Timken vs. AC Delco
Old 06-14-2008, 08:10 AM
jakers
jakers's Avatar
St. Jude Donor '06
Originally Posted by TimV SR
After researching bearings on this forum, I went with HP tapered rear bearings from Wheel Bearings Inc. I replaced both with around 7,000 miles on them after one failed. The HP ones cost a lot more, but should hold up better than my last ones.
My front bearings were tight when I got the car and still seem OK.
113,000 miles. Not sure if they are original or not.
I have researched the WBI bearings. It appears that only the rear hubs are available. Do you know otherwise?
Old 06-14-2008, 08:27 AM
TimV SR
Support Corvetteforum!
TimV SR's Avatar
Sorry, no.
But I would recommend them for the rears. It seems like the standard ball bearing types can't take abuse.
Mine see some abuse.
Quick Reply: Timken vs. AC Delco
