Leaky windows!
Leaky windows!
The weather stripping was bad when we bought the car so my dad and I put new weather stripping in and now they don't seal right. Any ideas?
And can anyone give me an idea of how much a transmission rebuild would run me for labor if I supply the rebuild kit?
Looks like you gasketed over gaskets. There are stops in the door that you can adjust higher to get the window to seal better. The door panels will need to be removed to access the stops. Also you'll need to reinstall the door panel to so it applies pressure against the widow glass for a correct adjustment then check for leaks using a water hose. It is kind of trial and error thing....you may have to remove and install the panel several time to find a good seal alignment. Use care/caution when working with the door handle bezels as the plastic may be brittle from age.
http://forums.corvetteforum.com/c4-p...air-video.html
My Dad said he's played with the settings already and the pictures are as far as close as he could get it. Is there anything else I can try? I'll still get the fsm out and give it another go, but incase it doesn't work I'd like a plan B.
Good Luck!
Getting the windows to seal well -new OR old weatherstripping - is a black art. Sometimes it helps to sacrifice a butterfly to the carburetor Gods...
Seriously - it's a challenge. It's unlikely that you (or Anyone) will Ever make the car perfectly water tight. Not to the point you would be comfortable taking it thru a car wash.
That said, with enough messing around you Can probably get the thing where it won't leak in the Rain. For a while, anyhow. Eventually you and the car will reach a compromise - It doesn't leak onto the Seats and You stop messing with it
Another thought - keep those new rubber parts out of the sun, as much as possible. UV exposure just plain Kills stuff like that, and the C4 design does a lousy job of Shading a Lot of that foam.
BTW, and for what it's worth.. I found it necessary (or at least Simplest) on My '85 to relocate slightly the drivers side A-pillar weatherstrip channel. I could NOT get a tight seal between the forward edge of the glass and the foam until I shifted the sheet metal channel that Holds the foam up/out about 1/4". After doing That modification getting a good seal was easy. The Passenger side didn't need the mod to work OK, and it's really hard to measure anything to tell what's "off" from side to side.
Who knows, someplace along the years perhaps a windshield install guy screwed it back on "wrong" - no telling how many times the glass has been replaced in a car with This many miles.
Not something that should have been necessary, and I don't recommend doing something like that except as a last resort, but it's Possible..
