Tips for loosening Catalytic Convertor brackets on LT-1
Old 06-18-2008, 01:04 PM
biggrizzly
biggrizzly's Avatar
2015 C5 of Year Finalist
Default Tips for loosening Catalytic Convertor brackets on LT-1
I'm attempting to loosen the brackets that hold the stock convertors in place on a 94 LT1. I don't want to cut them, but need them loose to align the factory convertor flange to the bottom of the Hooker Shortie header. There is a small gap and to close the gap I need to move the convertor up to meet the header flange.
I have tried just about every configuration of wrench and socket in my box, but for the life of me can't figure how to loosen them buggers with the transmission installed. Any tips or horror stories welcome.
Old 06-18-2008, 01:38 PM
toptechx6
toptechx6's Avatar
They are a son of a gun, no question about it. I'll assume you have the appropriate swivel sockets? They help a little if you don't.
Can't say I've ever found an easy way to get them but wonder if loosening the support beam bolts will let the trans drop enough to help, just an idea. Good luck.
Old 06-18-2008, 07:11 PM
88needspaint
88needspaint's Avatar
Heat them up...
Old 06-18-2008, 09:28 PM
biggrizzly
biggrizzly's Avatar
Originally Posted by 88needspaint
Heat them up...
Heat aint gonna help if you can't get a wrench on them after thier hot!
Besides that, with all the stuff in place, and as tight as it is, heat is not a real option without causing a fire where I don't want to.
The car is not on a lift, its on four jack stands only about 18" at the most clearance. Its just a bitch. I'm looking for a silver bullet.
Old 06-18-2008, 09:57 PM
pianoguy
pianoguy's Avatar
I took the long converter bolts out of the bracket by jamming 2 nuts on them - that gave me a little more room to get up there and get that top bolt out. I used a long box-end wrench and tried to think happy thoughts while I gave it zillions of small turns. Once the bracket was out, I was able to use a ratcheting box-end wrench to reinstall the bolt.
Old 06-18-2008, 10:01 PM
biggrizzly
biggrizzly's Avatar
Thanks, this is the kind of suggestion that I was hoping for. I'm gonna try doing some work on it this weekend and I'll give that a shot.
Old 06-18-2008, 10:12 PM
PLRX
PLRX's Avatar
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
Pianoguy's advice will work. I hyper-extended my forearm muscle with that SOB. If you lay face down, you may find it easier to manipulate with tact only. They do come out.
YOU NEED THIS
Old 06-18-2008, 10:20 PM
biggrizzly
biggrizzly's Avatar
Yep, that's the culprit. I wonder how loose I need it to get it to move the convertor around a bit.
I was told that I had to loosen the entire exhaust from front to rear and then tighten the convertor to the shortie header flange first. Then tighten the rest of the bolts from the front back. I just wonder how much play I will get by loosening these bolts?
Old 06-18-2008, 11:01 PM
pianoguy
pianoguy's Avatar
I had taken my exhaust and the cats off to put in long tubes, but I have to believe that if you can just loosen up those cat bolts, you'll get enough wiggle room without having to mess with the bracket.
Old 06-18-2008, 11:19 PM
PLRX
PLRX's Avatar
2017 C4 of Year
Man, I'm at work tired and I just realized your pain. I had the same issue with the headers. I got bad news for you. Loosing the cat will not straight/fix your problem. One of the headers, like yours, was "not perfect" and that shifted the entire exhaust system. The resonator was touching the seat belt bolt creating massive resonance (it was kinda awsome). I tried all, I removed both converters and the entire exhaust system and I ended up driving it to the muffler shop. There he heated up and using the "come along" he moved the system 1/4" to the right.
Old 06-18-2008, 11:23 PM
PLRX
PLRX's Avatar
2017 C4 of Year
Piano Guy, did you loose gas efficiency by installing longtubes?
Old 06-19-2008, 09:47 AM
biggrizzly
biggrizzly's Avatar
Well, luckily I don't think I have a bent header, but I do need to move the exhaust system up about a 1/4" to a half inch., at least the convertor so it will mate with the flange on the header.
You photos look just like mine!! How about that? So, you took the whole thing to a muffler shop? I have thought about that, but mine is not ready to fire up yet and I don't think it would be good to run it with the short tube header open, and no O2 sensors or CATS installed.
I could have it towed over on a flatbead though.
Old 06-19-2008, 09:59 AM
pianoguy
pianoguy's Avatar
No, mileage seems about the same (18-19 average). I was hoping for an improvement, but my right foot probably has more to do with that than anything - LOL! I have a couple of long trips coming up in July, so I'll see how good I can do under those conditions.
Old 06-19-2008, 10:31 AM
BlackC6LS3
BlackC6LS3's Avatar
I used a wrench, a block of wood and a jack.
Old 06-19-2008, 11:03 AM
biggrizzly
biggrizzly's Avatar
Can you elaborate? I have swivels, ratcheting wrenches, open and closed, lots of blocks of wood, but I'm not using them in conjunction that makes it unlock the puzzle. I'm usually pretty good at these things too.
I'm gonna give it my best on Saturday morning and see what happens.
The block of wood?
Old 06-19-2008, 11:27 AM
Demonic85
Demonic85's Avatar
Use a hammer and some WD-40
To Tips for loosening Catalytic Convertor brackets on LT-1
Quick Reply: Tips for loosening Catalytic Convertor brackets on LT-1
