New Radio with existing Bose speakers.
I am going to by a new radio with CD and iPOD front adapter. Crutchfield said all I need to do to use my existing Bose Speakers is to use the Scosche OEM Amplifier Adapter. Item #142C4GM01 Anyone ever go this route and how did it go?
I used an adapter like that for the same issue and it worked fine.
You may want to get the adapter for the radio to use with normal speakers as well in case you scrap the Bose system and use better/newer components.
Yeah, the more I think about it, I think I will go ahead and just get an entire new system. Not impressed with the sound at higher levels with the current setup. Makes more sense to do it once and do it right.
Run a search on the entire c4 section for something like "sub". There have been some awesome threads on subs in different parts of the car. Checking the audio section may also be of worth. I always wanted a nice system in the 'vette but removed everything as extra weight and decided to build up a system in the shop. Since I work on the car all the time.
You wouldn't put an lt1 in a chevette, why put a new head unit in with the old bose. If you're going to do it, do it right and all the way.........My Sony head unit and Infinity speakers make my bose sound like a transistor radio.
Hello,
I didn't use the adapter but did work thru it to use the Bose system.
I have since upgraded speakers and components.
You'll be happier to upgrade ALL at once.
Take Care, Be Safe and Good Luck, -John
i would update everything. be ready for a whole lotta fun. im in the middle of changing the whole stereo and speakers out. make sure you have all the right adapters before you start. the bose system isnt anything like any other gm. ive been sent the wrong wire harness adapter twice. even after i specified that i have a 91 vette with the bose system. i finally decided to wire everything up myself. it sounds so much better than the stock system. i need to run my antenna wires, gps and ipod wiring now, then mount the radio. its worth doing everything.
Added a new Pioneer Double Din unit. Love the radio with the USB and Sirius but now the sound sucks. They put on a Bose bypass and are powering the speakers with the deck. Now it sounds flat. The speakers bottom out and I lost all the highs. I guess I need new speakers. The Bose sounded grrrreat before the new deck now the sound sucks. Any ideas would be deeply appreciated.
Mike
Mike
Mike
Mike
If they actually bypassed the Bose amps, than that is the problem. Do away with the speakers and move on.
Bypass
Yeah,
Originally they charged me for a Bose adapter but then they noticed a whine noise so they shut down the bose amps and went with just the head unit powering the 4 speakers. I see what you mean about the ohm thing. Im not a big audiphile but I can hear the difference. I was totally happy with the 1996 Bose Sound but I guess that is gone for good. Hell the new satellite radio module they installed sounds like mono sound. This is a premier radio place but geeez they aren't used to working with Bose I guess. So some good speakers with this radio should get me the quality of Bose sound?
The adapted would have given you better sound then what they did. If you replace the Bose w/ some good speakers, I am sure the sound quality will be even better then before. Check out the C4 FAQ in the Audio section, good info there on replacing the Bose systems in our cars.
Good luck, Randy
Good luck, Randy
That's the best way to go. The blose system is pretty crappy and the adaptors make them sound even worse. An aftermarket system will sound 10x better. Plus, you can sell the blose crap on ebay and offest the cost considerably.
