The NEW Official Timeslip Thread
Updated 8/22/11
Notice to all CF C4 owners and drivers:
I've volunteered to take over the administration of this list for the group. I've updated it as of the last page posted in the original thread here. I'll continue to update the list as frequently as needed to keep it current.
Post your best times, and your trap speed and 60ft for that run, and density altitude of the air if you know it.
List your year, mods, gearing, and transmission, or you may not be added to the list.
And if you 1/4 mile guys could put some 1/8th mi info up, the rest of us without full tracks would be very grateful. You can also post your older best times with previous setups. My intent is that people can use this as a general reference on what to aim for with certain setups.
1/4 MILE, 11's and faster
1/4 MILE, 12's
1/4 MILE, 13.0-13.5
1/4 MILE, 13.5 and slower
1/8 MILE
CAI: cold air intake
DRs: drag radials
elims: muffler eliminators
LTs: long tube headers
RRs: roller rockers
SR: SuperRam intake
TC: torque converter
Code:
ET MPH 60ft D.A. CAR MEMBER MODS 8.3 @169 1.30 86 A2 3.73 tensecvet Bammann 565ci, Carrolls Rod & Racecraft Bolt-in rear, glide, some rims & 350 shot 9.34 @153 1.82 87 M6 3.45 AKS Racing 408cid , AFR215s, 248/254 @ 0.050 SR cam, SP intake, MB, D1R, FAST sequential, ZF 9.54 @139 1.28 90 A2 4.56 hookedup 420, carbed, PG 9.80 @135 1.54 92 A4 3.50 rwisk 346ci LS1, Melrose swap headers, 4l60e trans, 3600 stall, forged motor with d1sc procharger@14lbs of boost, Carrolls rod and racecraft straight axle rear with 28" et street radials 9.82 @148 1.54 92 M6 3.73 97AGGIE 383, 250shot direct port, custom cam, AFR 190s, 58mmTB, 36# inj, spec stg5 clutch, LTs, 3in exh 9.88 @137 1.34 93 INSANITY 434, NA, turbo 350, solid rear 9.90 @132 1.42 95 A2 dr.juice 383, 200 shot NO2, Powerglide, 28x10x15 Goodyear slicks 9.91 @140 1.43 86 A4 3.92 REDC4CORVE 434ci, 1050 Holley, CompCams 325, 125 shot, DRs 10.04 @138 1.47 92 A4 3.50 rwisk 346ci, Melrose headers, 4l60e trans, 3200 stall, forged motor with d1sc procharger@14lbs of boost, Carrolls rod and racecraft straight axle rear with 28" et street radials 10.06 @135 1.39 84 A4 ???? vetjack 406 sbc on 175 shot 10.14 @137 1.43 95 M6 3.70 dr.juice 377ci, 9.5:1, 250shot, M&H slicks, AFR/TPIs heads, LT4 intake, LTs, 3" exh, Spec clutch, 4-link 9in, CCW drag pack 10.15 @134 1.37 89 A3 3.73 ski_dwn_it 434ci, 11.5:1, M/T slicks, m2race brodix t1 heads, single plane, 3" ex, 8" TC 10.16 @137 1.42 89 A3 3.73 ski_dwn_it 434ci, 150 shot, 3000 stall. 11.5:1, M/T slicks, m2race brodix t1 heads, single plane, 3" ex, 8" TC 10.27 @131 1.41 85 A4 3.07 CORKVETTE1 434ci, 11.5:1, solid roller, 4200 TC, single plane, monoblade TB, brodix t1 heads 10.33 @139 1.65 85 A4 3.31 SloRvette 398ci 4000 stall, Canfield heads, 242/254 sr cam, Hooker 2151 headers, dual 3" exhaust, XFI, StealthRam, .024" jets in dry fogger, SRA Performance trans 4L60e full manual, Pro Torque 4500 stall non lockup 10.36 @136 1.52 +6800' 91 M6 3.70 tpi421vett 450ci AFR220's, Miniram, Crane 252/260 solid roller, FAST, 200 shot NOS, ZF6, 3.70 9" 10.44 @133 1.53 +4400' 91 M6 3.70 tpi421vett 421 bowtie block, ported miniram2, AFR220s, NOS, comp mech roller cam, monoblade TB 10.53 @131 96 M6 4.10 d48mclain 398ci, stepped headers, ported TFS heads, monoblade TB, sheetmetal intake 10.53 @127 1.42 500' 84 A4 4.33 383vett 406ci, Cola crank, JE Pistons, Crane cam, Holley heads, SuperRam, 4L60e tranny, Strange 12-bolt 10.55 @133 1.55 83 A4 3.54 dan0617 383, 12.2 compression, 230/236 cam, AFR195's, HSR intake, 200 shot, 2800 stall, built 700R4, ET Street radials 10.72 @149 1.62 90 A4 3.33 SloRvette 398ci 4000 stall, Canfield 197's, 242/254 sr, Hooker 2151 headers, dual 3" exhaust, 58 TB, StealthRam, 100 shot dry plate, FAST XFI 10.75 @128 96 M6 4.10 jonecap LT4 hotcam, 4.10's, headers, exhaust, ewp, Centerforce clutch, 150 shot nitrous 10.83 @134 1.82 +1200' 90 M6 3.91 mos90 396 solid roller, slicks, 250shot, mcleod RichS clutch, FAST xfi 10.89 @121 1.49 