Success! Transplanting a '92 LT1 Instrument Cluster in a '91 L98! Pics inside
Old 02-07-2009, 12:55 PM
janarvae
janarvae's Avatar
Default Success! Transplanting a '92 LT1 Instrument Cluster in a '91 L98! Pics inside
Hi all,
A while back I posted a video of my idle. One user noted that the idle was reading very high, while sounding like a lower speed. I bought a ALDL USB cable and did some datalogging with my laptop. I found that my '91 instrument cluster was reading about 2X or more higher than the actual RPM. I decided I'd rather take the chance with the cluster than try and change the tachometer filter deep in the engine bay. I researched the forums and posted a WTB and info thread. The inaccurate tach had never bothered me before, when I was oblivious to the problem. However, as soon as I became aware, I had to have it fixed!
I ended up with a '92 LT1 instrument cluster from a forum member, received it on Thursday, and just installed it last night. It took me about 3 hrs total. The new (to me) cluster is spot on. I also like that the gauges have more ticks, making it easier to guesstimate the values.
I swapped the LCD out of my '91 because I had read the LT1's display the MPH on the top, and fuel level on the bottom - this is the reverse of the '90 and '91 readings. The mileage is displaying correctly and the lights and warnings seem brighter.
I'll probably make a thread or add to this one for a DIY with all the pictures I took. It was really simple - just plug and play. No modifications were needed, excepting the LCD swap for personal preference. I also cleaned all contacts with alcohol as well as the transplant cluster gauge faces. It looks much better than the original.
Some pictures:
Rear of the new cluster (all screws in cluster are T-15):
New Cluster Lens Removed:
LT1 Cluster Face & LCD:
Removing the LT1 LCD - As easy as pulling it out (no screws):
LT1 LCD & Color Backing for turn signal/high-beams/speed:
Taking the LT1 cluster apart further for fun:
The Old L98 Cluster:
Removing the hush panel:
Hush panel light and ALDL connector disconnected:
Removing the silver panel so I can access the 2 steering wheel support bolts (15mm head, torque to 20ft-lbs) to lower the steering wheel/column:
Steering Wheel Column Support Bolts/Bracket:
Steering wheel lowered, now we can remove the 4 screws attaching the old cluster to the car:
Cluster Removed:
L98 (top), LT1 (bottom):
LCD Swapped Out, Everything else is from the LT1 cluster, except for the lens (used the original):
Installed in the car:
Video:
The beeping is the hard-wired Valentine One starting up. (Wow, I sound weird on a video )
I'm going to hook up my laptop and verify its accuracy.
-Jonathan
Old 02-07-2009, 01:08 PM
MikeC4
MikeC4's Avatar
Very cool indeed !!! Question: How hard was it removing the "silver panel" ? On my '94, it looks like I would have to remove tunnel carpeting to get at some botls that are recessed(ie can't be seen)
just curious.....
Old 02-07-2009, 01:12 PM
janarvae
janarvae's Avatar
just curious.....
You're talking about the 2 bolts next to the tunnel? I was able to access them without issue. They were a bit close to the tunnel trim, but I used an extension on my 1/4" ratchet. When removing the silver piece, you'll need to unscrew the 2 bolts holding the air duct in place. These are 2 small screws that are at the end of the silver piece. Then you can pop the air duct out. When reinstalling, leave these unscrewed, pop the air duct in, THEN maneuver the piece in and install the 4 screws holding the silver piece on.
Video added to the first post - that beeping is the hard-wired V1 starting up.
-Jonathan
Old 02-07-2009, 01:16 PM
engle1147
Support Corvetteforum!
engle1147's Avatar
Looks good.
Check to see if some of those trouble codes you're getting go away with the new cluster in there.
Old 02-07-2009, 01:18 PM
janarvae
janarvae's Avatar
Originally Posted by engle1147
Looks good.
Definitely. I think I'm having some trouble with converter lock-up too (getting 12 MPG!!!), but I'll work on that next week.
Old 02-07-2009, 01:37 PM
blkvette85
blkvette85's Avatar
I was thing of doing this swap. The tach on my 91 is way off. I like the higher red line (orange line).
Please keep us posted on the lock-up issue.
Old 02-07-2009, 01:57 PM
janarvae
janarvae's Avatar
Do the swap - you won't be disappointed. I just took it out for a run and realized that what I thought was redline was only 2500 RPM!!!! It was off the old tach at the same sound level/accelerator travel. Gosh, this is a corvette now.
Old 02-07-2009, 02:50 PM
383vett
383vett's Avatar
Received 1,541 Likes on 1,042 Posts
Wow, you thought you were redlining when the motor was at 2500? Now you have a whole 3000 or so rpm to play with. No more short shifting.
Old 02-07-2009, 05:13 PM
Ramrod92
Ramrod92's Avatar
Cruise-In II Veteran
Nice job Jonathan. The pics came out great. If anybody plans on doing this and needs a cluster, drop me a line.
Old 02-07-2009, 05:24 PM
pologreen1
pologreen1's Avatar
Old 02-07-2009, 07:03 PM
BrianCunningham
BrianCunningham's Avatar
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
Old 02-07-2009, 07:42 PM
l98tpi
Max G’s
l98tpi's Avatar
Old 02-07-2009, 10:43 PM
lite blue
lite blue's Avatar
St. Jude Donor '12
Nice work!
Old 02-08-2009, 08:28 AM
Dale1990
Dale1990's Avatar
St. Jude Donor '15
Good Job!
I just did that on my 90 a week or so ago except I used a ZR1 tach instead. Same basic deal tho.
Old 02-08-2009, 10:39 AM
Iroc57
Iroc57's Avatar
I didn't see you rev to check the rpm
Is it more accurate now? I remember noticing that on your thread a while back
Old 02-08-2009, 11:01 AM
twin540
twin540's Avatar
Good work ,this post well be a good reference post..
Old 02-08-2009, 11:53 AM
janarvae
janarvae's Avatar
Yep, it is VERY accurate. I hooked up my laptop and ALDL cable to check. I also notice that my oil pressure doesn't seem so low now at hot idle. I think that, as some suggested, the old cluster may have been reading the oil pressure inaccurately too. I have some videos of some runs and exhaust notes I think you guys will appreciate.
383vett - Yea, it was - thinking I was redlining it at 2500!!! Now I truly appreciate the Corsa cat-back - its presence is more known at a true 4000 RPM...
Ramrod92- Thank you! If anyone has a need for an early Lt1 tachometer, definitely contact Ramrod92.
For those with a '90 or '91, with an inaccurate tach, I would definitely consider this swap. The LT1 has brighter lettering and more deviations in the gauges.
Thanks to everyone else for the comments,
-Jonathan
To Success! Transplanting a '92 LT1 Instrument Cluster in a '91 L98! Pics inside
Old 02-08-2009, 12:15 PM
Ramrod92
Ramrod92's Avatar
-Jonathan
Thanks for the plug. Here's why I have my stock cluster out. http://forums.corvetteforum.com/c4-t...h-in-92-a.html
Old 02-08-2009, 02:01 PM
Sparkostatic
Sparkostatic's Avatar
Cool thread...but my steering wheel looks better than yours!
Old 02-08-2009, 03:06 PM
vetteman9368
vetteman9368's Avatar
Location: I have no tolerence for liberals and fools, but sometimes i repeat myself
CI 3-5-7-8-9 Veteran
St. Jude Donor '08
glad the cluster worked for you
Quick Reply: Success! Transplanting a '92 LT1 Instrument Cluster in a '91 L98! Pics inside
