Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-09-2008, 08:43 PM   #1
jfva
Junior Member
Default 1990 corvette horn relay
Need help
where is fuse and horn relay at on 1990 corvette conv?
jfva is offline   Reply With Quote
Old 09-09-2008, 09:22 PM   #2
rodj
CF Senior Member
rodj's Avatar
Fuse panel is in end of dash ,pass side ;hidden when door closed.
Horn relay is under the dash somewhere from memory.
rodj is offline   Reply With Quote
Old 09-09-2008, 09:29 PM   #3
C41987
CF Senior Member
http://www.autozone.com/N,4294931136...locsSelect.htm
on my 87 the fuse was w/relay
C41987 is offline   Reply With Quote
Old 09-09-2008, 10:14 PM   #4
BADDUCK
CF Senior Member
BADDUCK's Avatar
Location: One day you're a Comet...the next day you're dust... Arkansas
Quote:
Originally Posted by jfva View Post
Need help
Horn relay is behind the info panel in the dash above the shifter.
BADDUCK is offline   Reply With Quote
Old 09-10-2008, 10:09 AM   #5
josephf31
CF Senior Member
josephf31's Avatar
Send a message via AIM to josephf31 Send a message via Yahoo to josephf31
Default On my 91
the horn relay is up under the passenger side dash hush panel, there are 5 in there altogether
josephf31 is offline   Reply With Quote
Old 09-14-2008, 01:33 PM   #6
pipe
CF Senior Member
Send a message via AIM to pipe
Yep under the pass. side hush panel. Laying on your back there will be 2 on the left together then a group of 3 on your right. It's the middle one in the group of three. Ya know sometimes it's not the Horn relay that goes bad not making the Horn not work. A small connector in the Steering Column gets brittle over time and cracks not making contact and causes the horn not to work. Pipe
pipe is offline   Reply With Quote
Reload this Page 1990 corvette horn relay
Tags
1990, corvette, fuse, gm, horn, installation, location, pannel, relay
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
