96 LT4 leaking like a pig
Old 01-17-2009, 05:06 PM
A88FXRS
A88FXRS's Avatar
Default 96 LT4 leaking like a pig
started 96 LT4 today for first time in 3 months. coolant pouring from pass side of radiator, looks like it has to come out. how much of a problem to remove ? seems to leak near the front side of radiator. repair radiator or replace ?
Old 01-17-2009, 05:12 PM
aminnich
aminnich's Avatar
Replace it. The plastic side cap probably broke. It is about a 3 hr diy job the first time thru and the 3 little screws on each side of the shroud are the only pita.
Old 01-17-2009, 05:19 PM
Demonic85
Demonic85's Avatar
He has to replace the whole radiator because of a leak?
Old 01-17-2009, 11:33 PM
larryfs
larryfs's Avatar
the plastic becomes brittle.
Old 01-18-2009, 03:09 AM
Mr. Peabody
Support Corvetteforum!
Mr. Peabody's Avatar
C4 of Year Finalist (appearance mods) 2019
Yea, it's best to replace it in the long run because the plastic will continue to leak when hot and under pressure. I ended up having to have it done on my 95 last year.
Old 01-18-2009, 05:57 AM
Lars87
Lars87's Avatar
replace it. my 96 did the same, and replaced it with a BeCool
Old 01-18-2009, 08:19 AM
MR NICE
MR NICE's Avatar
Repaired tank leak on my truck still good 6 years later.But on the Vette I would replace if cash flow is not a issue.
Old 01-18-2009, 09:45 AM
larry00
larry00's Avatar
You could most likely find a new plastic tank but our cars are old enough to need a new radiator anyway.
I found a three row Radiator at Summit for a couple hundred that will do nicely.
I intend to get old one cleaned and save it for a spare .
The problem with the high dollar radiators is none are repairable and all get clogged if not cleaned every three years professionally.
Dex cool gels worse than green but green and aluminum aren't the best of friends.
Dang if you do or dang if you don't.
I use dex cool and water wetter !
Word of warning about cooling C 4's , they all get leaves and crap in front of the Air cond evaporator coil and you can only reach up there and dislodge so much of it.
I have used vacuum w/ 90 degree attachment , washed with low water pressure carefully from the engine bay side so as to not drown and ruin Opti Spark, but a lot of guys resign themselves to pulling the radiator and cleaning it and having access to clean the Air Conditioning coil which catches the road kill.
If you can't see any road kill up front and are not having cooling issues just flush system at least every three years but two if you love it or don't drive it much.
Another myth to keep in mind is more is not always better!
A thermostat restricts water for a reason.
The longer the water is in the radiator the more cooling it gets.
Same with Electric Water pump , which brings me to a question I'm fixing to put up about what flow to go with on electric WP.
To 96 LT4 leaking like a pig
Quick Reply: 96 LT4 leaking like a pig
