Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Closed Thread
Old 07-21-2008, 04:37 AM   #1
IslandVette808
CF Member
IslandVette808's Avatar
Default Bad ignition module symptoms
Just wondering what are the symptoms that a bad or damaged ignition module will cause? I have been getting code 42 meaning it could be the ignition module but my car still runs fine and strong, so im just curious. Thanks!!!
IslandVette808 is offline
Old 07-21-2008, 07:04 AM   #2
schrade
CF Senior Member
Hey Zeits - Get a load of this!!! 42 ICC code
Check this Island (pics for PCM by-pass):
http://forums.corvetteforum.com/show...9&postcount=68
Read the whole thread; good pics and GOOD info...
http://forums.corvetteforum.com/show....php?t=2069247
Your module alone can be tested at the Advance Zone any store.
Zeits -we need to swap PCM's too, to see what happens. PM me if you wanna' try it. I can do without mine if you wanna' go first...
schrade is offline
Old 07-21-2008, 08:43 AM   #3
jfb
CF Senior Member
Mine were hard starting, long cranking to start.
jfb is offline
Old 07-21-2008, 08:56 AM   #4
cfi
CF Senior Member
cfi's Avatar
Mine began as car not starting when hot. Then one day in cruise it just quit.
cfi is offline
Old 07-29-2008, 10:17 PM   #5
Stealthvette
CF Senior Member
Stealthvette's Avatar
Quote:
I have had an on-going problem with ignition modules burning out about every 6 months on my 86 auto. I used to have an MSD 6A system on it and people on this forum told me this was the problem. But here I am 6 months later and my IM just burned out again.
Mine always goes bye, bye after I shut the car off and try to start it up later. It can be overnight, or I can stop to get gas, but it never has stopped while running. This problem has happened in the original distributor and in an Accel distributor that I purchased to solve the problem.
Stealthvette is offline
Old 07-30-2008, 03:00 AM   #6
IslandVette808
CF Member
Quote:
You mean like the engine taking more than, say 10 seconds or more, to fully turn over?
Old 07-30-2008, 03:04 AM   #7
cwyates4
CF Senior Member
cwyates4's Avatar
A bad ICM is usually one of those "20 minute" type things. They tend to reveal themselves as bad when the car is hot.
cwyates4 is offline
Old 07-30-2008, 07:16 AM   #8
Da Mail Man
CF Senior Member
Da Mail Man's Avatar
....there is a long thread i started a few weeks ago dealing with ignition modules..take it from a guy who's replaced 8 of them!...in my case the car would simply not start...crank but no spark and no start....while there are symptoms of rough running at times that could be related to the ignition module due to heat, most of the time the ignition module will simply be either bad or good, period....
...no power to coil, bad coil, bad pick-up coil in distributor, bad ignition module, missing contact "button" on inside of cap can result in no start/spark...
...i don't believe that long cranking times have to do with the ignition module as i have that very same problem since i have owned my car...i have since replaced my capacitor/condenser assembly inside my distributor (1988) and am waiting to see how long my 8th module lasts.....what i would reccomend is that you change out the module and see what happens..at least you will have a spare to carry with you should yours go out while you are out.....good luck....
Da Mail Man is offline
Old 07-30-2008, 10:50 AM   #9
rick lambert
CF Senior Member
rick lambert's Avatar
Hey Mail Man, thought you eliminated the Ignition module as the cuprit?
rick lambert is offline
Old 07-30-2008, 11:12 AM   #10
vader86
CF Senior Member
vader86's Avatar
It'll start as hard starts; yes it'll take longer to turn over.
Then one day in the middle of traffic, with no warning, it will die and you'll be stuck there. It'll crank and crank forever and wont fire.
So I'd go ahead and replace it, its cheap, but follow the electronic troubleshooting guides in the manual and make sure something else isnt bad too.
vader86 is offline
Old 07-30-2008, 11:33 AM   #11
Da Mail Man
CF Senior Member
Quote:
...yeah, i think i did but, only time will tell on this one...i have noticed that it starts a bit easier and i get a little less "whine" in the audio n the car...
