Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-31-2008, 04:27 PM   #1
C4boy
CF Senior Member
C4boy's Avatar
Default Heater Control Valve Solution: 85-87 Corvette
I found a solution for the discontinued heater control valves for 85-87 Corvettes! A valve from an 82-84 full-sized Chevy is almost identical. The only difference is, the Chevy valve doesn’t have the long length of tubing, or a place to connect the coolant line that runs from the intake to the Corvette HCV.
The Corvette valve usually leaks from 2 seals in the valve and will drip around the screw. You'll find the main seal behind the screw will be all dried out.
C4boy is offline   Reply With Quote
Old 10-31-2008, 04:28 PM   #2
C4boy
CF Senior Member
C4boy's Avatar
Here are all your options:
1. You can rip out your heater control valve, replace it with heater hose, and cap off the line coming from the intake (if you have one).
2. You can replace it with another used valve from a boneyard or ebay, if you can find one and hope it doesn’t leak – About $50-80.
3. An aftermarket company is supposed to be making a new replacement valve. One website listed the price as $139. The original AC Delco was about $85.
4. If you don’t have a coolant line running from your intake, you can replace your old valve with the Chevy one and just run new heater hose. Everything will work perfectly.
5. If you do have a coolant line running from your intake and want to keep it - you could cut the tubing at your old valve, leave the rest of the plumbing, and connect the Chevy valve in line between the heater core and old coolant lines.
6. Or, you could rebuild yours for about $25! (insert Tim Allen grunt).
Removal Instructions:
1. Loosen all heater hose clamps from valve, remove mounting screw from wheel well, 1 nut on evaporator case, vacuum line attached to valve, and remove connector from AC switch (2 blade connector pulls straight back).
2. Slice heater hoses at heater core to valve lengthwise and slide a screwdriver in there to pry the hoses away from the heater control valve. Twist the hoses at the other end of the valve to loosen them and remove valve.
3. Slice the heater hoses on the heater core side and gently remove them. Measure the length and replace. They are 5/8” & 3/4" diameter.
Rebuild Instructions:
1. Try the disassembly procedure on your old valve first. Remove the screw and 1 piece of linkage from the vacuum actuator. Using a pair of cutting pliers, gently pry up the tabs on the bracket. Separate the bracket from the valve with a screwdriver. (I mixed and matched some of the pics from the new and old valve)
2. Pry the outer seal out with a screwdriver and pull out the plastic valve behind it.
3. With the plastic valve removed, you should be able to see another rubber seal inside the bottom of the housing. Using a screwdriver or a paper clip, make sure you remove all of the old seal. Scrape out the edge where the outer seal goes and clean up your old valve. Blow it out with compressed air or flush it with a garden hose. I also sanded my old valve & primed and painted it.
4. Now do the same disassembly procedure on the new Chevy heater valve and remove these 3 parts. 2 seals and the plastic valve. (You might be able to remove the plastic valve and actuator assembly from the heater control valve housing as one piece - without removing the small screw - but you won’t be able to pry the bracket off with a screwdriver. Unscrewing it lessens the chance of breaking the plastic valve).
Reassembly:
1. Place the new outer seal over the plastic valve.
2. Insert the new plastic valve into the vacuum actuator bracket. To attach the linkage, rotate the plastic valve until it lines up with the linkage. They are both shaped so that they only match one way. This ensures the valve goes back into the housing in the correct position. Replace the screw.
3. Slide the new valve assembly into your old housing. You may have to straighten the tabs a little to get the bracket to line up. Once it’s centered and in place, tap the tabs down with a hammer or a socket extension and a hammer.
Put the valve back in, warm it up and check for leaks. Done! You've got a brand new valve for $25.
©2008
Original heater control valve part #’s:
1985, 1986, 1987 Corvette heater control valve, hot water valve.
AC Delco - 15-5389
GM – 10120965
Replacement Chevy Valve Part #’s:
This valve fits several mid 80’s GM cars. I bought one from Advance Auto and it matched up perfectly. If you get one of the other brands, just make sure the tab cutouts line up to your old valve before you tear it apart. For a parts lookup you can use:
1982-1983 Chevrolet Malibu V6-229 3.8Lw/Gauges (4 Port valve)
1982-1984 Chevy Full Sized – V8 305 w/Gauges (4 port valve)
ReadyAir – 5935 (Autozone brand)
Four Seasons - 74800
Factory Air – 74800 (Advance Auto brand)
AC Delco - 15-5302
Heater Hose Sizes:
Heater core inlet: 5/8” (upper tube)
Heater core outlet: 3/4" (bottom tube)
(first person to quote this post gets a bitch slap )
Old 10-31-2008, 07:34 PM   #3
car5car
CF Senior Member
deleted
car5car is offline   Reply With Quote
Old 10-31-2008, 07:44 PM   #4
Benny42
CF Senior Member
Benny42's Avatar
Nicely done. Thanks for the part #s and pics. Its on project
list now. benny
Benny42 is offline   Reply With Quote
Old 10-31-2008, 10:22 PM   #5
Redeasysport
CF Senior Member
St. Jude Donor '05-'06
Redeasysport's Avatar
Send a message via AIM to Redeasysport
And why do you need it the LT1's just have a "T" in that spot?