96 A4 3.75 RichS 396ci, DRs, morgantini heads, ported LT4 heads/int, 3600 TC, CompCam, DRM LTs, 58mm tb 10.90 @126 1.49 +2100' 86 A4 3.33 REDC4CORVE 434ci, MT streets, 1095 barry grant carb, LT4 exh, 10.93 @126 86 3.45 _TWISTED_ 383, TPIS MiniRam w 58mm TPIS TB, N2O, PeteK 700r4 build, D44, Hooker Headers w/ custom 3" exhaust into SpinTech's 10.97 @124 1.51 87 Pete K 10.98 @122 1.53 85 3.45 IHRA221 383 spool 11.01 @123 1.42 93 INSANITY 396 11.02 @126 1.60 96 M6 3.75 RichS 396ci, DRs, morgantini heads, ported LT4 heads/int, CompCam, DRM LTs, 58mm tb 11.05 @123 1.60 90 SloRvette 11.14 @126 1.72 84 A4L JoBy Garret turbo, I/C, DRs, Stealth Ram, AFR 190s, Comp 12-404-4, LTs 11.21 @122 1.56 +2200' 94 A4 REDC4CORVE 125shot, 2600 TC, Comp cam, 1.5/1.6RRs, beehive springs 11.25 @119 1.55 +1600' 86 A4 3.73 Gold1986Ve 420ci, 11.3:1, SR 248cam, ported Miniram, 3500 TC, AFRs, LTs, DRs, exhaust 11.26 @123 1.58 +800' 95 A4 3.73 PDQUIK95 396 lt4 stroker, AFR 195s,Hyd.230/236 cam,58mm T.B., 36lb.inj., 2800 stall Dana 44, DR's. 11.31 @120 1.52 85 A4 4.10 85C4sX2 TFS 195 heads, TPIS MINI RAM, 58mm Throtle Body; TPIS ZZ9X HYD ROLLER CAM; ROSSLER 700 R4; 4000 stall TPIS HEADERS & CAT BACK SYSTEM; MT ET STREETS 11.32 @120 1.52 -200' 89 A4 3.73 Vic '89 Stock 350 bottem end, Ported 113 heads, ZZ9 Cam, Dana 44 11.37 @123 1.66 -500' 91 M6 3.90 neat 383, AFR heads, 230/236 cam, miniram, Mseven tune, nitto DRs, NA 11.55 @116 1.53 -90' 92 A4 3.33 MTVette 383 LT1, custom cam. ported heads & intake, LT's, 2600 TC, MT ET Street DR's 11.55 @123 2.1 85 M6 3.07 Killer408 drag radials, 406 sbc, afr heads, super ram intake, long tube headers, Mcleod street pro clutch, Accel efm (base tune) 11.57 @119 84 A4 3.08 NXS 9.5 compression, 230/230 cam, 70mm turbo 6 psi, street tires, full exhaust, pump gas 11.59 @117 1.66 91 A4 3.45 twin540 383 stroker afr 195 eliminator, LT1 intake conversion 503 cam built tranny with 5 pinion planetary front/ back. 3.45 dana 44 9.5" 3000 stall converter on 315 mt et drag radials 11.61 @119 1.76 +1600' 93 steve40th 425 rwhp 417 ft/lbs tq 11.62 @122 1.78 86 TKO ol,RJ 406ci solid roller, victor E intake, brodix heads, 246/.542cam, LTs, tune, Toyo RA1 11.64 @105 1.57 93 A4 3.73 93lt1fun 396 stroker LT1, GM 846Cam, ported LT1 heads, 52mm throttle body, Meziere water pump, TPiS LT headers, RT cats, 3500 stall Vig TC, MT ET Street DR's 11.71 @117 1.69 93 A4 4.09 93 ragtop MT et DRs, 3000 TC, hotcam, ported heads, LTs, elec wp, pcmforless tune 11.77 @114 1.67 86 A4 3.07 jd_v3tt3 150shot, BFG DRs, LTs, elims 11.79 @118 1.56 983' 93 A4 3.73 1989TTATony 383 LT1, 2800 TC, MT DRs, 1.6RR, Corsa cat-back, PCM4less tune, LE2 ported heads, custom cam 11.87 @113 1.68 95 A4 3.73 ckp D36,3000 TC, 30lb Ford racing injectors, Bottom feeder air induction, Pro Flow XT intake, Wilson 90mm TB, Headers, Stock mufflers, skinnies and cheater slicks 11.89 @120 1.9 96 A4 3.07 Dan Parker 75 shot, Nitto DRs, 3000 stall, LE2 heads/cam, EM LTs 11.94 @116 1.67 93 A4 4.10 BlackRoseL 2800 TC, stage2heads, hotcam, EM LTs, B&B exh, ported LT1, Alvin tune
Code:
ET MPH 60ft D.A. CAR MEMBER MODS 12.03 @116 1.67 50F 96 A4 3.73 vettestir1 LT4 hot cam, mez ewp, 2800 stall, 52mm tb, cai, DR's and a few minor bolt on's 12.05 @115 1.76 96 M6 4.10 jonecap DRs, EM LTs, R/T cats, catback, tune 12.08 @116 1.94 90 M6 3.73 adi4 383, miniram, 224/234 cam, 1.52 RRs, trickflow 195s, 54mm TB, EM LTs, RT cats, Corsa, alum fw, MSD 12.08 @112 1.63 95 A4 3.73 cheetah Headers,TC,coilovers,Eradispeed Plus rotors,CompCam,Lingenfelter headwork,PCMforLess(ish) tune, homebuilt ramair, 52mm TB,bullet cats,x-pipe thru stock mufflers, 30lb Ford injectors, adj. Camaro fuel pressure reg 12.13 @120 1.93 86 TKO ol,RJ 406ci solid roller, miniram, brodix heads, 246/.542cam, LTs, tune 12.19 @108 1.62 80F 86 A4 2.73 vetster86 Paxton SC 6psi, 2800 TC, SuperRam, LTs, 214/224 cam, 2.0/1.55 valves, 1.6RRs 12.19 @114 1.76 96 M6 4.10 jonecap LT4, DRs, catback, tune 12.22 @112 1.74 96 A4 3.45 Weav's Vet LT1 226/230 .565.565, 111lsa