LT1 Hotcam Install , Valve clatter
Old 11-09-2008, 08:08 AM
Tuff96LT1
Tuff96LT1's Avatar
Default LT1 Hotcam Install , Valve clatter
OK, folks help me out here. I just installed a new GMPP Lt4 Hot cam kit in my 96 LT1. All was well. I took my time and installed the new GMPP LT4 hotcam, kit came with lifters and lifter tray, and 1.6 roller rockers. I used my original push rods, all checked ok installed a new LT4 HD timing chain set and new Accel Opti. Had the pcm tuned by PCM4LESS. Went together fine, cranked and ran/runs great . After a couple of hundred miles I now get a LOUD clatter from what seems to be cyclinder #8 around 2000 rpm. I warmed up the engine, pulled the valve covers to readjust lash hot and running. Only odd thing I noticed was last valve at back of passenger side was getting 10 times as much oil to the top as compared to any other valve. Oil spraying everywhere. Valve lash seemed ok, and I adjusted to zero plus half a turn. Capped it all up, engine cranks fine, runs fine and is quiet at idle ( normal ticks and clicks) but at 2000 or rpm, clatter is very loud. Quiets down at higher rpms and is quiet at idle. What gives ? Any suggestions ?
Old 11-09-2008, 08:53 AM
Nathan Plemons
Nathan Plemons's Avatar
Well my first guess was going to be that your rockers had worked themselves loose. Normally though you will notice that at idle.
You didn't mention your springs? I thought they came with the hot cam kit. If you did springs and forgot to mention them, I don't know what to tell you. If you didn't do springs, I would say to start there. Stock LT1 springs are marginal for 1.5 rockers. With 1.6's they are dangerously close to coil bind.
It could be that above idle they are so weak that the inertia is "throwing" them into coil bind. It could also be that above idle the springs can't close the valves quick enough and what you're hearing is the slop in the valvetrain caused by the spring not keeping the rocker firm against the pushrod. Worst case it could be valve float and you're hearing the pistons slapping the valves.
I would hope for the first two options. Again if you did do springs, you can disregard these scenarios.
Old 11-09-2008, 09:30 AM
Tuff96LT1
Tuff96LT1's Avatar
Yes , springs are new, came with the kit. Odd it does not clatter cold, but as soon as it warms even a little the passenger side really clatters loud ( seems like cyl #8). Each bank has one lifter ( pushrod & rocker ) that really pumps a lot of oil, all others look normal. I am thinking the lifter(s) is bad, but think it is odd since they are also new.
Old 11-09-2008, 11:16 AM
WW7
WW7's Avatar
Never assume just because something is new that it works properly..WW
Old 11-09-2008, 12:23 PM
Sidney004
Sidney004's Avatar
You might want to post here as well:
http://web.camaross.com/forums/forumdisplay.php?f=9
A lot of very experienced LTX engine builders reside there, good luck and post the results; I was thinking of doing the Hotcam upgrade myself.
Old 11-09-2008, 02:56 PM
Nathan Plemons
If memory serves the rear cylinders seem to get oil more quickly than the fronts at idle. As soon as you get it some RPM's though they all should flow fairly evenly, as far as I can remember. It's been a lot of years since I've had the covers off of mine.
Old 11-09-2008, 10:32 PM
C4DC
C4DC's Avatar
St. Jude Donor '06
duped
Old 11-09-2008, 10:33 PM
C4DC
C4DC's Avatar
St. Jude Donor '06
http://www.camaroz28.com/forums/forumdisplay.php?f=9
Another place to visit. My vote is lifter.
Old 11-10-2008, 04:11 AM
lt4obsesses
lt4obsesses's Avatar
I have a ditto to the noise. Stock LT4 here. The noise started appearing at about 3000 rpm and went away at 4000. Gradually it started getting there at 2500, then 2000. I was hoping that it was an exhaust leak, as the sounds can be similar. Changed the gaskets and I was only half right, the stock gaskets were toast. But, I finally went in for a lifter change and I was right. Unfortunately, the bum lifter scuffed the cam. Hoefully the hotcam in my possesion will be going in next month.
I would check the lifter. The only cost you'll be out is to replace the intake gaskets if you do it yourself. At least you'll know for sure.
Old 11-10-2008, 11:38 AM
Tuff96LT1
Tuff96LT1's Avatar
[QUOTE=
I would check the lifter. The only cost you'll be out is to replace the intake gaskets if you do it yourself. At least you'll know for sure.[/QUOTE]
Sorry to hear your scuffed the cam, other than the scuffed cam how did detemrine lifter was bad ? Was it visibly damaged or other ?
Old 11-10-2008, 01:02 PM
pennscreek
pennscreek's Avatar
Default valve train noise
Along with a cam and roller rockers My builder had a machine shop mill some of the webbing out of the covers,He said they have had new parts hit the webbing before,good luck.
