'94 Vette Through Some Codes (HELP!!!)
Old 03-26-2011, 06:13 PM
94lt1vette94
94lt1vette94's Avatar
Default '94 Vette Threw Some Codes (HELP!!!)
Hey guys,
My vette recently died while running. Before dying, the rpm's took a dive. I threw the following codes:
H36- Distributor Ignition System High Pulse.
H41- Ignition Control Circuit Open.
H62- Engine Oil Temperature Sensor Circuit Voltage Low.
The car starts and idles fine for about 3mins, and then I start running into problems. What do I need to buy to fix this? And what could be the culprit? My plug wires are fine.
UPDATE: I finished the opti/water pump install. The vette is running flawlessly now. Thanks Chandler Motorsports for a quality piece at an affordable price and thank you O' Rilley's for a quality water pump!
Old 03-26-2011, 06:22 PM
STL94LT1
STL94LT1's Avatar
Opti.
Old 03-26-2011, 06:24 PM
94lt1vette94
Are you positive? I'm thinking it may be the ignition control module or whatever that thing is
Old 03-26-2011, 06:40 PM
STL94LT1
STL94LT1's Avatar
Normally a bad ICM will throw a 42 code. Pull the opti wire harness and look for corrosion. But, it does sound like a dying/dead opti to me.
Old 03-26-2011, 07:00 PM
94lt1vette94
I have 63k miles on the car, so I guess I do need to replace the opti...recommendations for an opti?
Old 03-26-2011, 10:14 PM
pcolt94
pcolt94's Avatar
Definitely has the symptoms of a possible bad opti. A H36 ( loss of high pulse) should not kill the engine. If a code 16 came up and a loss of the low pulse occurred, I could see the engine dying due to it is required pulse.
I would at least clear the codes and see if any codes return. The opti could be bad with having no codes at all. But usually (not always) cause poor running with bucking under acceleration and poor idling.
But aside from checking connectors and pins as indicated already, there is a possibility the ICM could be a bad because the engine is dying.
Old 03-27-2011, 02:25 AM
94lt1vette94
Which should I start with, the ICM or the Opti? I'd assume the ICM since it's cheaper?
And to all wondering how I "through" a code, I meant "threw" lol
Old 03-27-2011, 08:02 AM
TWISTERUP
TWISTERUP's Avatar
Code 36 is the opti or opti circuit to the PCM-- as stated above check the harness connection at the opti and above the right valve cover for corrosion etc.---however I suspect a opti replacement is in your future.
Old 03-27-2011, 05:21 PM
94lt1vette94
And if in fact it's the harness that's bad, where can I buy a replacement from?
Old 03-27-2011, 05:25 PM
STL94LT1
STL94LT1's Avatar
Default Opti wire harness
http://www.eficonnection.com/eficonn...spx?ItemId=864
Old 03-27-2011, 09:10 PM
ChrisLT1conv
ChrisLT1conv's Avatar
My guess is opti. You can get a new opti with cap as a sealed unit from advance for about 270$. it is new not remanufactured and it has a lifetime warranty.
Old 03-28-2011, 09:16 AM
94lt1vette94
So you wouldn't recommend going with the Autozone one? There's a core charge of $90, so I'd only be spending like $150 if I give them mine.
Old 04-08-2011, 02:26 PM
94lt1vette94
Any recommendations for an opti? I'm looking to buy one this weekend and I want something that'll last.
Old 04-08-2011, 04:50 PM
mmracecars
mmracecars's Avatar
i myself thru my camaro and vette have had problems with ones from advance/autozone and a couple of msd's,before i bought an ac delco unit,no problems since. have also heard good things from chandlermotorsports ,vendor on here,and there very cheap.
mike
Old 04-10-2011, 06:08 PM
94lt1vette94
Just ordered an opti from chandler motorsports. Hopefully it's as great as the reviews make it out to be. I can't see how I could wrong with it regardless, seeing that it was $114 shipped lol
Old 04-11-2011, 07:08 PM
94lt1vette94
It shipped! It should be here sometime this week. Is the install that difficult?
Old 04-12-2011, 02:37 PM
0ChandlerMotorsports
Former Vendor
ChandlerMotorsports's Avatar
Thanks for the business!
To '94 Vette Through Some Codes (HELP!!!)
Old 04-12-2011, 08:57 PM
94lt1vette94
Lol, no problem. I'm looking forward to getting a quality piece. Hopefully everything operates as it should...I've read mixed reviews
Old 04-13-2011, 11:20 PM
94lt1vette94
Talk about FAST shipping!!!!
Old 04-14-2011, 11:12 PM
94lt1vette94
Took the water pump off today. I'm having a hard time getting the 4 plug wires off of the opti on the driver's side. Also, how'd you guys block the crank pulley?
Quick Reply: '94 Vette Through Some Codes (HELP!!!)