Redeasysport is offline   Reply With Quote
Old 10-31-2008, 11:27 PM   #6
H P Bushrod
Moderator
CI 5-6-7-8-9-10-11-12 Veteran
St. Jude Donor '09-'10-'11
H P Bushrod's Avatar
Send a message via AIM to H P Bushrod
Informative article, C4boy. Thanks for sharing!
H P Bushrod is offline   Reply With Quote
Old 11-01-2008, 07:51 AM   #7
Joe C
CF Senior Member
Joe C's Avatar
Location: half way between Uniontown and Hartville in rusty old Ohio
good work, but are you sure the original heater valve has been discontinued?
http://www.acsource.net/xcart/home.p...=0&page=2&js=n
scroll down to...
SKU: Control Parts for 1987 Chevrolet Corvette (5.7 V8 Gas FI)
Valve; Heater Control
AC Shut Off
SKU: 24606-P/N: 15-5389
Auto AC Parts
Joe C is offline   Reply With Quote
Old 11-01-2008, 09:10 AM   #8
AGENT 86
CF Senior Member
AGENT 86's Avatar
Nice write up, C4boy !!
AGENT 86 is offline   Reply With Quote
Old 11-01-2008, 09:11 AM   #9
AGENT 86
CF Senior Member
AGENT 86's Avatar
Quote:
Originally Posted by car5car View Post
Valve from some Dodge. $13 new in stock in Advance auto
Wasn't that a FAIL !! Or did you get it working ??
Old 11-01-2008, 10:46 AM   #10
car5car
CF Senior Member
deleted
Old 11-01-2008, 02:30 PM   #11
C4boy
CF Senior Member
C4boy's Avatar
scroll down to...
AC Shut Off
Auto AC Parts
Joe, I called AC Delco a while back and they were the ones who told me it was discontinued. I think you gave me that link to AC Source about a year ago - thanks. I called and spoke to the guy there and he said he had several calls on the part #. He can't get it. The catalog system he uses still has the Delco part # in its database, but he can't remove the listing or get the part.
Old 11-01-2008, 03:46 PM   #12
Pete K
CF Senior Member
Pete K's Avatar
Thank you very much for this thread.
Threads of this type were the reason I joined the vette forum years ago, and they are few and far inbetween these days.
Great job
Pete K is offline   Reply With Quote
Old 11-01-2008, 06:26 PM   #13
Joe C
CF Senior Member
Joe C's Avatar
Quote:
thanks for that info - i'll file your original rework intructions for future reference. don't have my 85 anymore, but my son has taken ownership - never know when we'll need it...
Old 11-02-2008, 03:21 PM   #14
Joe C
CF Senior Member
Joe C's Avatar
...just got a NOS AC Delco heater control valve, p/n 15-5302 on ebay for $26. don't need it now, so it will go into the parts stockpile for future use. again, thanks for the info C4boy!
Old 11-13-2008, 07:49 PM   #15
C4boy
CF Senior Member
C4boy's Avatar
great idea Joe.
And thank you very much Pete.
Old 11-13-2008, 07:58 PM   #16
engle1147
CF Senior Member
Support Corvetteforum!
engle1147's Avatar
Send a message via AIM to engle1147
Well done - great post! I think you became a C4MAN!
engle1147 is offline   Reply With Quote
Old 11-14-2008, 10:56 AM   #17
Kevin@KeenParts.com
Premium Supporting Vendor
Kevin@KeenParts.com's Avatar
Send a message via Skype™ to Kevin@KeenParts.com
Check out my other post. We are in the process of making a reproducttion right now and a re looking for a tester with preferably an 85 to try it out.
http://forums.corvetteforum.com/c4-p...l-for-you.html
Kevin
Keen Parts
Kevin@KeenParts.com is offline   Reply With Quote
Old 02-13-2010, 03:43 PM   #18
Orphen1987
CF Member
Orphen1987's Avatar
This is great I just did mine and it works perfectly. Another part # for the one I got at NAPA was 660-1225.
Orphen1987 is offline   Reply With Quote
Old 02-13-2010, 03:54 PM   #19
Kevin@KeenParts.com
We have the reproductions valves in stock now if anyone is interested in one.
Kevin
www.KeenParts.com
800-757-5336
Old 02-14-2010, 01:12 AM   #20
C4boy
CF Senior Member
C4boy's Avatar
Or you can find original valves cheaper on ebay.
Reload this Page Heater Control Valve Solution: 85-87 Corvette
Tags
1986, 1994, 85, 86, 87, c4, chevy, corvette, cut, delco, heater, hot, part, valve, water
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
