Opti alternative?
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
Opti alternative?
For now, I'm sticking with the opti, just bought an MSD unit.
But for those looking for an alternative.
Getting the dash to work might be a real PITA though
http://www.eficonnection.com/eficonn..._cylinder.aspx
http://www.vetteweb.com/tech/vemp_07...tor/index.html
https://www.msdignition.com/product....erms=optispark
* Advanced optical encoder trigger design for accuracy and reliability.
* Easily adjust the timing up to +/-5°.
* Improved housing design and extra bolt eliminates leaks.
* Fresh air vented and sealed to keep the elements out.
* Large ball bearing stabilize
Just what I need Bryan something else to spend money on ! LOL
I already put on LS 1 Timing Cover w/crank trigger just in case I wanted to switch.
The OPTI's are good till about 6800 which covers me unless I decrease compression from 9.8 but right now I looking for another supercharger before I waste money paying off credit cards !
I hate being responsible ! Would rather play !
Just don't want to sacrifice A/C cause it's too Hot in Texas for a street car without it.
I know they got complaints and likely fixed the problem but I would locktite your screws that hold down the rotor cap anyway.
MSD Opti: I bought one to install at the next opportunity...seemed quite high quality/rugged.
Installed it and found a variable rev limiter from 6000-7000 rpm from mile one of the installation. I tried different things for a couple days and finally installed a new OEM GM Opti...no changes...engine runs to 7200 fuel cut.
I got my money back. I was very disappointed especially with the work involved for a failed product. Percentage wise, many issues with the unit.
I hope you have better luck.
By the way, MSD did warranty the fix...new Opti sensor and cap-I did not reinstall-returned to vendor for refund.
