Anyone make a kit to put an LS motor in a C4?
I currently have the motor out of my 87 and have been driving my roommates 06 GTO for a few weeks and love the LS2. It got me wondering if anyone offers a kit to install an LS based motor in a C4? Has anyone ever seen one?
Yes I've searched the many old threads but still see no "kit" offered and am just wondering if anything new has since come out...
I am sure you can get most of the parts needed but from my understanding there is some work to the lower cross member that will require some cutting and welding. obviously if this is correct there isn't a "KIT" that can provide the clearance but everything else is just a matter of how much work and time you want to put into an 87 corvette?
would likely be cheaper to just buy a 97 C5 in the long run and sell the 87 with the opriginal motor once it is back together and have a factory fit engine and better handling etc.. just a thought
Chris
Chris
I'm also AMAZED that they JUST came out with a single turbo setup for the C4 TPI cars, only took 20 years I could buy a single turbo kit for my Fox Body Stang 18 years ago. The C4 is the largest production Vette ever made so there is no excuse for the old "there aren't enough of them to turn a profit" excuse, whats the deal with the aftremarket just dropping the ball for parts for this car?
Exactly, and restoring it is the next owners job, not mine :-)
Received 3,043 Likes
St. Jude Donor '05
Most C4 owners dont want to spend the money on product, not a real lucrative deal for a mfr. Heck, look at all the XXX is a pos threads.
Stubbs, just build a big CI Gen 1 for that sucker.Lots of that going on here.
Simple like that
I think that I have seen the motor mount adapters somewhere to make it easier.
You don't need a kit for that part. Now the electronics are a different story I'm sure
There isn't a kit, but Corvette fever has put a gen III small block in a C4. My vote would go to getting a donor car so you have all the sensors 'n stuff, so if that roommate's goat ends up rear-ended, you know what to do.
Motor mounts seriously should not be that bad. Since I'm gonna use a carb setup, not use AC or powersteering, and plan to fab up brackets in order to use my stock alternator with an LS1 F-Body water pump, I'm sure this will greatly simplify the conversion for me.
