L-98 cast heads vs aluminum
No sale...
GM makes no such heads.
try reputable sources for information:
http://users.erols.com/srweiss/tablehdc.htm#Chevy
What was interesting was that these "mystery" heads were ordered from GM performance parts, and seemed to be CNC machined. The person had them flowed and had the fantastic numbers...
Hey guys just found this thread. I went to get plugs for my '91 Vette with the last year of the L98 and they asked what heads it has. How do I know for sure if it has aluminum or steel heads?
Thanks.
Thanks.
Aluminum heads, unless an F body guy stole them.
68post (09-23-2022)
From this currently hypothetical upgrade.
The F body has Iron heads.
The Y body recieved aluminum upgraded heads.
If you could get the aluminum heads near free.
Also would require your time and actual swap.
The weight reduction is near a 10HP increase.
The head CC volume is a gain in compression/ potential power increment.
This would most likely. Turn into PROM tune corrections. Economically this would require you as the tuner. purchasing the pocket programmer.
Learn and burn.
The air flow is a equal stand still.
Learn and burn.