Bullet cam, 1.6 Comp Cams full rollers, stock heads, 30lb FMS injectors, Cloyes DR timing chain, 52mm BBk throttle body, Dana 44, 2800 stall, ZFDoc's beam plates, K&N, 160 stat, EWP, M/T ET Street DR's 12.23 @111 1.69 83' 92 A4 3.73 reoch999 CC503 cam, 1.6RR, Flowmasters, 3000TC 12.24 @116 1.96 96 A4 3.54 fredk 190 AFRs, ZZ9cam, EM LTs, claw intake, 1.6RRs, Autoworx tune 12.24 @116 1.96 96 M6 3.45 tpivette LT4, hotcam, cut lid, elims, port matched intake, 5-angle valve job, tune 12.25 @112 1.84 90 M6 j-stingray 355 cu in, nitrous, lingenfelter intake, 58mm TB, hypertech chip, 1.6 RR, hooker headers, flowmaster catback 12.27 @111 1.77 94 A4 3.45 blue94 AI ported Heads, 565 lift 110 LSA, 2800 Stall, LTs, MT ET's, D44 12.28 @110 1.65 -460' 96 A4 3.73 Red96Coupe BFG DRs, 1.6RR, 160stat, Hypertech, 3500 TC, elims, skinny fronts and Weld Pro Star wheels 12.31@112 1.87 88 A4 3.07 Aardwolf Ram air intake, K&N, free mods, ported MR, ported head, TPIS headers, March under drive pulleys, dual exhaust with H-pipe, street tires, KWD 12.34 @109 1.74 89 A4 3.07 dustmann 383, ATI supercharger w/8 PSI boost, ported intake & heads, comp cam, MSD ignition, Nitto DR's 12.34 @113 1.82 0' 90 M6 3.33 bogor vortech s/c 8psi, ET streets superram, mild cam, LTs, 52mm TB, Autotronic SMC 12.37 @115 89 M6 3.33 vette punk 383, Superram, DRs, 1.6RRs, pulleys 58mm TB, LTs, 3.5" ex, chip, SLP cai, LPE 219 cam, AFR 190s 12.41 @109 1.87 0' 91 M6 4.09 neat 100shot, ET streets, Hooker LTs, catback 12.42 @114 1.97 96 M6 4.09 Dr. Evil hotcam, catback, K&N+cutlid 12.43 @117 1.79 90ZR1 MFS hooker mufflers 12.49 @108 1.63 91 A4 3.33 TA stock heads/cam, 2500 TC, LTs, accel intake, asm runners, 1.6RRs 12.50 @108 1.67 93 A4 3.45 Mr Mojo 2800 TC 12.51 @107 1.68 +800' 92 A4 3.33 MTVette M/T DRs, 2600 TC, LTs, hotcam, chip, 1.6RRs, RT cats, Xpipe 12.58 @114 2.17 85 M6 3.45 LD85 406ci, AFR 210s, Miniram 12.62 @109 1.85 96 M6 1stvette94 BFG DR's 1.6RRs, Meziere 12.62 @110 84 A4 3.07 NXS 350 dishtop, ported vortecs heads, airgap intake, 2.5" exhaust with x-pipe, toyo tires, ac delete 12.63 @111 2.01 96 A4 Legion21 SLP cai, LTs, 3" exh, nitrous, mallory hyfire VI 12.65 @114 95 M6 gears hotcam, ported heads, ed wright chip, 52mmTB, tpis LTs, catback, vortex rammer 12.66 @108 1.83 100F 90 skateparkd M/T DRs, Hooker LTs, Monza muffs, Catless, 125shot, Jet Perf stg 2 chip, 160stat, Manual Fan Switch, Tossed frisbee 12.68 @108 1.86 89 A4 Chance 383(8.7:1), superram, port+polish TFS heads, transgo shift, true duals 12.72 @107 1.77 94 A4 3.55 GS4-LT1 ZZ-409 TPIS Cam, TPIS 52mm TB, 1.6 RR, TPIS AFPR, 3000 stall converter, Dana 44, Hoosier 315 DR's. Stock heads, intake, fuel pump and injectors. 12.74 @110 1.96 96 M6 3.91 C4DC LT4 CE K&N w/ cut lid, SS Works LT headers, RT cats, Corsa, Hurst, Camber Brace, ZF Beam Plates, Z51 HO shocks, Poly rear end/swaybars 12.76 @104 1.80 87 A4 3.54 stauger 383 LPE 12.81 @113 2.10 +2300' 88 3.73 88espo 358ci carb 12.83 @107 1.84 87 A4 3.07 SpankYello 180cc intake heads, Miniram, ZZ4 cam, LTs 12.85 @106 1.90 89 M6 3.33 Razor89 nitto DRs, ZZ9 cam, ported heads, LTs, catback, bigmouth, LT runners, ported plenum, cai, 52mmTB, stageVchip 12.87 @109 1.87 92 A4 2.59 04gtogoat Hotcam, 1.6R, full exhaust catless, elims, power coupler, MSD blaster, 30# injectors, stock block, convertor, & tune 12.89 @111 2.09 93 M6 4.09 DieL 1.6RRs, pullies, crane hi-6, accel u-groove plugs, Watson headers, no cats 12.89 @106 1.74 1702' 93 A4 3.07 1989TTATony 2800 TC, MT ET Streets, 1.5RR, Corsa cat-back, PCM4less tune, K&N w/cut air lid 12.90 @105 1.73 89 A4 3.07 HeeHaw89 355, LPE/Accel base, LPE 219, AS&M LTR, ported plenum, ProMag 1.6's,Hooker 2149's, 24lb inj, Holley AFPR, Magnaflow cat, LT1 mufflers, Vigilante 2600, B&M cooler, Nitto dr's, free mods 12.91 @110 2.09 96 M6 4.09 Dr. Evil hotcam, catback, K&N+cutlid 12.93 @107 2.00 94 M6 pr1mu5 DRs, centerforce clutch, no muffs, no spare tire 12.95 @107 1.93 96 M6 ubnpast DRs, SLP intake, flowmasters 12.95 @108 84 elkabong rollerblock w/ Eagle internals, trickflow heads, 10.4:1, Comp XR269 cam, 1.6RRs, X-Ram, EM LTs, 7747 ECM 12.95 @108 1.99 89 M6 3.54 89sleeper M/T streets, 383 GMPD short block, edelb heads, TPIs: 409 cam, Miniram, LTs, prom 12.98 @108 2.20 87 A4 2.59 CRV3TT3 Paxton S/C, exh, M/T DRs 12.98 @108 2.12 91 M6 3.64 sebaj 355 Miniram, Edelbrock heads, Hotcam, 1.6RR, Alvin tune, Bridgestone tires12.98 @102 1.78 68F 87 A4 3.07 rodj M/T DRs, 2000 TC, ZZ4cam, SLPrunners, ported TPI, 58mmTB 12.99 @107 1.95 -500' 95 M6 3.45 Mr Mojo no muffs 12.99 @104 1.77 86 A4 3.07 jd_v3tt3 BFG DRs, LTs, elims, stock iron heads 12.99 @101 1.70 87 A4 2.59 JimMcCombe 377 stroker, Edelbrock heads, Crane cam, 2500 stall TC, 52mm TBK TB, Goodyear Eagles
Code:
ET MPH 60ft D.A. CAR MEMBER MODS 13.00 @107 1.95 94 M6 pr1mu5 DRs, centerforce clutch, no muffs 13.01 @107 1.97 94 M6 3.45 1stvette94 DRs, 1.6RRs, meziere 13.02 @107 1.90 92 M6 3.45 STEVEN13 Stock with Tri-Y LT headers, 1.6 Rockers, Tune, Toyo 888 scrub road race tires 13.04 @106 1.96 91 M6 4.10 neat LTs, catback, 1.6RRs, tune 13.07 @108 2.07 -2150' 95 M6 3.45 Mr Mojo stock 13.07 @105 1.96 92 A4 3.07 C4Crazy787 2800 TC, hotcam, 1.6RRs, EM LTs, 52mmTB, NP chip 13.07 @102 1.83 -400' 88 A4 2.59 65Z01 TC, SLP cai, 52mm TB, ported plenum, no precats, cat&back, 1.6RRs 13.10 @109 2.06 +500' 93 M6 3.45 mn_vette iron heads, no cats, mez, 58mmTB, 230/236 cam 13.11 @108 1.91 90 M6 jonecap DRs, TPIs intake+chip+runners, 1.6RRs, catback, no cats, pulleys 13.11 @107 1.90 87 A4 3.07 SpankYello 180cc intake heads, Edelbrock base, TPIS runners, ZZ4 cam, LTs 13.14 @106 1.97 89 M6 3.33 black_89_v 383, Superram, LTs 13.14 @107 1.97 96 M6 Jack_lt4 flowmaster 13.14 @103 1.91 89 M6 3.33 Z51L9889 ported 113s, no precats, cat&back, portedTPI 13.17 @104 1.99 -400' 88 A4 2.59 65Z01 SLP cai, 52mmTB, ported plenum, no precats, cat&back, 1.6RRs 13.18 @103 1.79 +600' 93 A4 3.73 Fuzzy Dice Nitto DRs, LTs, 3200 TC 13.21 @103 2.03 +1100' 93 A4 3.45 James93LT1 hotcam, LT4heads, 1.6RRs, slp shorties 13.22 @108 2.00 85 A4 3.07 JohnMarker ZZ4, LPE 74211 cam, AFR 180 heads, SuperRam base, 52MM TB, March pulleys, AFPR, Accel injectors, Walbro FP, 1.6 RR, chip by TJWONG, TRANSGO shift kit, 2400 stall 13.22 @107 1.95 +2771' 92 A4 2.59 04gtogoat hotcam, 1.6RR, CC full exhaust catless, eliminators, power coupler, MSD blaster, 30LB injectors 13.23 @107 2.12 94 M6 1stvette94 stock 13.25 @111 2.6 96 A4 3.07 Dan Parker LE2 heads/cam, EM LTs 13.29 @108 2.21 -2150' 94 M6 3.92 DaveT just gears 13.29 @105 2.04 89 3.07 kopbet89c4 miniram, no cats, chip, 24# inj, no MAF 13.32 @109 2.21 -2150' 95 M6 3.45 Mr Mojo stock 13.34 @ 99 1.82 85 black85 LTs, catback, pulleys, ported TPI 13.3 @106 2.0 87 M4 3.07 TUNED87vet 1000cfmTB, ported plenum, bigmouth base, AFRs, TPIS cam, LTs, cat+back, tune 13.37 @102 1.95 93 A4 Mr Mojo stock 13.38 @104 1.94 60F 95 A4 3.07 pettvette 13.38 @107 2.06 86 PaulRugger factory aluminum head, 1.6 roller rockers, MSD ignition, Toyo R888 tires 13.4 @108 2.19 +1500' 90ZR1 4.10 cuisinartv 3" exhaust, Haibeck chip, meth injection 13.45 @102 1.86 1200' 89 A4 3.74 Red98C5 D44 - Hedman Hedrs - Flowmaster 40 Series - BFG 275/18 13.47 @101 1.95 93 4.10 Driftmonst LTs, chip, borla exh 13.49 @102 1.94 92 A4 3.54 mcnulty95 shift kit, elims
Code:
ET MPH 60ft D.A. CAR MEMBER MODS 13.50 @101 1.90 94 A4 3.07 LilRedCorv Borlas, 160 tstat, 2400 stall 13.50 @101 1.99 -500' 88 65Z01 13.53 @103 95 M6 3.45 95_6spdvet 13.54 @107 2.24 +2445' 91 M6 neat 100shot, Hooker LTs, catback 13.60 @102 1.95 +2200' 94 A4 REDC4CORVE 2600 TC, Comp cam, 1.5/1.6RRs, beehive springs 13.61 @ 99 2.09 85 A4 3.07 JohnMarker AFR 180s, SR, RRs, tjwong chip, MSD, transgo shift kit, cust exhaust, pulleys, no cat 13.6 @102 89 GIJoe no cats, TBswitch, no smog, hypertech, 160stat, 13.67 @104 2.20 91 M6 3.45 Yorcci stock mufflers, street tires. K&N air filter with open lid, EGR removed, A.I.R. pump gutted, frisbee removed, throttle body coolant bypass, dual exhaust without precats 13.70 @101 2.06 +1235' 94 A4 Drug Deliv stock 13.70 @104 2.05 +1000' 95 M6 3.45 SHINOBI-X B&M shifter, Xpipe, elims 13.75 @ 99 2.03 +2276' 89 A4 3.07 gigaglytch 2100stall, LTs, no cats, catback 13.76 @102 2.10 86 M4 3.07 PaulRugger LTs, an SR a K+N and underdrive pulleys. 