.
Reload this Page MAF Screen
Tags
c4, corvette, maf, modified, screen, worth
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
MAF Screen Removal ICUALL C5 Tech 72 11-23-2010 07:28 PM
MAF screen removal on L98- yea or nay - I will go with the majority dbwade36 C4 Tech/Performance 30 10-10-2003 10:46 AM
Bone stock times 01 A4 then with removed MAF Screen BAD 97 WS-6 C5 Tech 20 05-08-2003 02:28 PM
MAF screen removal Resqjoc C5 Tech 28 02-18-2003 09:28 AM
N2O- Fire out of hood, Blew up air duct, Fried Donaldson, Shredded MAF screen JMon C5 Tech 39 10-08-2002 05:03 PM
Car is surging now after removing my MAF screen. SR1654 C5 Tech 31 07-20-2002 10:45 AM
MAF Screen removal Dyno results Charley Hoyt C5 Tech 23 07-19-2002 11:56 PM
Took out MAF screen! IMQUIK C5 Tech 111 07-11-2002 06:41 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
