code 44
code 44
Hi, I have been getting a code 44 for years now and really want to get it running right. I read that the computer should send .35-.55 volts to the sensor when running so i cut the wire going to the O2 sensor (A16) right up by the computer and connected a volt meter to it and the battery and got a reading of only .18 volts. I also ohm checked the ground wire (A22) and it came up good. I replaced the computer a few years ago so im really hoping that it is not the problem but is their anything else that could cause it?
Thanks, Mike
Thanks, Mike
Thanks, Mike
Thanks, Mike
Cheers,
Michael