Old 07-30-2008, 11:33 AM   #12
Da Mail Man
CF Senior Member
Old 08-07-2008, 06:18 PM   #13
Stealthvette
CF Senior Member
My 86 needs a new IM every 6 months. It has never gone out while running. It always happens after I shut the car off and then try to restart or start it up first thing in the morning. I've replaced many, many in 9 years. Putting my system back to totally stock has not helped. Putting in a new distributor has not helped. So, I can eliminate the threads about the bad pick up coil, bad wiring harness and using aftermarket coils/MSD. Next??
Old 08-07-2008, 06:26 PM   #14
Da Mail Man
CF Senior Member
Quote:
....mine has never gone out while running either...it is when, after use, that it will crap out when i want to start it...i have over time and doing the usual tune ups and not throwing parts at it, have narrowed it down so far to be what i mentioned in an earlier threat here and again, only time will tell.....it is the ONLY part that i have either not tested or replaced....
Old 08-07-2008, 06:30 PM   #15
Binski
CF Senior Member
Binski's Avatar
My experience: Hot day-in traffic, starts to die, restarts about 3 times and then its over.
Binski is offline
Old 08-07-2008, 06:44 PM   #16
Stealthvette
CF Senior Member
Quote:
As I recall you have tried changing your small wire harness inside the distributor. I hope that works for you. Unfortunately, I have replaced the whole distributor and still have the problem.
Old 08-07-2008, 06:47 PM   #17
Da Mail Man
CF Senior Member
...granted but, how do you know that you don't have a problem with the capacitor in the distributor?..that is the only thing i have not replaced....if it starts to crap out due to heat, etc., that could be a cause...as for me, that is the ONLY thing i have not tried...in a points car i had a long time ago, the capacitor shorted out and car would not start...i disconnected the capacitor/condenser and it started immediatly......good luck..
Old 08-08-2008, 11:16 AM   #18
rick lambert
CF Senior Member
Stealthvette, when your ICM seemed to go bad did you take it into AutoZone or some other place to confirm it was bad? or just replaced it. If I were you 2 guys I'd also be checking connections on the ECM.
I think mailman replaced one of his ICM, then took it in and it checked out to be OK. Problem is, there is no way for US to check out the ICM, takes special equipment.
Old 08-08-2008, 11:24 AM   #19
Da Mail Man
CF Senior Member
...that is correct..i never took any of my icm's (8 or 9) in to be tested as they were all under warranty..i DID take the last ac delco TWICE and the first time ran it through 3x's and it tested good..the second time i ran it through +/- 15x's and it also tested good...i DID however a long time ago, cleaned and checked all the connections to/from the icm....
Old 08-08-2008, 06:54 PM   #20
Stealthvette
CF Senior Member
I have done the same. I would have to assume that the IM is the culprit because changing it is the only thing that gets the car running again. Any ideas why this is what works?
Reload this Page Bad ignition module symptoms
Closed Thread
Tags
bad, c4, capacitor, car, coil, control, corvette, distributor, failure, faulty, igniter, ignition, module, pickup, replaced, symptoms
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
96 died - no start Gary04Z06 C4 Tech/Performance 11 09-18-2005 12:12 AM
Ignition control module/pick-up coil question 6speedshifty C4 Tech/Performance 15 05-10-2005 12:16 AM
Well it's time to consult the experts!!! edsalinas C4 Tech/Performance 53 02-21-2005 08:22 AM
Bad Opti symptoms/experience sumoboy C4 Tech/Performance 14 07-22-2003 07:37 AM
Bad Optispark? Dakota 6 C4 Tech/Performance 26 04-24-2003 04:30 PM
I hope you guys understand this message. yong C4 Tech/Performance 51 03-28-2003 10:34 AM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
