Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-04-2008, 11:54 PM   #21
Caboboy
CF Senior Member
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Caboboy's Avatar
It will be worth the effort.......trust me on that one Look at Beach's post #14 above.........the last paragraph in particular. There's just too many of us happy with our big cube SBCs to ignore their merit. The only words of advice I have are to choose your combo & goals carefully so your parts compliment each other!
ps: check my photos for my Scat internally balanced rotating assembly
Caboboy is offline   Reply With Quote
Old 09-04-2008, 11:57 PM   #22
cuisinartvette
CF Senior Member
St. Jude Donor '05
I always thought the 400 would be fun to try out with a FIRST TPI system as far as a mild streetcar goes. Tons of torque and no need to rev it to the moon to make power (although those are fun too but get pricy quick).
cuisinartvette is online now   Reply With Quote
Old 09-05-2008, 12:23 AM   #23
Caboboy
CF Senior Member
Caboboy's Avatar
Quote:
That would've been my first choice Ron!
Damn Cali smog laws
Old 09-05-2008, 12:31 AM   #24
cuisinartvette
CF Senior Member
St. Jude Donor '05
Like you need more torque, Mr. 54,856 ft. lbs at the tires.
Old 09-07-2008, 05:16 AM   #25
hip
CF Senior Member
Default 400 dip stick
A dipstick on the lelt is a + , more room for starter wires. My TPI motor changed to a 427 carbed fun little ride.
hip is offline   Reply With Quote
Old 11-18-2008, 02:59 AM   #26
Jeff M
CF Senior Member
Jeff M's Avatar
Send a message via AIM to Jeff M
Not trying to hijack the thread but I've been amassing parts and doing research for my other "toy" build; an 86 Chevy Silverado 4x4 I'm going to lift, bigger axels, etc... I have wrapped up a 400 block still with the factory bore. It's going to end up as a 406 with a modified factory TPI. Extrude Hone base, AS&M runners, ported plenum and so on. I'm only looking for an RPM peak around 5000 or so. In fact I could care less about HP just give me a nice fat torque curve from about 1200 to 4500 and I'll be happy. With the proper combo of heads/cam/TPI mods and good chip tune this motor should put out Big Block torque numbers. As someone else mentioned ensure your honest with yourself as to the intended application for your build. The factory TPI will never put out huge HP numbers, however if the combo is put together correctly they will make an incredibly fun motor to drive on the street.
Jeff M is offline   Reply With Quote
Reload this Page 400 SBC with tuned port?
Tags
400, 400sbc, cam, ci, flywheel, good, limi, make, port, powerband, rpm, sbc, tpi, tune, work
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
