Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-02-2009, 03:43 AM   #1
mrdahk
Junior Member
Default Cruise control doesn't work
The cruise control in my 86 doesn't work, where do I start?
I'm not very mechanically inclined so use small words please
mrdahk is offline   Reply With Quote
Old 02-02-2009, 06:44 AM   #2
toptechx6
CF Senior Member
toptechx6's Avatar
The brake switch can get out of adjustment, try holding up on the brake pedal with your toe as you try to engage the cruise on the road, if it sets the brake switch will need to be adjusted.
If it still will not set, check all fuses and verify manifold vacuum is present at the cruise servo (located above battery) You will likely need a Factory Service Manual if the checks mentioned fail to get it working, good luck.
toptechx6 is offline   Reply With Quote
Old 02-02-2009, 08:31 AM   #3
AGENT 86
CF Senior Member
AGENT 86's Avatar
Start with reading these and see if you can follow the diagnostic steps.
http://members.shaw.ca/dankai/Cruise%20Control%209C.pdf
http://members.shaw.ca/dankai/Cruise%20Control.pdf
AGENT 86 is offline   Reply With Quote
Old 02-03-2009, 12:20 AM   #4
86PACER
CF Senior Member
86PACER's Avatar
I agree with these guys.
http://www.corvettefever.com/howto/82001/index.html
86PACER is offline   Reply With Quote
Old 02-03-2009, 11:16 AM   #5
josephf31
CF Senior Member
josephf31's Avatar
Send a message via AIM to josephf31 Send a message via Yahoo to josephf31
Default Check
All of the vacuum hoses, especially under the hood to/from the cruise control module
__________________
1991 White C4 Automatic L98 Coupe
josephf31 is offline   Reply With Quote
Old 02-03-2009, 12:35 PM   #6
86PACER
CF Senior Member
86PACER's Avatar
Don't forget about the check valve near the base of the distributor.
Should let air in towards the engine in the normal vaccum direction, but not in the opposite direction.
Reload this Page Cruise control doesn't work
Tags
1986, 84, 86, adjustment, brake, c4, c5, control, corvette, cruise, fuse, parts, servo, switch, work
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
