cam change with motor in car?
Is it possible to do a cam change with the motor in a 96 lt4?
Also if a guy had 16 good magnets and ppl to hold them do you think I could pull the cam while holding the lifters up with those magnets? then put the new one in quick? so that way I wouldnt have to pull the intake off.
Received 1,789 Likes
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
It can be done in the car but I would recommend taking the intake off. Th only other way to get to the lifter is to take the valve covers off and go through the guide plate where the pushrod goes. You would nee a long small magnet. I would feel safer doing it the right way.
Yes, you can change cams with the engine in the car. In addition to the other parts, remove the intake, unbolt and remove the spider and remove the lifters.
Jake
Jake
Why would you want to bother with magnets ? Pulling the intake is alot easier than just about everything else you are going to have to do to swap the cam.
I'm thinking it would still be easier to pull the heads off with the engine in the car and then drop the transmission to get to the converter.
But my answer for the O.P. is why monkey around with magnets and hope you don't drop a lifter when it's relatively easy to pull the intake manifold off an LT4? Or as Dr. Ian Malcolm from Jurassic Park would put it, "Yeah, but your scientists were so preoccupied with whether or not they COULD, they didn't stop to think if they SHOULD."
Received 3,043 Likes
St. Jude Donor '05
LT4 intake is a cakewalk to remove will take less time than messing around with whatever magnets you think you can get to work.
If the person doing the job has any mechanical skill, pulling the intake takes about 30 minutes.
why pull the intake though and have to replace the gaskets and reattach all the vacume lines and injectors when you can spend 16 bucks on 99 cent magnets and save time? seems alot simpler to me..
plus if one drops then you can always fall back on pulling the intake, since the oil pan has to come off anyways...
St. Jude Donor '05
I am still trying to figure out why he doesn't just yank the engine out and throw it on a stand to make it real easy. The tranny is getting unbolted for the TQ antway and the accessories are coming off so the only thing left is the exhaust.
A local shop charges less to pull the motor vs doing a cam in the car. That's because the labor manual shows less work to pull the motor.
If you want a REALLY good idea of what's involved, go to Vader's website. Click on Technical Info link (sidebar). Then click on Hotcam installation.
In his link, you'll see a complete to-do list with plenty of pics.
