Weight of a door
89 Coupe door.
Bare door with wire harness and hinges = 56lb
Window regulator and motor = 6 lb
Door glass = 9lb
Door mirror and housing = 3lb
Door glass = 9lb
Thanks Hooked didn't realize how much they weighed! I found a set of Carbon Fibre Doors for sale cheap and they only weigh 12 lbs. bare nice weight savings Pipe
the doors on early vettes is a little bit less, also the targa tops . the crash beam on the 1984- early 1986 is not as beefy
don't know abt PA, but in NY the answer is 'no', law here sez you must have 'saftey glass' (dot label /numbered) at 'immediate right and left of driver'...hint: little glass front side 'vent' wings on 80's chevy vans have dot labels...of course, if you have 'nothing at all', that passes in some places...
