What does it take to make 400WHP in an LT1?
A few guys here have hit 400 rwhp with H/C. I would shoot for a killer combo over just hitting 400 rwhp. Anyone can put a huge cam in the car and watch the dyno spin to 6800 rpms to hit your magic # but it might be a pig off the line. IMOP dont go any bigger then a cam similar to the cc306. Even that cam may require a big stall converter to get up to its power range. The boys at www.advancedinduction.com netted my 93 auto 90 more rwhp and 50 rwtq with there 190cc and a cam with less duration but higher lift then the hotcam.
Have you had any track experience with the c4? Im curious to what yours and other 400whp (or close to) c4's run? 12's? high 11's?
The only time I've had my car to the track with its current combination, the times were very traction limited. But, I got 4 runs in the 12.40 range, and every run was 119+ mph. With a good set of sticky tires I should be solidly in the 11's.
I've read alot about the LE2 package(at least everything i can find) and it seems to be like a good option to me, especially because emission are not a issue with me. I like how everything is matched for you (h/c) package and pretty much ready to go other than a few other supporting mods. But, i have not found much information from corvette customers about power numbers on their applications. Thats what im looking for. and you are my man Any plans to get a tune or dyno? Keep us updated on what your results are.
i see everyone talking heads cam long tubes i dont have any of that and im getting 412rwhp out of my lt1. i have stock heads, stock cam, stock intake, 52mm body,1.6 rollers,short headers. i beefed the bottom end up to support the 175 shot of nitrous im puttin to it so there you have the 400 rwhp without all that high dollar stuff.
I have the AI 200s on my daily driver with an AI cam a bit more radical than Bob's, but Ron/Phil have everything optimised to work together. So with an Ed Wright tune my little 355 has mellow enough street manners that my 17 year old takes it out at night, but it has enough ***** to shred the tires from a roll,
....and it gets me to work every day with the AC kicking in the Summer, heat in the winter, and has been on a couple of multistate road trips.
Mike
I forget to mention Brian Ebert, he built an outstanding shortblock that handles my juvenile antics with aplomb.
Last edited by aboatguy; 07-11-2008 at 08:30 PM. Reason: Forgot Kudos to Brian Ebert
I was wondering how long it would take for someone to say it
Does lloyd elliots website still exist?? I can't seem to find it?
Received 3,043 Likes
St. Jude Donor '05
#33
Check out Advanced Induction, I used their LT1 200 setup with long tubes and stock intake and TB turned 360 at 5800 and 391 at 6250. The Engine was still making HP and the torque line was still flat, just did not want to run a stock bottom end past 6250.
With a 2800 stall TC and a shift kit it will light em up at will. Still get 23 MPG on the highway but stop and go is down to about 15.
Ron and Phil at AI are great to work with and don't mind the string of questions either. you can tell them what results you want and they will get you there.
Keep in mind you will need a good tune.
#34
Looks like they make some great packages at an affordable price. This about the price range that i am looking for. Great info!
#36
What about forced induction? I know building a twin turbo for your car wouldn't be too daunting, also I have seen that pro charger makes a complete system. The pro charger, an exhaust with headers should get you pretty darn close.
#37
When it comes to a c4 i am much more of an N/A kinda guy..i dont know why but i am. Now, if i had a c5 i would consider that...
#38
If I had the money I'd buy a ZR1 just to him build me another engine!
#40
I went with AI more than once, my 190s were great the 200s are a little better than great so I guess that makes them AWESOME. The great thing about AI is quality. LPE is probably the same QUALITY. IMO there are no bargains when it comes to quality performance parts, IE Quality costs Money.
Mike
Mike