13.78 @101 1.99 +600' 88 M4 3.07 88BlackZ51 Nitto DRs, Hooker LTs+Y, cat&back, K&N+lid 13.79 @100 2.00 +1000' 85 M6 3.45 CentralCoa M/T DRs, SLP cai, elims, cat&back 13.86 @ 99 2.11 +7000' 92 M6 3.45 TOM400CFI Stock 13.87 @104 2.15 92 M6 3.45 FalsusNomen airbox lid 13.87 @ 97 1.95 87 A4 CRV3TT3 catback 13.89 @ 99 1.97 90F 86 A4 JrRifleCoa MSD, catback, Alvin chip 13.90 @ 98 1.97 +600' 87 A4 3.07 87 rag 1.6rollertips, Borla catback 13.90 @ 99 2.0 90 M6 3.45 MATCHLIGHT catback, fan switch, 180stat 13.91 @102 2.24 +1500' 88 M4 3.07 88espo 327ci, 461 heads 13.91 @ 99 2.11 +2445' 91 M6 neat Hooker LTs, catback 13.92 @ 98 2.01 88 A4 3.07 popkid Stock L98 with Pypes Dual Exhaust with x-over, no Cats 13.93 @ 99 2.07 85 M4 3.07 rel3rd pulleys, hiflow cat 13.93 @ 98 1.93 104F 85 A4 3.73 krenalor Ram air, stock motor, B&M TH700R4, TPIs cat back, Flowmasters, MT Sportsman tires 13.96 @ 99 2.01 +950' 89 M6 3.33 Z51L9889 stock 13.98 @ 99 1.86 86 A4 2.59 zbo2 bone stock, street tires 13.98 @ 97 1.99 87 A4 RS69 K&N, modified cats, ultaflow mufflers 14.02 @105 2.30 96 M6 3.45 ALLT4 bone stock LT4 14.04 @ 99 1.96 93 A4 2.59 MFS 2400 stall 14.09 @ 98 2.11 88 A4 3.07 popkid stock, street tires, Pypes exhaust system 14.13 @ 98 1.99 85 A4 3.07 JohnMarker AFR 180s, SR, RRs, tjwong chip, MSD, transgo shift kit, cust exhaust 14.14 @ 95 1.93 85 A4 rickhiggin bone stock 14.16 @ 93 1.88 1709' 87 A4 2.73 Lemme T Headers, Shaved Heads, Stg 2 shift kit, 2600 TC, A/BOX Lid, power pipe, TB Bypass, airfoil, MAF gauze removed, K&N, AIR delete, precats delete, EGR delete, custom 89 ARAP bin 14.27 @ 99 85 A4 3.07 L98/Z51 L98 TPI ADS Stage 1 Super Chip, K&N Filter, airfoil, removed screen 14.33 @ 97 2.13 86 Agent 86 no cats, no smog, magnaflow exhaust 14.36 @ 98 2.27 85 M6 3.01 dclafleur bone stock 14.44 @ 97 2.18 87 M4 Mr. Dude lowered, bilstein shocks, borla high flow mufflers with true dual straight pipes, newer control arms, newer bushings, newer tie rods, K&N filter 14.46 @ 94 2.16 91 A4 2.59 1991 C4 B&B exhaust 14.47 @ 94 2.03 +2710' 89 A4 3.07 cuisinartv catback 14.63 @ 95 2.16 86 A4 3.07 KnightVett catback, K&N, (stock 86L heads) 14.7 @ 92 84 A4 3.07 xrcrx cai, RRs
Code:
ET MPH 60ft D.A. CAR MEMBER MODS 6.02 @111 1.28 90 A2 4.56 hookedup 420, carbed, PG 6.40 @105 1.39 84 A4 ???? vetjack 406 sbc on 175 shot 6.45 @116 1.54 92 M6 3.73 97AGGIE 383, 250shot direct port, custom cam, AFR 190s, 58mmTB, 36# inj, spec stg5 clutch, LTs, 3in exh 6.52 @131 1.41 85 A4 3.07 CORKVETTE1 434ci, 11.5:1, solid roller, 4200 TC, single plane, monoblade TB, brodix t1 heads 6.64 @107 1.37 89 A3 3.73 ski_dwn_it M/T slicks, 434ci 11.5:1 compression, m2race system brodix t1 227cc heads, Single plane intake, 30# injectors, 3" exhaust, m/t front runners, turbo350 auto, 8" race converter 6.68 @105 1.47 +7000' 91 M6 3.70 tpi421vett 450ci AFR220's, Miniram, Crane 252/260 solid roller, FAST, 200 shot NOS, ZF6, 3.70 9" 6.73 @104 1.51 91 M6 3.70 tpi421vett 421 bowtie block, ported miniram2, AFR220s, NOS, comp mech roller cam, F.A.S.T., monoblade 6.79 @102 1.55 83 A4 3.54 dan0617 383, 12.2 compression, 230/236 cam, AFR195's, HSR intake, 200 shot, 2800 stall, built 700R4, ET Street radials 6.82 @103 96 M6 4.10 d48mclain 398ci, stepped headers, ported TFS heads, monoblade TB, sheetmetal intake 6.91 @ 98 1.49 96 A4 3.75 RichS 396ci, DRs, morgantini heads, ported LT4 heads/int, 3600 TC, CompCam, DRM LTs, 58mm tb 6.99 1.53 85 3.45 IHRA221 383 spool 7.01 @108 1.82 +1200' 90 M6 3.91 mos90 396 solid roller, slicks, 250shot, mcleod clutch, FAST xfi 7.10 @ 98 1.60 96 M6 3.75 RichS DRs, 396ci, morgantini heads, ported LT4 heads/int, CompCam, DRM LTs, 58mm tb, 421hp/412tq 7.22 @ 92 1.52 85 A4 4.10 85C4sX2 TFS 195 heads, TPIS MINI RAM, 58mm Throtle Body; TPIS ZZ9X HYD ROLLER