Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-04-2008, 01:23 AM   #1
GS4-LT1
CF Senior Member
GS4-LT1's Avatar
Default Alto reds or Raybestos Z-Pack
Buying parts for my tranny rebuild and need advice on what brand of 3-4 clutches to buy. Alto reds or the Raybestos Z-pack. Pros and cons.
Thanks!
(Wish we had a transmission section on the CF!)
GS4-LT1 is offline   Reply With Quote
Old 05-04-2008, 08:03 AM   #2
Pete K
CF Senior Member
Pete K's Avatar
If 500 hp or less, either will be fine.
Pete K is offline   Reply With Quote
Old 05-04-2008, 11:44 AM   #3
ZD1
CF Senior Member
ZD1's Avatar
I used the reds in mine, although for other reasons it never quite ran right which forced a transition to the ZF6
Be carefull in your tool selection for removing those pesky snap rings..they're a pita with extra hot sauce.
__________________
91' Quasar Blue
-427 Stroker-eagle /6" Eagle H-beam rods/ross-pistons
-coated pistons and rod bearings
-fully ported AFR 227cc heads/miniram/242-246 cam
-ZF-6 conversion/ MC pull twin
-AFS C6 polished 9.5"x18" and 10.5x18 wheels
Somewhere in the Out-west
- C6 Z51 brakes is in work along with nitrous/alcohol injection
ZD1 is offline   Reply With Quote
Old 05-04-2008, 12:21 PM   #4
JimiHendrix
CF Senior Member
Default Im a fan of Z Packs
Im running the Z pack in my rebuild. Very happy with it. It seems to grab solidly with WOT shifts. I dont know if that is normal for all nwe clutch packs. I guess I will find out.
Hey Pete K. . . . Z pack is only good for 500hp or less? What would one use for a higher horsepower engine. Im figuring that if you have 500hp+ and you ride it hard, no clutch pack is going to last 100k.
JimiHendrix is offline   Reply With Quote
Old 05-04-2008, 12:25 PM   #5
Pete K
CF Senior Member
Pete K's Avatar
I just meant that 500hp or less would not hurt either. Sorry for the confusion.
Old 05-05-2008, 12:11 PM   #6
GS4-LT1
CF Senior Member
GS4-LT1's Avatar
Thanks guys! Anyone else with info?
Old 05-05-2008, 05:05 PM   #7
JimiHendrix
CF Senior Member
Quote:
Since either clutch pack is good, what other components could you install. . . or mods you can make....to make the 3/4 pack last longer.
I left the 6 assist springs out of the input drum per raybestos' instructions.
I really didn't see anything else you could do to make the 3/4 pack work even better.
Pete K? any suggestions......I heard ur da man.
Old 05-05-2008, 09:57 PM   #8
GS4-LT1
CF Senior Member
GS4-LT1's Avatar
Pete K told me the 3 weakest parts of the 4L60E are the Reaction Shell, the Pump washers, and the 3-4 clutches. I am going to buy a Beast shell, looks like TransGo has a set of hardened Pump washers, but I was just confused on the clutches as Raybestos touts their "One sided clutches with less coning"
When I drag race I put it in D rather than OD and go throught the traps around 3500-4000 rpms, so maybe the 3-4 clutch selection is not that big of a deal....I am not that wise when it comes to transmissions. Pete Kane is Da Man!
Reload this Page Alto reds or Raybestos Z-Pack
Tags
alto, clutch, clutches, corvette, eagle, forum, instructions, lt1, pack, packs, raybestos, red, set, zpack, zpak
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
