LT1 - Torsional Damper Hub Phasing
Old 01-18-2009, 10:31 AM
TuffyToo
TuffyToo's Avatar
Default LT1 - Torsional Damper Hub Phasing
I have a 1994 Vette LT1 Motor. The torsional damper and hub were removed from the end of the crankshaft. The crankshaft is keyed, but the damper hub is not. Since the hub is not keyed, can someone tell me the correct phasing for the hub. Does it align with #1 TDC?
Old 01-18-2009, 10:44 AM
STL94LT1
STL94LT1's Avatar
Yes. You should also see a shadow on the inside of the hub where it was aligned to the keyway.
Old 01-18-2009, 11:01 AM
TuffyToo
TuffyToo's Avatar
I don't see a shadow on the inside of the hub where it's aligned with the keyway. Does the small triangle on the damper also indicate TDC? The hub bolts are such that it will only bolt to the up to the damper one way.
Old 01-18-2009, 11:17 AM
STL94LT1
STL94LT1's Avatar
Yes, the triangle indicates TDC. Since these engines were neutral balanced through the dampner. It is not critical that the triangle has the be perfectly aligned at TDC. Either mine had slipped or was off about 10* from the factory.
Old 01-18-2009, 11:21 AM
STL94LT1
STL94LT1's Avatar
Once the dampner is installed back on the car it is difficult to see the triangle. You may want to mark the outside of the dampner with a paint pen at TDC #1/6, this will help for future reference.
To LT1 - Torsional Damper Hub Phasing
Quick Reply: LT1 - Torsional Damper Hub Phasing