CAM; ROSSLER 700 R4; 4000 stall TPIS HEADERS & CAT BACK SYSTEM; MT ET STREETS 7.24 @ 93 1.58 86 A4 3.73 Gold1986Ve 420ci, 11.3:1, SR 248cam, ported Miniram, 3500 TC, AFRs, LTs, DRs, exhaust 7.30 @ 97 1.69 92 A4 3.73 qwiketz 383 with vortech t trim, auto, Stock converter 7.30 @ 91 1.54 -90' 92 A4 3.33 MTVette 383 LT1, ported heads & intake, LT's, 2600 TC, DR's 7.31 @ 94 1.55 93 A4 3.73 93lt1fun 396 stroker LT1, GM 846Cam, ported LT1 heads, 52mm throttle body, Meziere water pump, TPiS LT headers, RT cats, 3500 stall Vig TC, MT ET Street DR's7.44 @ 93 1.76 +1600' 93 steve40th 425 rwhp 417 ft/lbs tq 7.35 @ 98 1.66 -500' 91 M6 3.90 neat 383, AFR heads, 230/236 cam, miniram, Mseven tune, nitto DRs, NA 7.38 @ 93 1.71 91 A4 3.45 twin540 383 stroker afr 195 eliminator, LT1 intake conversion 503 cam built tranny with 5 pinion planetary front/ back. 3.45 dana 44 9.5" 3000 stall converter on 315 mt et drag radials 7.49 @ 88 1.56 983' 93 A4 3.73 1989TTATony 383 LT1, 2800 TC, MT DRs, 1.6RR, Corsa cat-back, PCM4less tune, LE2 ported heads, custom cam 7.52 @ 92 1.67 86 A4 3.07 jd_v3tt3 150shot, BFG DRs, LTs, elims 7.53 @ 92 1.69 93 A4 4.09 93 ragtop M/T et DRs, 3000 TC, hotcam, ported heads, LTs, elec wp, pcmforless tune 7.55 @ 94 1.78 86 TKO ol,RJ 406ci solid roller, victor E intake, brodix heads, 246/.542cam, LTs, tune, Toyo RA1 7.58 @ 91 1.68 95 A4 3.73 ckp D36,3000 TC, 30lb Ford racing injectors, Bottom feeder air induction, Pro Flow XT intake, Wilson 90mm TB, Headers, Stock mufflers, skinnies and cheater slicks 7.67 @ 88 1.67 93 A4 4.10 BlackRoseL 2800 TC, stage2heads, hotcam, EM LTs, B&B exh, ported LT1, Alvin tune 7.70 @ 87 1.62 80F 86 A4 2.73 vetster86 Paxton SC 6psi, 2800 TC, SuperRam, LTs, 214/224 cam, 2.0/1.55 valves, 1.6RRs 7.72 @ 89 1.7 84 A4 3.73 calpbs 383 carb, cam, dart pro 1's,11:1 compression, lightened rotating assembly, 3600 stall, 700r4, a-mod 315-35-17's, Street tires 7.76 @ 1.78 96 M6 4.10 jonecap DRs, EM LTs, R/T cats, catback, tune 7.78 @ 87 1.69 83' A4 3.73 reoch999 CC503 cam, 1.6RR, Flowmasters, 3000TC 7.79 @ 88 1.65 -460' 96 A4 3.73 Red96Coupe BFG DRs, 1.6RR, 160stat, Hypertech, 3500 TC, elims, skinny fronts and Weld Pro Star wheels 7.80 @ 89 1.72 55F 96 A4 3.73 vettestir1 LT4 hot cam, mez ewp, 2800 stall, 52mm tb, cai, DR's and a few minor bolt on's 7.82 @ 89 1.74 96 A4 3.45 Weav's Vet LT1 226/230 .565.565, 111lsa Bullet cam, 1.6 Comp Cams full rollers, stock heads, 30lb FMS injectors, Cloyes DR timing chain, 52mm BBk throttle body, Dana 44, 2800 stall, ZFDoc's beam plates, K&N, 160 stat, EWP, M/T ET Street DR's 7.82 @ 88 1.77 94 A4 3.45 blue94 AI ported Heads, 565 lift 110 LSA, 2800 Stall, LTs, MT ET's, D44 7.83 @ 92 1.94 90 M6 3.73 adi4 383, miniram, 224/234 cam, 1.52 RRs, trickflow 195s, 54mm TB, EM LTs, RT cats, Corsa, alum fw, MSD 7.85 @ 89 1.76 96 M6 4.10 jonecap DRs, catback, tune 7.88 @ 88 1.78 96 M6 4.09 Dr. Evil hotcam, alvin tune, LTs, catback 7.88 @ 89 1.80 93 A4 3.54 fredk 190 AFRs, ZZ9cam, EM LTs, claw intake, 1.6RRs, Autoworx tune 7.89 @ 88 1.75 96 A4 3.45 Weav's Vet LT1 226/230 .565.565, 111lsa Bullet cam, 1.6 Comp Cams full rollers, stock heads, 30lb FMS injectors, Cloyes DR timing chain, 52mm BBk throttle body, Dana 44, 2800 stall, ZFDoc's beam plates, K&N, 160 stat, EWP, M/T ET Street DR's 7.91 @ 85 1.68 +800' 92 A4 3.33 MTVette M/T DRs, 2600 TC, LTs, hotcam, chip, 1.6RRs, RT cats, Xpipe 7.92 @ 85 1.63 91 A4 3.33 TA stock heads/cam, 2500 TC, LTs, accel intake, asm runners, 1.6RRs 7.94 @ 89 1.87 0' 91 M6 4.09 neat 100shot, ET streets, Hooker LTs, catback 7.95 @ 90 1.82 0' 90 M6 3.33 bogor vortech s/c 8psi, ET streets superram, mild cam, LTs, 52mm TB, Autotronic SMC 7.96 @ 91 1.93 86 TKO ol,RJ 406ci solid roller, miniram, brodix heads, 246/.542cam, LTs, tune 7.97 @ 89 1.70 85 A4 3.73 rssshen ve roller 383, dart pro1 heads, 270 cam, Alvin chip, edelbrock base, SLP runners, 58mmTB, MSD, TPIs LTs, flows, 2800 TC, shift kit, BFG DRs 8.08 @ 86 1.83 100F 90 skateparkd M/T DRs, LTs, Monzas, Catless, 125shot, Jet stg 2 