How to OHM check Injectors (instructional video)
Supporting Vendor
I have been getting a lot of e mails on how to check injector coils. You should do this 1st cold and then hot
Way to go Jon! That should help a lot of folks.
Don't forget to check them hot and cold too!
BTW, injectors are working fine on the convertible! I am looking forward to the # 42s on the turbos, when I get them in finally!
Johnny
Johnny
Here's a question Jon,
When I first learned how to ohm my injectors (87) stock, I was told they should ohm around 16 +/- .5, well, they did, so I past that information on to others. Later one of the forum members asked me where I came up with the 16, I couldn't remember, so I looked in my 87 FSM. It says they should ohm at least 10. So, what yrs. should ohm where? As far as I'm concerned now, as long as their all within +/- .5, it seems to me that's the most important criteria. Is that right?
Supporting Vendor
awesome, thanks John
Terrific, thanks, answered my questions with your various posts about LT1 injectors. I'll test at 2K range for around .017 value on all, any much below or above (beyond .0005 I guess it would be) is suspect but .012 or below definitely a problem unit from what I gather.
You guys PM the mods to sticky this...
Everyone makes their own injector thread / FPR thread, and they all get buried. Sticky this, and your threads won't get buried so fast with new ones...
My
My
Supporting Vendor
If Jon made a big sticky, he'd probably save himself some work. He's constantly posting the same info to people everyday.
Received 3,043 Likes
St. Jude Donor '05
FIC is a class act. Im ashamed I dont know how to use my multimeter. Know the voltage/ohm amounts to check, just used to flip the switch around til I hit on what I thought was the right one
Dont know an ohm from a Volt
Learned something tonight.
