Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-21-2002, 06:19 PM   #1
StealDads67
CF Senior Member
StealDads67's Avatar
Send a message via AIM to StealDads67
Default 1988 Corvette mods?
I was wondering for a stock 88 vette, where would you start with modding the car, say u have about $1500 wwhat would you do to get the 1/4 times down? Thanks guys :cool:
StealDads67 is offline   Reply With Quote
Old 01-21-2002, 06:41 PM   #2
scorp508
CF Senior Member
scorp508's Avatar
Default Re: 1988 Corvette mods? (StealDads67)
I'll assume you mean a 4+3 since I know you want a stick car.
1. Short Shifter (less time shifting = more time on the gas = better ET) $23
2. K&N Air Filter ~$50
3. Open Air Lid ~$50 (if you buy it, $0 if you make it)
4. 1.6 Roller Rockers ~$260
5. Catback Exhaust $900
6. High Flo Cat $200
7. 1/2 Tank of Gas for race day $17
scorp508 is offline   Reply With Quote
Old 01-21-2002, 07:04 PM   #3
vader86
CF Senior Member
vader86's Avatar
Id look to get a 89 ZF6 if i could. Ditto on Scorps suggestions. Maybe you can look into TPIS headers for about $750. A 160 thermo and fan switch might keep your car cooler which could help your times on a hot day. Look into tires too.
vader86 is offline   Reply With Quote
Old 01-21-2002, 08:36 PM   #4
StealDads67
CF Senior Member
Default Re: 1988 Corvette mods? (vader86)
With all these mods that u have suggested what times in the 1/4 should you expect to run with drag radials also. You guys are great thanks for the help. Oh and i would love to get the ZF-6 but the price jump is to much (From what I have seen) I only have 10K :cry , but i fugure that will get me something decent. thanks again for your time.
Old 01-22-2002, 12:11 AM   #5
vader86
CF Senior Member
vader86's Avatar
i figure you could get really low 14s or high 13s with the drags
Old 01-22-2002, 12:14 AM   #6
scorp508
CF Senior Member
scorp508's Avatar
With those mods and drag radials you better be in the mid 13s.
Old 01-22-2002, 10:29 AM   #7
Scoob
CF Senior Member
Scoob's Avatar
Default Re: 1988 Corvette mods? (scorp508)
Wouldn't $50 muffler elims accomplish the same thing?
Scoob is offline   Reply With Quote
Old 01-22-2002, 10:55 AM   #8
jaa1992
CF Senior Member
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
jaa1992's Avatar
Location: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps GA
James Anderson
Send a message via MSN to jaa1992
Add to scorps suggestions:
Gut the precats - probably $50 -70 to have someone do it. They have to cut them open, remove insides then weld them back together. My guestimate is about an hour labor.
Remove the "frisbee" on the water pump. Some folks picked up .1 sec just with that mod alone - its free!
Or replace the front Y pipe with one with no precats, not sure on cost.
My whole exhaust system is unstatisfactory so I'm planning on headears to tailpipe replacement, my budget is $1500 - 2000 for just that change.
[Modified by jaa1988, 9:56 AM 1/22/2002]
jaa1992 is offline   Reply With Quote
Old 01-22-2002, 02:19 PM   #9
Fastguy
CF Senior Member
St. Jude Donor '03-'05
Fastguy's Avatar
Default Re: 1988 Corvette mods? (jaa1988)
OK, just to be reeeeeeeeal basic here, everything has to have an INSA and an OUTSA. You don't want a killer exhaust and no intake mods or the opposite, its all the combination. Someone here, I think its Vic89 has a great combo going using lots of stock parts. You can probably get a used Lingenfelter Super Ram for $800-$1,000 and some brand new ceramic coated Hooker Super Comps for about $450 but that kills your budget and forget hooking in street tires. I guess for $1,500, I would get drag radials ($320) and spare wheels from an old Camaro or something, (about $60) and then look at headers and exhaust while keeping an eye out for a used SR. You can get Hooker SC's that have all of the emission provisions uncoated for about $280.
Fastguy is offline   Reply With Quote
Old 01-22-2002, 02:36 PM   #10
VetNutJim
CF Senior Member
Cruise-In I Veteran
VetNutJim's Avatar
Default Re: 1988 Corvette mods? (Fastguy)
What is the "frisbee" on there for?
I've seen some WITH it and some WITHOUT it.
Anybody k-no?
