Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ Photo AlbumsGarage
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Old 11-21-2008, 02:15 PM   #1
sphinx boostin
Junior Member
Default losing battery over a day
as it states i am losing cranking power if the car doesnt run for over 14 hrs any clue?? thanks for the help
also any recommendation for injectors and the size no mods but axle back exhaust and it will have a cut airlid and possible port match intake manifold
also it hesitates when cold all spark plugs and wires are replaced getting a distributor and rotor in a little bit and a fuel filter? all help is appriciated
sphinx boostin is offline   Reply With Quote
Old 11-21-2008, 02:41 PM   #2
Iroc57
CF Senior Member
Iroc57's Avatar
Find out what is staying on....if there is nothing on get a battery
Iroc57 is offline   Reply With Quote
Old 11-21-2008, 03:09 PM   #3
engle1147
CF Senior Member
Support Corvetteforum!
1989 Chevrolet Corvette
engle1147's Avatar
Send a message via AIM to engle1147
Get with Jon with FICInjectors.....he'll get you on the right path! He has a "sticky" on the C4 Tech & Performance page with videos.
engle1147 is offline   Reply With Quote
Old 11-21-2008, 03:37 PM   #4
Sweet 90
CF Senior Member
1990 Chevrolet Corvette
Sweet 90's Avatar
It will be helpful to know what year your Vette is. Fill in your profile
when you have a chance
Jim
Sweet 90 is offline   Reply With Quote
Old 11-21-2008, 04:14 PM   #5
StealthLT4
CF Senior Member
1996 Chevrolet Corvette
StealthLT4's Avatar
Send a message via AIM to StealthLT4
Take your car to AutoZone or Advance Auto and have them do a battery check. It's free. I was getting pretty close to what you're experiencing, and it turned out to just be a bad battery.
StealthLT4 is offline   Reply With Quote
Old 11-21-2008, 05:26 PM   #6
Jim McCombe
CF Senior Member
Im my case on my 87, it turned out that the 2 under hood lights were remaining on after the front clip was let down.
Removed the light bulbs and problem cured...
One another thing after the battery has been recharged, try removing one of the battery cables then touching it to the post of the battery.
If you see an arc, you have a open circuit or short some where within your system.
Jim McCombe is online now   Reply With Quote
Old 11-21-2008, 09:56 PM   #7
jfb
CF Senior Member
Partial Quote from Jim McCombe:
If you see an arc, you have a open circuit or short some where within your system.[/quote]
It is normal for a spark to occur when reconnecting the battery, there are many bypass capacitors that draw a current pulse when reconnected, also the courtesy lights come on and they draw several amps. A spark does not necessarily mean that excess leakage current is occurring. Also, if you had a short, you would blow a fuse.
If you measure the leakage current, it should be less than 50 milliamps and 50 ma. would take 83 days to discharge a battery. My 87 draws 27 ma. and I have no battery problems.
jfb is offline   Reply With Quote
Old 11-24-2008, 09:15 PM   #8
brinikprice
Junior Member
My 95 is discharging the battery if left for more than 2-3 days without running. At first I thought it could be a bad battery, bought the most expensive, premium 84 month battery, and it happened again, dead as a hammer in two days, replaced that battery and still have the same problem. So I disconnected the negative terminal, let everything power down for about 15-20 mins, then connected a meter and I have a constant 85 milliamp draw, then took out/ replaced all fuses in interior,then both groups of maxi fuses beside the battery, as well as took the wire off the alternator, still about an 80-85 milliamp draw, can anyone help?? This little demon is evasive. Thanks in advance, Brian (brinikprice)
brinikprice is offline   Reply With Quote
Old 11-24-2008, 11:22 PM   #9
Jonnymac
CF Senior Member
St. Jude Donor '08
1995 Chevrolet Corvette
Jonnymac's Avatar
My '95 is doing the same thing right now.
Jonnymac is offline   Reply With Quote
Old 11-25-2008, 04:48 PM   #10
pcolt94
CF Senior Member
pcolt94's Avatar
Quote:
Sounds like you have the right idea but you just need to go a bit further. Maybe you need to not only pull the fuses but unplug boxes like PCM, ABS computer, headlight control or any other item you can get to that might get power. How about fuse links under the hood. Usually it’s the computers, radios and PKE that require power when car is not running. Perhaps a hung relay somewhere. Elimination is the way to do it, the current is going somewhere.
pcolt94 is offline   Reply With Quote
Old 11-25-2008, 10:12 PM   #11
brinikprice
Junior Member
Ok, I will give this a try this weekend, thanks so much for the advice, now if I only knew what a fuse link was. I think you have the right idea about a relay being stuck open or the headlight power, just have to take some more time to try these out. Also any idea where to unplug the ccm or the abs? not sure where the relays are either, this is my first corvette, I am in love with it, just have to figure this out, this site is great. Thanks for the help, also I plan on buying a Factory Service Manual (s) not found any under 160 yet.
Brian
Old 11-26-2008, 05:35 PM   #12
L71Maynard
CF Senior Member
L71Maynard's Avatar
May want to check the starter too. A friend had a Chevy pickup where the starter worked but it was draining the battery. Pull the cable off the starter and see if the power draw is still there
Dave
L71Maynard is offline   Reply With Quote
Reload this Page losing battery over a day
Tags
85milliamp, battery, discharge, draw, long
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertise Here - Contact Us - Corvette Enthusiast Discussion Forum - Archive - Top
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
