Oil leak.. bad pan gasket?
Old 03-08-2009, 05:14 PM
DrEvil11417
DrEvil11417's Avatar
Default Oil leak.. bad pan gasket?
I recently had some work done on my vette... a forum member that will remain nameless
He changed the oil pan gasket, and as soon as I got the car back, there's a leak from the back of the pan, under the rear main seal. I don't think the seal was disturbed (it's a 1 piece, 1990 block).
should I just replace the entire gasket, or is there anything else I should check first?
Old 03-08-2009, 05:24 PM
JackDidley
JackDidley's Avatar
Thats unusual. The gaskets are very flexible. I have used one several times. Are you sure its from the bottom of the motor ?
Old 03-08-2009, 05:32 PM
DrEvil11417
The motor was only 1 year old.. didnt leak before, but the guy ripped the old gasket when he dropped the pan. He didn't touch the rear main seal, it looks like the oil is dripping out between the oil pan and the gasket, there's some kind of small lip
Old 03-08-2009, 06:25 PM
JackDidley
JackDidley's Avatar
Its real easy to drop the pan. Just have to take the flywheel dust cover off first. At least on my 87.
Old 03-08-2009, 11:14 PM
96GS#007
96GS#007's Avatar
Received 1,739 Likes on 1,047 Posts
I'll guess that he didn't adequately clean the block and use RTV in the corners per the FSM. A leak like you describe is pretty typical when someone does that.
Old 03-09-2009, 11:30 AM
redrose
redrose's Avatar
RTV is critical...have seen some RTV no-seal cases, none since using permatex 'ultra' grey...MUST allow 24 hours for RTV to fully cure or crankcase pressure may create a flow channel (oil leak)...many shops bow to customer demand with immediate delivery after repair and RTV failure results (hope that wasn't you)
Old 03-09-2009, 11:39 AM
M.J.L.
M.J.L.'s Avatar
St. Jude Donor '10-'11
Reclean it, put on a new gasket(my personal preference), and use RTV. Let it cure for 24 hours like mentioned, then it should stop the oil leak. Be sure to clean up any oil that may have dripped onto the pan or other parts of the car. It will burn off but it will stink and smoke a little until it's all gone. I know from personal experience.
Old 03-09-2009, 11:44 PM
Jims 92 lt1
Jims 92 lt1's Avatar
plan on replacing my oil pan gasket soon. Permatex ultra grey on one side of the blue rubber gasket facing the pan. Felpro kit comes with plastic pins making aligment much easier. I have the 92 lt 1. Other than the inspection plate on trans, what else has to come out to make way for the pan removal ? Starter ? etc thanks jim
Old 03-10-2009, 07:34 PM
DrEvil11417
so the permatex goes between the pan and the gasket, not the gasket and the block?
Old 03-10-2009, 08:31 PM
rickneworleansla
rickneworleansla's Avatar
On my 95 I had to remove the oil filter, oil filter adapter(gasket), starter, and flexplate cover.
Old 03-10-2009, 09:19 PM
steve40th
steve40th's Avatar
St. Jude Donor '03 & '05
I put some on the block at the four corners, then put the gasket up and applied a little more on top. No leaks. Maybe overkill but it works.
Old 03-10-2009, 10:37 PM
96GS#007
96GS#007's Avatar
Old 03-10-2009, 10:47 PM
STL94LT1
STL94LT1's Avatar
I installed my oil pan gasket dry, and no leaks.
Old 03-10-2009, 10:57 PM
96GS#007
96GS#007's Avatar
bastich
Old 03-11-2009, 08:00 AM
jwt1603
Support Corvetteforum!
jwt1603's Avatar
Old 03-11-2009, 09:05 AM
onedef92
onedef92's Avatar
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Use a Fel-Pro gasket and you won't leak from that area for a long, long, long, time.
Old 03-11-2009, 11:57 AM
rickneworleansla
I'm resealing my oil pan this weekend. (cam install) I went with the $40 FelPro gasket. Will I have any problems installing this thing if my timing cover is already installed? Is it just a matter of putting the front rubber up in the timing cover groove?
To Oil leak.. bad pan gasket?
Old 03-11-2009, 01:31 PM
onedef92
onedef92's Avatar
Did some research on the Fel Pro gaskets since it's been more than five years since I installed mine....
OS34509T: Thin seal
OS34510T: Thick seal
Which type you use is dependent on your oil pan, not the block or timing cover.
Also, one-piece main seal blocks use this one: OS34500R
Here's a picture of the thick seal version (OS34510T) for 2-piece main seal blocks:
Old 03-11-2009, 01:40 PM
jwt1603
jwt1603's Avatar
OS34509T: Thin seal
That's the one I used and it seems to work fine on my 94.
Old 03-11-2009, 02:00 PM
STL94LT1
STL94LT1's Avatar
You want the timing cover installed before the oil pan, and yes the gasket just fits in the groove. The Felpro gasket is blue and easy to see if it is seated correctly once the oil pan is installed.
Quick Reply: Oil leak.. bad pan gasket?
