Need a new battery, what is the best buy?
I went with one of the top of the line autozone batteries. It has a good warranty and like last time I can easily swap it out in the parking lot if I need to. Theres a lot of Autozones around here.
I personally like the Gold top battery from Autozone. Yes I know what you're thinking but the battery just wont die. Its been in my vette for over 3 years now and has been completely drained, sat for months, and still will start the car after sitting 3 weeks. They come with a 3 yr warranty and arent that expensive.
If you run your battery down alot, that could damage your alternator as it isn't designed to recharge a drained battery. The battery that came in my Vette when I bought it kept running down low, and I'd still start it when I could. The alternator ended up needing to be rebuilt soon after I got it. I believe it was due to starting it with a low battery all the time.
Get one from a supplier close to your house. If that supplier has a national chain, even better. You can make warranty claims much easier from a chain.
As noted above, if the car sits for some time, you need a battery management strategy. The Battery Tender or similar device is a must to keep whatever battery you select in good condition. If you select the worlds best battery and let it sit for long periods of time, there will be trouble. Corvettes love to eat alternators used as chargers.
Several great brands out there at a reasonalble price. The real key is what happens after the battery install.
I used Interstate, cause the dealer was about 2 miles from my house. Battery Tender works great. No battery/alterator trouble for 4 years.
Enjoy your car.
dlmeyers
Enjoy your car.
dlmeyers
I had an Everstart Maxx in my 89 for 6 months. I didn't drive it much, and kept it unplugged when I didn't drive. While I had the battery pulled to clean the engine. I took it to Autozone for a charge and test. It tested bad. I took it back to wally world and got my money back.
I was looking at going with AC Delco but not sure.
AC Delco professional 75 battery with 5 year warranty (18 month free replacement, rest is prorated) has 550 cold cranking amps and is $95.
AC Delco 60 series 75 battery with 60 month warranty (12 month free replacement rest is prorated) has 680 cold cranking amps and is $75.
Kind of hard to decide which one is better. Though, they charge a core charge for some reason. I still don't understand why. I may just look into interstate if one is local or Duralast.
Location: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
Since there are only 3 or 4 actual manufacturers of batteries but hundreds of different labels on the batts, I just use the WalMart brand battery. They are affordable and made by the same manufacturer that makes the other high dollar batts. If the car sits, use a battery tender jr. to keep it up to snuff. You will extend the life of the battery by one or two years by doing this simple step.
Got excited about optima yellow tops based on a lot of recommendations. I put one in my 86 vert and one in my Bronco. BOTH are CRAP and die very often. If I don't start either car for a week they drain.
Once a yellow top optima dies, it never fuilly re-charges again. This IS from experience and not heresay.
I even looked for threads on how to recharge and dd it slowly at 10 to no avail. 1 week and they're dead.
I would stay away from optima yellow tops. I don't know anything about red top optimas but they can't be that much better.
You can buy a batter mat (ironically yellow) which will keep your battery tray DRY.
Though, with regards to AC Delco batteries, it looks like to me their warranty sucks when you compare it to other similar batterys of the same price. In order to get a good warranty and good cold cranking amps, you're looking at a 7 year (3 year free exchange, the rest is prorated) professional AC Delco for around $150 I think.
So, I don't really see an advantage of getting an AC Delco battery where you can get the same thing for half price. Other than for looks. I'm gonna call up a local Interstate dealer and see what prices and specs they have on the interstate batterys.
I'd like to get AC Delco, but don't want to loose out on the extra cold cranking amps if I went with another brand.
if you want to save some money, ask your interstate dealer if he has any "blems". they have slight cosmetic imperfections but are still good batteries with the same warranty.
You're not supposed to use a yellow top. That is a deep cell battery like for a boat. Car battery's are supposed to be kept at or near full charge at all times and kept topped off. Deep cell batterys like to be drained then recharged, not kept topped off all the time like what happens in a car.
#33
Yeah the blue is their marine battery, I think the red and yellow should be set up for auto use.
I had a red top in my Eclipse before the Vette, and I think it's still running that battery, probably 5 or 6 years later. I like the Optima's but as far as I know the only Optima you can fit in there has top posts and side posts, putting the top posts too close to the ECU support for my taste. Last I checked they didn't list a red top for my '90.
I picked up an Auto Zone Duralast Gold over the winter, the Delco that was in the car when I bought it threw in the towel. I've had good luck with the Auto Zone batteries, they are local and easy to buy/exchange.
#35
#36
The Interstate battery was $100 for the 75 series with 2 year free exchance warranty and the rest is pro-rated. It had 650 cold cranking amps.
I really don't see the point in buying an Interstate battery when I can get the same thing at Autozone for $70 for a Duralast. I've read they are both made by the same company, Johnson Controls I believe.
#37
I elected to have it sent to the store for pickup so I'm pretty sure it won't be new old stock.
Anybody want a dual post optima yellow top free :-) ?
I can't guarantee it will stay charged more than 4-5 days at a time.
#40
I have a 5 year old Duralast gold in my 89 Firebird, it has a black top on it. And I was looking today and noticed all kinds of corrosion where the battery is sitting on. Not too big a deal as it is only worth $1k. But I wouldnt' want to have corrosion happening on the Vette. The battery does look pretty dirty, so I guess it could be leaking from around those two top pull pieces.