Old 11-10-2008, 01:11 PM
Tuff96LT1
Tuff96LT1's Avatar
OK, covers off.
I cranked engine cold and the ticking seemed to come from #8 exhaust. Also it was pumping oil all the way back to the MidEast. All the others had the normal dribble. So I proceeded to remove intake etc.
Once in I took off #8 cylinder rocker, pushrod and lifter.
I did notice a sharp burr in the edge of the rocker in between the cup and rocker where the pushrod sits. It wiped off easily and no other issues seem to be with rocker. checked Pushrod, is not bent nor damaged. Checked Lifter and it too looks normal, I cannot see anything wrong with it.
I am going to replace the pair of lifters in #8 anyway as at least the only sign (REALLY HEAVY OIL SPRAY) came from that lifter as compared to all else.
Does anyone think I may be on the right track ?
Also, can I replace the rocker studs and lock nuts with LT4 versions with the GMPP Hotcam LT1 Kit 1.6 rockers and simply just torque them down ? Seems that would be an easier valve adjustment.
Old 11-10-2008, 02:35 PM
JAKE
JAKE's Avatar
It may be only a mis-statement on your part, but you repeatedly referred to "valve lash" and "lash", but I suspect what you actually mean is "lifter pre-load", since "lash" is for mechanical cams.
Anyway, just to eliminate the adjustment procedure as the possible cause, how about posting the exact, step-by-step procedure you followed.
I've never checked into this so I'm asking: Are the lengths of the LT1 and LT4 pushrods the same?
Could the mark you found on the rocker arm be caused by interference with the vavle spring retainer? Is there any sign on contact on the retainer?
I much prefer the adjustable lifter preload method as opposed to the method where the nuts are cranked down.
Jake
Old 11-10-2008, 02:54 PM
MK 82
MK 82's Avatar
With hydraulic lifters, you must still find zero lash point before you can adjust preload.
Jake
Old 11-10-2008, 03:01 PM
JAKE
JAKE's Avatar
You missed the point. Lash is the clearance between the rocker arm tip and the valve stem tip. So that term - lash - isn't correct for and shouldn't be used in a discussion of a hydraulic setup.
Jake
Old 11-10-2008, 04:13 PM
Tuff96LT1
Tuff96LT1's Avatar
LASH for a hydraulic cam
That is why the instructions for the LT4 Hotcam kit call for (0) ZERO lash plus 1/2 to 1 turn after. I used both the not running method of #1 TDC, adjust LASH to zero and turn crank 1/4 turn to adjust according to firing order there after as well as the running method of loosening to hear clack and than tighten until quiet plus 1/2 turn.
What about the 1 lifter pumping the heck out of oil. ? Is that a sign of a defective one. ?
Old 11-10-2008, 04:42 PM
JAKE
JAKE's Avatar
I prefer to use "Zero Pre-Load" just to avoid any confusion. But as long as you didn't actually set LASH with a feeler gauge, then we're on the same page.
Although you didn't say specifically, but did you make sure you established the lifter preload while the lifter was on the base circle of the camshaft lobe? That's an error that many make; setting the preload while the lifter is on the ramp of the cam lobe.
Any sign of rocker/retainer contact? How about the underside of the valve cover, any sign of valvetrain contact there?
If the lifter is collasped, it should be very easy to depress the plunger by pushing on the pushrod. Not sure why there's so much oil spraying there; I'll have to chew on that one a while.
Jake
To LT1 Hotcam Install , Valve clatter
Old 11-10-2008, 04:49 PM
Tuff96LT1
Tuff96LT1's Avatar
Lifter Pre-Load was set while at base of cam lobe.
No signs of any contact to the retainer or the valve cover. Also note the noise was not there the 1st 100 miles. Lifter is not collapsed and I cannot push the plunger by hand at all.
When inserting the lifters , which way do the oil holes face ?
Old 11-10-2008, 08:40 PM
MK 82
MK 82's Avatar
I didn't miss a thing. I am well aware of what lash is. You must adjust the rocker on a hydraulic motor to zero lash prior to turning further to set the preload. The 96 FSM says:
"ZERO LASH can be felt by moving the valve pushrod up and down between your thumb and forefinger until there is no more movement.
When all free play is gone, tighten the valve rocker nut 1 additional turn."
Jake
Old 11-11-2008, 03:10 AM
JAKE
JAKE's Avatar
There's a bit more to it that just that. You must first ensure that the lifter is riding on the base circle of the camshaft lobe. If it's anywhere else you won't have the correct position to establish ZERO pre-load/lash.
But I'm not going to spend any more of my time debateing this with you. I prefer to spend my efforts trying to help the original poster.
Jake
Quick Reply: LT1 Hotcam Install , Valve clatter
