Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-12-2008, 10:59 PM   #1
Calderone
CF Senior Member
Calderone's Avatar
Default Egr Delete And Some Hose ...
Guys what effects can cause if i buy a EGR Block off plate ????
I remember that i saw some plates to block that silly hose
that runs over the passenger valve cover...where can i get the plates for that ???? i dont remember where i saw them !!!
what's that hose function ??????
im planning to delete all of them ! thanks
Hose locations and EGR
Click the image to open in full size.
Hose installed
Calderone is offline   Reply With Quote
Old 07-12-2008, 11:14 PM   #2
AGENT 86
CF Senior Member
AGENT 86's Avatar
I cut them out of 1/4'' aluminum plate. Not worth the time and money to buy them.
AGENT 86 is offline   Reply With Quote
Old 07-12-2008, 11:15 PM   #3
FICINJECTORS
Premium Supporting Vendor
FICINJECTORS's Avatar
Hose installed
here you go sammy
http://cgi.ebay.com/ebaymotors/CHEVY...9486QQtcZphoto
FICINJECTORS is offline   Reply With Quote
Old 07-12-2008, 11:21 PM   #4
Calderone
CF Senior Member
Calderone's Avatar
thanks but there is something missing here !
i can see 3 here :
1 - block off plate for :
- COLD START INJECTOR (I DONT WANT THAT)
- EGR - OK
- EXHAUST CROSSOVER PLATE (ARE THEY 2 ???) I SEE 1
I need only that...the complete kit looks cool
do i need the cold start block off if i put edelbrock '89 runners ?
Old 07-12-2008, 11:25 PM   #5
FICINJECTORS
i can see 3 here :
- EGR - OK
here try this one..
http://cgi.ebay.com/ebaymotors/CHEVY...0890QQtcZphoto
Old 07-12-2008, 11:40 PM   #6
Calderone
CF Senior Member
Calderone's Avatar
Jon,the exhaust crossover needs 2 plates
i only see one plus the EGR one
Old 07-12-2008, 11:48 PM   #7
FICINJECTORS
sam e mail them.. i know alot of guys that use them..
but thats the place
Old 07-12-2008, 11:52 PM   #8
Calderone
CF Senior Member
Calderone's Avatar
i just did it !!!
thanks !
i will be getting this,its a pita take off that silly hose everytime i want to take the valve cover off.-
and i dont want the EGR valve anymore since maybe its not working properly,i dont know how all of this will affect my car but i think nothing terrible since this items are being bought all the time !
any idea on what could happen with no egr and crossover hose ?
thanks
Old 07-13-2008, 11:06 AM   #9
'Shifter
Gimme fuel, gimme fire...
St. Jude Donor '08-'09-'10-'11-'12-'13-'14
NCM Member '09
Support Corvetteforum!
'Shifter's Avatar
I read somewhere that you need to delete the EGR function in your
PROM....I only skimmed it since I'm stuck with mine...
__________________
Take no prisoners!
'Shifter is offline   Reply With Quote
Old 07-13-2008, 12:53 PM   #10
staugur
CF Senior Member
staugur's Avatar
Here's a cheap way.Cut the flanges off the old pipe and reuse with a couple of coins. The EGR valve you can just block with an aluminum plate,easy enough to fabricate.
__________________
'87 383 Lingenfelter
staugur is offline   Reply With Quote
Old 07-13-2008, 01:55 PM   #11
Calderone
CF Senior Member
Calderone's Avatar
thanks staugur
are the 2 ends of the crossover exhaust tube identical ?
thanks
Old 07-13-2008, 02:01 PM   #12
staugur
CF Senior Member
staugur's Avatar
thanks staugur
thanks
I believe so.
Old 07-13-2008, 02:20 PM   #13
Calderone
CF Senior Member
Calderone's Avatar
thanks !
Old 07-13-2008, 03:35 PM   #14
Firevette
CF Senior Member
Cruise-In X Veteran
Firevette's Avatar
Send a message via AIM to Firevette
TPIS sells some too.
Firevette is offline   Reply With Quote
Old 07-13-2008, 03:39 PM   #15
Calderone
CF Senior Member
Calderone's Avatar
what's the advantage on doing this?
Old 07-14-2008, 01:12 AM   #16
SunCr
CF Senior Member
Zero without something to keep your combustion temps under 1200 degrees which is what EGR does. Get above that combustion temp and it forms NOX - ok - so you're not a tree hugger - but you can also get detonation. The ECM then pulls timing and you lose performance (and maybe a mile or two per gallon - kinda of important these days). At worst, you wear out what may be an allready worn out motor. Anyway, unless you want to swap out the cam for a little more overlap - or maybe figure out how the Brits used water injection to keep their Spitfires flying - I'd fix it; it isn't that difficult to figure out. And while you're out it, spend your money on a Scanner or a cable for your laptop, which along with some free software, will give you all you need to monitor how everything is doing.
SunCr is offline   Reply With Quote
Old 10-18-2011, 05:46 PM   #17
hitmanpty
CF Senior Member
hitmanpty's Avatar
romulo.alvarado.52@facebook.com
Send a message via MSN to hitmanpty Send a message via Skype™ to hitmanpty
great post. love the forum
hitmanpty is offline   Reply With Quote
Old 10-19-2011, 10:24 AM   #18
blackozvet
CF Senior Member
blackozvet's Avatar
hi sammy, did mine on my 85 (only needs one plate) cleans up a lot of mess with hoses and pipes and mine had a vacuum block on the intake manifold that went too,
got my plate, which is cnc'd billet alloy for $15 off ebay.
and no codes or ses light at all
blackozvet is offline   Reply With Quote
Old 10-19-2011, 10:46 AM   #19
Calderone
CF Senior Member
Calderone's Avatar
thanks ! guys this is a 3 year old thread
i have now the accel base with non egr all blocked , keeps everything clean
less things to worry , it's under the Super Ram now
Thanks !
Old 10-19-2011, 06:25 PM   #20
93Rubie
CF Senior Member
93Rubie's Avatar
What happens when the dime/nickel comes loose over time?
That is half @$$'ed in my book, but hey your car, not mine. So whatever floats ones boat I suppose.
I'd get the plates cleaner look/less chance of revisiting it later.
93Rubie is offline   Reply With Quote
Reload this Page Egr Delete And Some Hose ...
Tags
1986, 1990, 84, 85, 87, bypass, c4, corvette, crossover, delete, diagrams, egr, pipe, tube, vette
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
