No Clutch Pressure...
1987 Corvette with 4+3.
I haven't Driven the car in a few weeks because of snow here in Iowa, but I went to start the car today and I had no clutch pressure, it just goes right to the floor with little effort. The Master cylinder got changed over the summer and after that I had a nice stiff clutch pedal.
Anyone know what the problem might be?
I looked in the factory service manual but did'nt see anything like this in the diagnosis section.
sounds like when i forget to make sure that my throwout bearing was attached to the fork...but i had the transmission out...if you haven't pulled anything, then i dunno how that could happen...unless there is a line seriously leaking.
I actually didn't change the clutch master cylinder, the previous owner did. I bought the car in september, and have had zero problems with the clutch until now. Nothing looked wet around the master cylinder...
How it spring a leak that bad not using it? haha I still havent located the leak and its too cold outside now!
