where is knock sensor? and ESC module?
Old 03-10-2009, 03:26 PM
rithsleeper
rithsleeper's Avatar
Default where is knock sensor? and ESC module?
Is knock sensor opposite my water coolant temp sensor? and is the ESC behind the bread box passenger side?
I'm getting a ESC code and car is running like crap, but was perfectly fine a few weeks ago.
'86 L98
Old 03-10-2009, 03:50 PM
86GoldProject
86GoldProject's Avatar
the knock sensor is down by the the starter, a little in front of it, threaded into the block just above the oil pan, it has a 1 pin connector and its round, kinda hard to see.. not sure on the esc, I'd havta dig a manual out.. my car was kinda lacking parts when I got it..
Old 03-10-2009, 04:18 PM
lil_Mike
lil_Mike's Avatar
Old 03-10-2009, 04:30 PM
JAKE
JAKE's Avatar
'86 L98
No, the ESC isn't behind the breadbox.
It's under the hood, passenger side, near the firewall, mounted behind the front tire. A little rearward of the hood latch. About the size of half a pack of cigarettes.
Hard for me to describe where it's mounted.
Jake
West Point ROCKS!
Old 03-10-2009, 04:45 PM
Muffin
Support Corvetteforum!
Muffin's Avatar
ESC is mounted just below the HCAC blower motor.Faces outward, may be partly covered by the passenger "gill".
Old 03-10-2009, 04:56 PM
"swamp rat"
"swamp rat"'s Avatar
Originally Posted by RPD_Vette84
Thats nice wat ci ?????????
Old 03-10-2009, 05:00 PM
JAKE
JAKE's Avatar
Yep, I guess between the two of us he'll be able to find it.
Jake
Old 03-10-2009, 05:17 PM
floridamale
floridamale's Avatar
This might help
Old 03-10-2009, 05:22 PM
JAKE
JAKE's Avatar
Originally Posted by floridamale
This might help
YEA!!!
Jake
West Point ROCKS!
Old 03-10-2009, 06:27 PM
lil_Mike
lil_Mike's Avatar
350ci.
Old 03-12-2009, 02:04 AM
86GoldProject
great pic showin the knock sensor. Is that aluminum heads AND block?!?! haha jk
Old 03-13-2009, 04:18 AM
Firevette
Firevette's Avatar
Cruise-In X Veteran
Originally Posted by joshwilson3
And can the knock sensor be removed without lifting the car?
I can tell you it can be removed by lifting the engine...dont ask how I know this....
If you have an oil cooler, I dont think there are any drain plugs.
HiHp63 (04-11-2021)
Old 03-13-2009, 05:06 AM
floridamale
The knock sensor is used for the drain plug passenger side if you remove it coolant will flow from the hole, There should be a fitting with a bolt on drivers side
Old 03-13-2009, 09:54 AM
onedef92
onedef92's Avatar
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
When you go to remove the knock sensor, take care you don't break the plastic nipple (acoustic coupler) thingie that surrounds the sensor electrode. One slip of your box-ended wrench and BLOOP! It's done for.
You can use a pair of vice clamp to get a good bite on the circular part of the sensor to coax it out if need be. Be sure and re-torque the sensor to FSM specs. since it needs to be adequately installed to listen for spark knock.
I believe it's 13 or 15 lbs. but someone who knows for sure chime in.
Old 03-13-2009, 03:49 PM
JAKE
JAKE's Avatar
To drain the coolant from the block, I've used the Knock Sensor on the passenger side and the oil coolant fitting on the driver's side. But that was on the L98 and 400 blocks.
I haven't had to drain my LT1 block yet, but if I do, I'll look for the knock sensors and/or screw in plugs.
Jake
West Point ROCKS!
Old 03-13-2009, 08:20 PM
86GoldProject
It can if you can get your arm down in there, but it would probably be easier from underneath..
Old 03-14-2009, 11:14 AM
86GoldProject
Is that inch or foot lbs.?
Oh, and I do have an oil cooler on mine.
Does it really matter? Put it in til it's tight.. Just because you HAVE a torque spec for something doesn't mean it's absolutely critical.. I doubt few people have ever installed a knock sensor with a torque wrench..
To where is knock sensor? and ESC module?
Old 03-14-2009, 11:44 PM
JAKE
JAKE's Avatar
Yes, the torque reading for the knock sensor is important to get right. I always torque mine using a torque wrench.
Jake
Old 03-15-2009, 12:13 AM
JAKE
JAKE's Avatar
What is the torque spec?
The FSM for the 86 Vette sets the torque spec at 14 ft./lbs.
It also calls for thread sealer, such teflon tape, on the sensor threads. GM changed the tape recommendation in later year Vettes, but I don't recall which year it was changed.
Jake
West Point ROCKS!
Old 03-15-2009, 01:43 AM
86GoldProject
You don't even have to use a torque wrench to install head bolts, but it would probably be a good idea.
That's one of the few things you ever see someone in the shop pull a torque wrench out for. It's important to torque head bolts to spec. If you ever had an engine replaced under warranty at a gm dealer I can almost guarantee the knock sensor wasn't torqued to spec, along with all of the other sensors. I know I've never bothered to on any engine I've ever done at work, never saw anyone else do it either. Can't say it's ever been an issue. There are probably some guys out there that do it though, who knows.. If you arn't sure how tight to make it a torque wrench defently wouldn't hurt though..
Quick Reply: where is knock sensor? and ESC module?
