Is this Optispark dead?
When I did my cam swap, I inspected my optispark, and found this (shown in the pictures) There was little oil, not much in the optispark, but the rotor was halfway detached. Since I had to get the car roling and out of my friends shop I had no other options as assemble the car again with the rotor repaird with epoxy glue as a shorttherm sulution.
Today I drove a longer drive with the new cam, on the stock tune, and I get some missfires at low rpms, could this be due to my Optispark or the stock tune I have. I get code 300, the car is stumbling also sometimes when I get on it.
I also had some missfire problems before my cam swap, but I am not sure how a Lt4 with a Hotcam SHOULD drive on the stock tune.
Here is the half lose rotor lead
There is some tear in the leads here aswell
There was also some play in the opti beaing..
SO.
How does a dying Optispark feel?
How should a LT4 with a stock tune and Hotcam Drive?
SO.
That cap and rotor have seen better days. What was loose on the rotor, the 2 torx bolts or the metel contactor ???? You said you had to epoxy something......use loctite on the screws......but if you had to epoxy the metel contactor due to plastic tabs not holding it in place, time to replace rotor/cap.
What kind of Opti is that anyway ???
yes, one of the tabs holding the Conductor in plac eon rotor was broken off. So the conductor was loose.
What would a dying opti feel like?
St. Jude Donor '05-'06
Exactly as you described in your first post. I would have at least put a new cap and rotor in if not the whole unit. You will get misses as the carbon tracing I am sure you had occurs. If you look closely at the cap you will see little lines of carbon. You also probably opened up the gap from the rotor to the pins causing a larger spark gap. I could go on but just replace it and be done with it.
If you could feel play in the rotor bearing, I'd replace the entire unit. That's probably what started the abnormal wear against the cap, which in the long run loosened the rotor.
Mine showed exactly your symptoms and it's now in pieces on my bench. Maybe I'll make a clock out of it.
Stock Opti Insurance
Before I install my new optispark I'd like to prevent any future problems. What type of fasteners are those it is sealed with? Tool? What parts need the locktite. High strength? or Medium?
You can get a 6 piece deep wall "External Star(torx) Socket Set" from Harbor Freight. The Opti uses size E4. Can't beat it for $7
http://www.harborfreight.com/cpi/cta...emnumber=95178
The 2 normal torx rotor screws should use locktite "red". I would think the "blue" medium would also be fine, I just use "red" . Dealers choice. It would be easier to replace a rotor in future if you use the medium blue stuff. I am not sure why these 2 screws do not have ""star" lock-washer considering the high rotational spin and vibrations.
The Opti unit is sealed with 4 "inverse" torx screws.
You can get a 6 piece "External Star(torx) Socket Set" from Harbor Freight. The Opti uses size E4.