chip, 160stat, Fan Switch, frisbee 8.09 @ 90 1.87 0' 96 3.91 ericcer LT4 motor/hotcam, LT headers, catless, custom tune, elec wpump, delteq ign 8.10 @ 85 1.86 89 A4 Chance 383(8.7:1), superram, port+polish TFS heads, transgo shift, true duals 8.15 @ 83 1.80 87 A4 3.54 stauger 383 LPE 8.16 @ 84 1.78 85 A4 3.73 rssshen ve roller 383, dart pro1 heads, 270 cam, edelbrock base, 58mmTB, MSD, TPIs LTs, flows, 2600 TC, BFG DRs 8.20 @ 85 1.74 1702' 93 A4 3.07 1989TTATony 2800 TC, MT ET Streets, 1.5RR, Corsa cat-back, PCM4less tune, K&N w/cut air lid 8.23 @ 84 1.90 89 M6 3.33 Razor89 nitto DRs, ZZ9 cam, ported heads, LTs, catback, bigmouth, LT runners, ported plenum, cai, 52mmTB, stageVchip 8.26 @ 82 1.77 86 A4 3.07 jd_v3tt3 BFG DRs, LTs, elims, stock iron heads 8.26 @ 83 1.78 68F 87 A4 3.07 rodj M/T DRs, 2000 TC, ZZ4cam, SLPrunners, ported TPI, 58mmTB 8.29 @ 87 1.90 96 M6 4.09 Dr. Evil hotcam, catback, K&N+cutlid 8.31 @ 91 2.04 107F 90 A4 3.45 conv90 383, trickflow heads, SuperRam, 219cam, LTs, 58mmTB 8.32 @ 86 1.90 87 A4 3.07 SpankYello 180cc intake heads, Edelbrock base, TPIS runners, ZZ4 cam, LTs 8.34 2.01 96 A4 Legion21 SLP cai, LTs, 3" exh, nitrous, mallory hyfire VI 8.38 @ 85 1.93 96 M6 ubnpast DRs, SLP intake, flowmasters 8.39 @ 83 1.84 -100' 94 A4 3.07 Red98C5 DRs, cai 8.39 1.79 +600' 93 A4 3.73 Fuzzy Dice Nitto DRs, LTs, 3200 TC 8.40 @ 84 1.95 -500' 95 M6 3.45 Mr Mojo no mufflers 8.40 @ 86 1.99 89 M6 3.54 89sleeper M/T streets, 383 GMPD short block, edelb heads, TPIs: 409 cam, Miniram, LTs, prom 8.41 @ 85 1.95 94 M6 pr1mu5 DRs, centerforce clutch, no muffs 8.41 @ 84 1.97 94 M6 3.45 1stvette94 DRs, 1.6RRs, meziere 8.42 @ 83 1.96 91 M6 4.10 neat LTs, catback, 1.6RRs, tune 8.43 @ 84 1.96 92 A4 3.07 C4Crazy787 2800 TC, hotcam, 1.6RRs, EM LTs, 52mmTB, NP chip 8.43 @ 83 1.91 90 M6 jonecap TPIs intake+chip+runners, 1.6RRs, catback, no cats, pulleys 8.45 @ 87 2.20 87 A4 2.59 CRV3TT3 Paxton S/C, exh, M/T DRs 8.45 @ 83 1.91 89 M6 3.33 Z51L9889 ported 113s, no precats, cat&back, portedTPI 8.46 @ 81 1.82 85 black85 LTs, catback, pulleys, ported TPI 8.46 @ 85 2.04 89 3.07 kopbet89c4 miniram, no cats, chip, 24# inj, no MAF 8.46 @ 85 1.97 89 M6 3.33 black_89_v 383, superram, LTs 8.46 @ 80 1.77 90 A4 3.07 Crowhater zz4 crate, Lingenfelter headers, NX nitrous, 2800 stall, Kumho's 8.47 @ 84 2.04 87 A4 2.73 slverdrptp Stock 113 heads, TPIS ZZ9 cam, TPIS Big Mouth intake, AS&M semi-siamised runners, Comp Cams 1.5 Pro Magnum roller rockers, SVO 24lb flow matched injectors, true dual 2 1/2" exhaust off factory headers with Flowmaster mufflers, chip by skidownit 8.48 @ 82 1.99 -400' 88 A4 2.59 65Z01 SLP cai, 52mmTB, ported plenum, no precats, cat&back, 1.6RRs 8.49 @ 83 2.07 -2150' 95 M6 3.45 Mr Mojo none 8.50 @ 83 2.03 +1100' 93 A4 3.45 James93LT1 hotcam, LT4heads, 1.6RRs, slp shorties 8.51 @ 85 1.95 96 M6 Jack_lt4 flowmaster 8.53 @ 88 2.17 85 M6 3.45 LD85 406ci, AFR 210s, Miniram 8.53 @ 86 1.97 60F 94 M6 3.45 chevy406 LTs, cai, no cats, centerforce DF, 1.6RRs 8.54 @85 1.95 2771' 92 A4 2.59 04gtogoat hotcam, 1.6RR, CC full exhaust catless, eliminators, power coupler, MSD blaster, 30LB injectors 8.57 @ 85 2.06 +500' 93 M6 3.45 mn_vette iron heads, no cats, mez wp, 58mmTB, 230/236 cam 8.57 @ 84 1.94 60F 95 A4 3.07 pettvette 8.59 @ 86 1.90 50F 95 A4 3.07 aminnich DRs and elims, Meziere WP, otherwise bone stock 8.64 @ 84 2.12 94 M6 1stvette94 stock 8.64 @ 79 1.86 -400' 85 M6 3.45 CentralCoa M/T DRs, SLP cai, elims, cat&back 8.64 @ 81 1.94 92 A4 3.54 mcnulty95 shift kit, elims 8.65 @ 81 1.99 -500' 88 65Z01 8.68 @ 83 2.11 95 M6 3.45 Jonnymac SLP cai, 1.6 RR, Borla catback 8.69 @ 81 1.95 93 4.10 Driftmonst LTs, chip, borla exh 8.71 @ 84 2.04 89 3.07 kopbet89c4 Superram, no cats/smog, Alvin chip, 24# inj 8.71 @ 79 1.89 88 A4 hooblyboob miniram, 2500 TC, ported heads, cam 8.71 @ 82 2.21 -2150' 95 M6 3.45 Mr Mojo stock 8.73 @ 83 2.21 -2150' 94 M6 3.92 DaveT just gears 8.74 @ 80 2.09 85 A4 3.07 JohnMarker AFR 180s, SR, RRs, tjwong chip, MSD, transgo shift kit, cust