LS1 IN A C4
Location: No more yankee my wankee, the Donger is tired!
1 Post
Re: LS1 IN A C4 (vettewrench)
TracerX on the forum dropped a LS1 into a 84. It wasn't easy and I'm not sure if they ever completed the job. Last I heard it was running and had been driven, but not sure if he had any probelms that cropped up with it.
When I went to U&W Corvette Parts in Hannover, Germany, to have my new brakes installed, I saw a 71 coupe that was just getting a LT4 engine transplanted. The guys there told me of another 71 convertible that they where equipping with a LS1 engine. Their webside is
http://www.corvette24.de/
I think, they have an e-mail link posted there.
BTW: I´ve heard you´ve done something nice to the centre console of your late C4. I hate the plastic look of the original! Can you post a pic?
Re: LS1 IN A C4 (BrightAquaLT1)
[/QUOTE]
Thanks for the info here is a pic
[Modified by vettewrench, 9:13 AM 1/20/2002]
[/QUOTE]
Elite Torch Red Member
There is someone running around PA with an '88 with an LS1. Never got a chance to mee th guy at the track, but the buzz was that he had LS1 under the hood.
Re: LS1 IN A C4 (Mr Mojo)
Well I was thinking of taking on the job of droping in a LS1 in my 95 anybody try or do this?????? TIA
All in all, I'll bet it's much cheaper and easier to hot rod your LT1. A set of AFR heads, a new cam and some long tube headers should get you in the 330-350 RWHP range, that'll beat a stock LS1 with ease. You get to keep the PCM, so no hidden nightmares at the wonderful State of Ill emissions test station.
Just MHO,
Eric
Re: LS1 IN A C4 (silver & red CE)
It will be very difficult to install an LS1 and pass IM240 emissions (I see you live in Naperville, so it can be a very large issue).
The 95 has a Power Train Control Module (PCM) that need the optispark to function. To make the LS1's ignition system work in a 95, you'll have to make an optispark simulator....
If you don't have the optispark, then you'll need to program the LS1 PCM to emulate an 96 LT1 when the emisson tester person hooks the scan tool to you link and scans for codes.
Jimmy
Re: LS1 IN A C4 (Jimmy69)
Why would you think of retaining the LT1 PCM stuff??? An LS1 requires an LS1 PCM to run. The CCM would be the bigger problem. Dunno how you would retain its functionality.
Brian's car is a 95, so its OBDI and is not required to be scanned. They dont do visual inspections, so they wouldnt know a LS1 is under the hood.
Agreed. A 383 motor with a supercharger would be much easier and be able to run away from those HEAD&CAM LS1 cars.
[Modified by silver & red CE, 2:39 PM 1/20/2002]
Cruise-In II Veteran
I can't imagine how you'd get the ABS/TC to work on a 95 with an LS1 PCM. I guess you could just dump it (ABS/TC). Might have a big battle with SES codes.
Re: LS1 IN A C4 (88L98)
I used the motor and trans out of a 98 camaro. I started by making a bracket to mount the rear of trans to factory torque arm, made motor mount adapters, and a few other odds and ends. I am very happy with how the car turned out.
Trace
Trace
Re: LS1 IN A C4 (TracerX)
Well, I guess I won't drop you a line about this thread, Trace. :)
Anyway, Motor mounts are EASY!!!! There are a lot of other things that will be a lot more difficult. :yesnod:
BTW, Traces car is up and running. I saw it the other day! It looks very nice...except for the master cylinder... :p: :p: :p:
NCM Bash 2008-2018
Location: Granby, MA Talladega Super Speedway Vettes 4 Vets Ambassador
Middle TN Events Coordinator
Cruise-In 1, 3, 9. 10 & 11 Veteran
Re: LS1 IN A C4 (Chris@SpeedDemon)
i have heard of traces car.........amazing.....the will and desire of some people....hehe
Re: LS1 IN A C4 (ChrisB)
Thanks for all the posts and info guys im just getting ideas and it will not go for emmisions so that wont matter even if it didn't pass no biggie.
jeff I was thinking of the LS1 im my 73 too will see what happens!!!
Thanks, Brian
Thanks, Brian
And trace has about the best looking hood I have ever seen on any C4 - it's a sweet car for sure!
Hey Speed Demon, I thought you liked my master cylinder mod ;)
Trace
Trace
You need to put up a website that details this conversion. It's quite an impressive accomplishment and it seems you are becoming somewhat of a legend!
Re: LS1 IN A C4 (Eric Fischer)
Trace,
I am putting together some info and hope to have a website up very soon.
Thanks for the compliment.
