Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-09-2008, 06:23 PM   #61
Zix
CF Senior Member
Zix's Avatar
I'm running 42lb SVO injectors as well. No problems at all...as stated before it's all in the tune. These injectors where recommended to me by the original tuner of the engine.
Zix is online now   Reply With Quote
Old 06-09-2008, 07:33 PM   #62
JimiHendrix
CF Senior Member
Me likes
Quote:
Originally Posted by MTVette View Post
My experience covers much more than just increasing the displacement. In addition to the work on the rotating assembly (0.030" overbore on the cylinders and a 3.75" crankshaft), major work was done on the intake to increase airflow. The LT1 cylinder heads were ported, so that the intake flow increased from the stock 210 CFM to 272 CFM (cu. ft. per minute) at max valve lift. The stock intake was also ported, and the 48mm throttle body was replaced by a 58mm body. To keep up with the increased airflow, the standard 22#/hr injectors were replaced with 30#/hr. The exhaust work had already been done - long tube headers, high-flow cats, and an X-pipe.
All engine builds have to be done as part of a plan. Increase just one component and the results will be disappointing, because some other part of the engine now becomes limiting. For instance, when I installed the HotCam without any changes to the intake or exhaust, my best time on the quarter increased my a measly 0.05 seconds! Then, when I changed out the exhaust, I got a full three tenths off the quarter, and the intake became the limiting factor.
Finally, to answer how the change feels, it is now scary fast. Estimated 0-60 time is about 3.4 seconds, and the 0 to 100 time is about 8.5 seconds. When I hit the gas while cruising at 30 MPH with traction control off,, the back end skitters back and forth as the car leaps forward with a screaming roar. In the quarter mile, I took almost a full second off my previous best, and increased my trap speed by 10 mph.
JimiHendrix is offline   Reply With Quote
Old 06-09-2008, 07:36 PM   #63
95wht6spd
CF Senior Member
95wht6spd's Avatar
I have a very similar build as LT4POWR, but LT1 heads, and used his build as a guide.
I also use 42's on a 350, so you will be fine if you get a good tune.
95wht6spd is offline   Reply With Quote
Old 06-10-2008, 08:22 AM   #64
Bluewasp
CF Senior Member
NoVa Events Coordinator
Bluewasp's Avatar
Send a message via AIM to Bluewasp Send a message via Yahoo to Bluewasp
Quote:
Originally Posted by BlackHarleyMan View Post
I appreciate you confirming that one. I thought you told me that it was a Internally balanced motor with a neutrally balanced Dual Mass.
Oh-Kay!...........Another 383 with 30's.........What's your CHP/RWHP on your Motor Rob?
Noland
442rwhp...
Bluewasp is offline   Reply With Quote
Old 06-10-2008, 03:03 PM   #65
BlackHarleyMan
CF Senior Member
BlackHarleyMan's Avatar
Send a message via AIM to BlackHarleyMan Send a message via MSN to BlackHarleyMan Send a message via Yahoo to BlackHarleyMan
Todd it made sense to go with a proven setup, so I'm glad to know that I wasn't the only one thinking down that path! Very nice numbers on your LT1, very nice indeed.
Quote:
Originally Posted by Bluewasp View Post
442rwhp...
Thanks Rob!........I knew it was over 500CHP, but wasn't sure what your Rear Wheel was.
Noland
BlackHarleyMan is offline   Reply With Quote
Old 06-10-2008, 03:05 PM   #66
Bluewasp
CF Senior Member
Bluewasp's Avatar
How well do the AFR heads flow? Do you have any information on the heads you purchased?
Old 06-10-2008, 03:05 PM   #67
Bluewasp
CF Senior Member
Bluewasp's Avatar
Also, Why did you buy the AFR heads vs one of the other LTx heads on the market now..
Old 06-10-2008, 03:25 PM   #68
BlackHarleyMan
CF Senior Member
They are listed at 300 at .600, and I have general info that came with the heads, but no specific flow sheet for these heads. I did talk to Tony over at AFR after speaking with AI and LE, so that had almost everything to do with my decision.
Maybe this will help:
SBC 195cc-LT Comp Pkg.L98 MILL 60 CC'S Part# X1039F
8019 Hyd Roller Valve Spring
8mm 2.080 Std Race Int Valve
8mm 1.600 Street Exh Valve
SBC Eliminator 7 Deg.Ti Ret
Upgrd 3/8 Studs to 7/16
8mm Valve Locks- 7 Degree
LT1 Hds-Angl Mill Hds and
Because after speaking to LPE, AI, and LE everyone wanted $1500 to over $2000 to take my LT4 heads and port-polish and then send my heads back, with or without a cam. For less than $1000 more, I bought a set of superior heads outright which outflow anyone's port and polish job that can be done with the stock LT4 castings. I also looked at other off the shelf heads, but for the LT4, AFR's rep was far far better (In MY research of heads), than anyone else. When I have a guy willing to sell me a set of LT4 P&P heads, because he's running AFR's on his LT4, AND the guy building my motor is telling me that he's running AFR heads but I can go with whomever I want for the P&P. Eventually you have to question what is being said to you. There's a reason that AFR's are replacing stock head castings all over the place. But when I made a change to the AFR's, because of the superior combustion chamber my rods and pistons had to be changed. SO, IMHO, it was about getting the most bang for the buck, maximizing efficiency of the motor and only having to do it once.