VetNutJim is offline   Reply With Quote
Old 01-22-2002, 04:28 PM   #11
jaa1992
CF Senior Member
St. Jude Donor '12
jaa1992's Avatar
James Anderson
Default Re: 1988 Corvette mods? (VetNutJim)
THere have been lots of threads on the Frisbee.
It was put there for some sort of damping that was not required.
Someone asked a Corvette engineer and they said it wasn't used and
could be removed.
As for location, look at your waterpump pulley. I think it is attached to the front of it.
(Guys did I remember that correctly???)
Old 01-22-2002, 08:40 PM   #12
chucks88
CF Senior Member
chucks88's Avatar
could be removed.
Thats a good simple explanation.
I found a 3.08 rear for $400 and had it istalled (including the speedo gear) for another $400
chucks88 is offline   Reply With Quote
Old 01-22-2002, 11:36 PM   #13
Vic'89
CF Senior Member
Vic'89's Avatar
If you want to get your 1/4 mile ET down, then first start with all the small and free mods, like cutlid, K&N filter, gutted MAF sensor, crank pulley, & ported plenum.
Next, you need drag radials, remember you are looking for ET, so you need to cut the 60' time down.
Finally a nice ypipe+catback exhaust, I have the TPIS exhaust and it made the biggest ET difference. 65Z01 also has this system with similiar results.
Good luck.
Vic
Vic'89 is offline   Reply With Quote
Old 01-23-2002, 12:59 AM   #14
TreyZ28
CF Senior Member
TreyZ28's Avatar
Send a message via AIM to TreyZ28
Kevin, just remember, i'm one step ahead of you...:boxing
you'll never beat me
You had a bike
i got a subaru
you got a 3.4 camaro
I got a Z28
You get a mid-high13sec vette
I'll get the Z into 13 sec camaro maybe low 12's :p:
how how bout them long tubes and drag radials... i got the intake!
Hehe just kiddin kev
its all about who has the least wieght in theri backpack that day, and God you know were both good at lightening the backpack! So cheers! :cheers:
SUCKER!
(ps sorry u ruined my first post at Cz28.com...
TreyZ28 is offline   Reply With Quote
Old 01-23-2002, 04:02 PM   #15
65Z01
CF Senior Member
Cruise-In II Veteran
65Z01's Avatar
Send a message via AIM to 65Z01
You can check out my site for things that worked for me and the test/race results.
A good cat-back is essential to gaining HP and I realy like my TPIS cat-back, but you could save some $$ by using muffler elims.
If you have plans to do some internal engine mods, e-mail me for some such mods & test results data.
65Z01 is offline   Reply With Quote
Old 01-23-2002, 05:14 PM   #16
StealDads67
CF Senior Member
Default Re: 1988 Corvette mods? (65Z01)
Hey what do u mean by "normailized 1/4 mile" on that website? and how much did this stuff come out to. Comp Cams 1.6:1 ProMagnums w/ 7/16" studs, springs w/ Ti retainers. OH and guys, All installation for me is free :D I love my dad, He teachs me all the cool stuff also, so it will be little bit cheaper, and i can do most the stuff myself anyways, he just watchs and makes sure i dont do anyhting stupid :rolleyes: Thanks guys
Old 01-23-2002, 05:43 PM   #17
65Z01
CF Senior Member
65Z01's Avatar
"Normalized" means I applied adjustemnts to my ET & trap speed for weather conditions. Check out the math page on my site for the equations. Plug em into a spread sheet, get the temperature and baro next time your at the strip and you can normalize your numbers too.
I believe the cost numbers for the valve train stuff was "about" as follows:
$260-1.6:1, 7/16" ProMagnums
$50-hardened pushrods
$50-7/16" rocker studs
$50-hardened guide plates
$100-Ti retainers
$50-10degree locks(keepers)
$20-upper seals
$20-shim pack
$100-springs
$700-total cost
Though these numbers may be a little off (I'm not home now so can't access my receipts) but the total is accurate to within $100.
BTW, I tossed the oil shedders from the tops of my springs as they realy added some weight and these were not used on the LT1, to help raise the valve float limit.
Old 01-23-2002, 10:36 PM   #18
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Support Corvetteforum!
Mr Mojo's Avatar
Send a message via ICQ to Mr Mojo Send a message via AIM to Mr Mojo Send a message via Yahoo to Mr Mojo
Best advice is to follow Jims work(65 Z01) He backs everything up with multiple runs at the track.
Mr Mojo is offline   Reply With Quote
Reload this Page 1988 Corvette mods?
Tags
1988, 88, air, corvette, corvettes, flow, intake, mass, mod, modifications, mods, performance, plenums, sensor, simple
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
