C5 Brake Upgrade Done (Pics)
#41
I'm pretty sure you can get them at most if not all parts stores.
I got mine from here.
https://www.superchevyperformance.co...les.asp?ID=124
#43
OOPS! I found my receipt from my rotor purchase and discovered that I had the wrong name for the company that supplied my rotors and pads.
I had BSI Brakes listed, but the correct company is "BRAKE DESIGNS, INC.", (BDI). http://brakedesigns.com/
I made corrections throughout the thread.
Sorry for making such a bad mistake. Great company to deal with.
#49
They require 17" rims. You can use 1/4" spacers with saw blades, but I'm not sure about the salad shooters. Any C5 or C6 wheels fit with no clearance issues on the 88-96 Vettes, but the earlier models require wheel adapters to get the right offset. (Unless you buy them new with the correct offset for your car).
#50
J55's are 13x1.1". C5's are 13x1.25". They are definitely thicker than J55's.
I think the stock (JL4 or something?) '88-94 stuff is 12x1.0" (or 0.9")? It may sound minor but it's a pretty big difference in rotor material.
#51
#52
I'd like to do this, but I also want to run saw blades. How bad was the clearance issue? No way to safely remove enough from either the caliper and/or the wheel to keep that combo?
#53
Not sure, but I believe they do clear those wheels without issues.
I don't see why you couldn't remove about 1/4" off of the back-side of the saw blades. (exactly where it would contact the calipers) Plenty of material would still be there afterwards.
#55
You could probably take a little off the caliper, however it might not pass a safety instpection if your state has one or a track inspection.
IIRC the back of the sawblade wheel there is a little bit that could be ground off.
Want to be 100% sure, find a thin spacer that retains the hub centric mount.
I may have a c5 upgrade set available in October - trying to decide between the C5 set I have on the shelf or a big brake kit.
#58
So a 1/4 inch adapter might solve any clearance issues I might have with my rims? Where can you buy these adapters?
Here are the wheels I have on the car.
#60
Let me know on the upgrade set - all I'd need would be the calipers and adapters themselves. I already have access to a set of rotors and pads.