Noland
Old 06-10-2008, 11:58 PM   #69
Mojave
CF Senior Member
Mojave's Avatar
You guys with the 383's and 30/42 lb injectors: what fuel pumps are you running? Stock? Walbro 190? 255?
Mojave is offline   Reply With Quote
Old 06-11-2008, 12:03 AM   #70
MTVette
CF Senior Member
MTVette's Avatar
Quote:
I know we replaced the fuel pump, but I'm not sure with what. Stock would be my guess.
MTVette is offline   Reply With Quote
Old 06-11-2008, 12:07 AM   #71
Zix
CF Senior Member
Zix's Avatar
Walbro 255, but it actually wasn't really needed. I wanted to replace the pump and happened to get one at a good price. I watched the FP with the stock pump and it held fine all through the RPM range.
Old 06-11-2008, 08:00 AM   #72
Bluewasp
CF Senior Member
Bluewasp's Avatar
stock with no pressure issues...
Old 06-11-2008, 08:22 AM   #73
BlackHarleyMan
CF Senior Member
I'm installing the Racetronix 255gph
Old 06-11-2008, 08:29 AM   #74
96lt4c4
CF Senior Member
96lt4c4's Avatar
+1 for the ford 30 lb injectors. I am running the stock pump. I have been told that the ford 30lb injectors flow about 32lb on the Vette due too a little higher fuel pressure than the Mustang.
__________________
1999 Hugger Orange SS (HOSS) 1 of 374 SS, 6 speed, T-Tops, Charcoal Leather.
96lt4c4 is offline   Reply With Quote
Old 06-11-2008, 08:35 AM   #75
96lt4c4
CF Senior Member
96lt4c4's Avatar
Noland
This may be a stupid question, but why did you have to change pistons and rods when you decided to go with the AFR heads? Compression ratio?
Your car is going to be nasty dude........
Old 06-11-2008, 09:58 AM   #76
rklessdriver
CF Senior Member
rklessdriver's Avatar
Yes mainly for the Compression ratio. AFR didn't want to cut the heads downto 55cc. If we used the pistons I orginally speced for the stock heads (Wiesco 20cc dish) it wouldn't have had enough compression.
Moving from the 5.7" rod to a 6" rod was 2 fold. Mainly because, honestly the only really nice pistons (with the correct dish) I could get him a deal on at the time were the Manleys and they were for a 6" rod... but since the AFR heads have a very eficient combustion chamber, I knew I get away from the shorter 5.7" rod (orginally speced because the faster piston speed on and of TDC reduced the chance for detonation) and take advantage of the less side loading of the longer 6" rod, without having to worry about detonation.
I also knew I would need to change the cam lobes to take full advantage of the new AFR heads and I could juggle the Intake Valve Closing point around a few degrees to help compliment the long rod and its slower piston speed/longer dwell time at TDC.
Will
rklessdriver is offline   Reply With Quote
Old 06-11-2008, 11:32 AM   #77
LT4POWR
CF Senior Member
LT4POWR's Avatar
OK, JUST to let YOU know..........Alot of the research on this build came from your combo!...........You send me the specs on your engine awhile back and I've used it as a template for this setup! SO, Thanks to you, here I sit BROKE AS A JOKE!.......Thanks!
Noland
P.S. I would love to see your dyno sheet if you have one for your motor. When I saw your combo, I knew that if a stock bottom LT4 could make that type of power and be driven daily, then a stroker would kick Azz!
N
Thanks guys, and no problem
I'm actually thinking about doing a 383 this fall/winter, so this thread has me really interested.
I've got my dyno sheet scanned, but it's pdf and photobucket is giving me problems uploading it...if someone PMs me their email, I'll email it to them and they can host/post it.
I'm still running the stock fuel pump.
__________________
1996 LT4 Corvette
416rwhp/375rwtq (SAE) - NA Stock Bottom End
2004 Cadillac CTS-V
Stock (for now) LS6
LT4POWR is offline   Reply With Quote
Old 06-11-2008, 11:52 AM   #78
Mojave
CF Senior Member
Mojave's Avatar
Sounds like a lot of people are running the stock pump, which is awesome, but I didn't want to have to change it.
Anyone out there running non-stock style (either poly or solid) motor mounts? All I can find are the oil filled ones.
Old 06-11-2008, 04:27 PM   #79
BlackHarleyMan
CF Senior Member
I thought I saw a part number for Energy Suspension's Poly Motor mounts that would work, but I've decided to just stick with the stock units.
Old 06-11-2008, 06:07 PM   #80
Mojave
CF Senior Member
Mojave's Avatar
Really? I searched all over their site and I couldn't find anything for a 92-96.
Here is a link to their catalog for Chevy engine mounts: http://www.energysuspension.com/pages/mt_tr3.html
Reload this Page LT-4 383 Rebuild "LOTS of Pictures"
Tags
2080, 383, 917269, ati, champ, cp100ltrb, eliminator, jr, lt4, noland, pictures, rebuild, rr, sbc, smith, va, winchester
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