exhaust, pulleys, no cat 8.76 @ 82 2.05 96 A4 3.07 Gmans96Cou Vortex ram air, 52mm TB, Borlas, no cats, granatelli MAF 8.79 @ 79 1.88 86 A4 2.59 Corv Chris Dynomax Catback, Flow Kooler W/P, TB Bypass, TB Airfoil, 180 'stat, K&N Filters, Bosch Design III Injectors 8.82 @ 78 1.97 +600' 87 A4 3.07 87 rag 1.6rollertips, Borla catback 8.84 @ 79 1.99 +600' 88 M4 3.07 88BlackZ51 Nitto DRs, Hooker LTs+Y, cat&back 8.84 @ 79 2.06 +1235' 94 A4 Drug Deliv stock 8.8 @ 81 2.2 92 A4 3.45 MrNuke chip, Borlas 8.83 @ 79 2.03 +2276' 89 A4 3.07 gigaglytch 2100stall, LTs, no cats, catback 8.84 @ 77 1.89 86 A4 2.59 Corv Chris K&N, muffs, (stock 86L heads) 8.85 @ 78 1.95 87 A4 CRV3TT3 catback 8.85 @ 76 1.86 86 A4 2.59 zbo2 bone stock, street tires 8.91 @ 80 2.09 -200' 85 M6 3.07 CentralCoa SLP cai, elims, cat&back 8.91 @ 1.86 95 M6 3.45 95wht6spd cut lid + K&N 8.93 @ 83 2.24 +2445' 91 M6 neat 100shot, Hooker LTs, catback 8.94 @ 79 1.99 87 A4 RS69 K&N, modified cats, ultaflow mufflers 8.95 @ 78 2.11 +2445' 91 M6 neat Hooker LTs, catback 8.95 @ 76 1.88 1709' 87 A4 2.73 Lemme T Headers, Shaved Heads, Stg 2 shift kit, 2600 TC, A/BOX Lid, power pipe, TB Bypass, airfoil, MAF gauze removed, K&N, AIR delete, precats delete, EGR delete, custom 89 ARAP bin 8.96 @ 78 2.07 85 M4 3.07 rel3rd pulleys, hiflow cat 8.96 @ 76 1.93 85 A4 rickhiggin bone stock 9.09 @ 78 2.06 +500' 85 M4 3.07 CentralCoa SLP cai, elims, cat&back 9.10 @ 82 2.24 +1500' 88 M4 3.07 88espo 327ci, 461 heads 9.23 @ 76 2.13 86 Agent 86 no cat, no smog, magnaflow exhaust 9.24 @ 74 2.03 +2710' 89 A4 3.07 cuisinartv catback 9.15 @ 77 2.21 88 A4 3.07 popkid stock, street tires, no mufflers 9.32 @ 76 2.16 91 A4 2.59 1991 C4 B&B exhaust 9.35 @ 78 2.09 88 A4 2.73 gbody5 stock 9.39 @ 80 2.18 87 M4 Mr. Dude lowered, bilstein shocks, borla high flow mufflers with true dual straight pipes, newer control arms, newer bushings, newer tie rods, K&N filter
DRs: drag radials
RRs: roller rockers
SR: SuperRam intake
Last edited by MTVette; 08-22-2011 at 01:34 PM. Reason: Added Crowhater and 04gtogoat; updated Aardwolf
I didn't notice many FI cars, so I will add mine. Time slip is from early spring, and temp in the low 70s.
9.34 @ 152.7, 1.82 60'. I have slightly better 60' times with this combo (some in the 1.7s), and a few with a couple more MPH (crappy 60' and spinning adds speed), but this slip is probably the best overall.
'87, 408cid (4" stroke, 350 block), AFR215s, 248/254 @ 0.050 SR cam, SP intake, MB, D1R, FAST sequential, ZF, 3.45D44
Noticed my run wasn't up here, this was when I was bone stock earlier this year.
My best run was
R/T .618
60' 2.274
1/8 9.300
1/8 MPH 77.63
1/4 14.367
MPH 97.69
'85 4+3 with 3.07's
My best run was
R/T .618
60' 2.274
1/8 9.300
1/8 MPH 77.63
1/4 14.367
MPH 97.69
'85 4+3 with 3.07's
Last edited by dclafleur; 10-13-2008 at 12:49 PM. Reason: forgot year and transmission
Received 3,043 Likes
St. Jude Donor '05
What was wrong with the other thread?
St. Jude Donor '05
Was it locked recently or back then? Just curious
Here is a update for mine. 10.36@135.86 1.52/60. DA 6800 ft. 450ci AFR220's, Miniram, Crane 252/260 solid roller, FAST, 200 shot NOS, ZF6, 3.70 9".
6.68@105 1/8mile 1.47/60 DA7000 ft
Former Vendor
Here's mine. 13.76@101.7 with a 2.1 60. Its a cast iron head 86 with LTs, an SR a K+N and underdrive pulleys. Its a 4+3 with a 3.07s and the drivetrain is stock except a Fidanza aluminun flywheel. I'm in the process of installing aluminun heads off a 90 and 1.6 roller rockers.
St. Jude Donor '05
Can I put this in my sig?
here's mine. 1/8 mile, 7.30 @ 97 on a 1.69 60'. 383 with vortech t trim, auto, 3.73 gears. Stock converter, off idle at 900 rpm. No quarter runs.
Would be nice if you could make the column headers stationary so when you have to scroll vertical and/ or horizontal, you don't have to remember what each column is. And when there are page breaks, repeat column headers on the next page.
Another column for Coupe or Convertible would be good since there is about 200# difference in the two.
