Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-13-2008, 12:08 AM   #1
mechanic58
Junior Member
Default '93 LT1 PCM Pinout diagram
I did search, couldn't find anything (here). I'm hoping someone here has this. Thanks in advance guys.
mechanic58 is offline   Reply With Quote
Old 04-13-2008, 12:38 AM   #2
rodj
CF Senior Member
rodj's Avatar
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
rodj is offline   Reply With Quote
Old 04-13-2008, 01:07 AM   #3
Redeasysport
CF Senior Member
St. Jude Donor '05-'06
Redeasysport's Avatar
Send a message via AIM to Redeasysport
The 93 does not have a PCM. What exactly are you looking for? ECM wiring diagram is in the FSM I believe.
Redeasysport is offline   Reply With Quote
Old 04-13-2008, 11:04 AM   #4
mechanic58
Junior Member
Thanks, I did find that one on the autozone site earlier. According to THAT drawing, it IS a PCM.
Also, I know those drawings are in the FSM, however I do not HAVE an FSM or else I wouldn'ta been on here askin this question. lol. Sheesh.
Thanks guys.
Old 04-13-2008, 02:29 PM   #5
Redeasysport
CF Senior Member
Do you believe what Autozone tells you or someone has owned 2 '93s? PCM did not start till '94. You need the FSM for your car it will answer all your electrical questions. I have never heard anyone asking for a pin out of all the wires so I doubt you going to find a post on it. I did ask why you needed it though.....
Old 04-13-2008, 09:43 PM   #6
mechanic58
Junior Member
I have a complete LT1, harness and computer from a wrecked '93 Vette that I recently aquired. I have transformed the harness into a "essentials only" stand alone harness. I'm going to put this engine in a 1971 Pontiac Ventura with a muncie 4-speed behind it. Since I made my original post, I was able to locate the proper schematic and I have typed up my own 'pinout' description. Here it is below, now it'll be here for anyone else who might need this information.
Quote:
PINOUT for GM PCM/ECM 16159278 (wire color abr. follows descriptions)
Wire Color Legend
B = Black
BL = Blue
BR = Brown
DKBL = Dark Blue
DKG = Dark Green
GY = Gray
LBL = Light Blue
LG = Light Green
O = Orange
P = Purple
PK = Pink
R = Red
T = Tan
W = White
Y = Yellow
Connector [A] is Gray
[A1] Vapor Canister Purge Solenoid DKG/Y (HOT in start and run) 10A
[A2] EGR Solenoid B/PK (HOT in start and run) 10A
[A4] IAC LBL/W
[A5] IAC LG/B
[A6] Check Engine Light BR/W (this grounds when light is on, connect other terminal on light socket to HOT in start and run) 5A
[A7] Air Pump Relay BR
[A8] Air Divert Valve BR (this grounds when active, connect other terminal on valve to HOT in start and run) 10A
[A9] Shift Light W
[A10] IAC LBL/B
[A11] IAC LG/W
[A12] Ignition Coil W (HOT, connect other black wire on coil to ground) 10A
[A13] Coolant Temp Sensor Y
[A20] Fuel Pump ON input R
[A21] Trans Position Switch O/B
[A22] Anti-lock Brake Module GY/B
Connector [B] is Red
[B2] Trans Converter Clutch (Auto) or Overdrive Relay (Manual) T/B (Auto) or DKBL (Manual) (also connects to Pin F on ALDL Connector)
[B3] MAP Sensor B
[B4] Primary Cooling Fan Relay DKG/W
[B5] A/C System DKG/W
[B6] Grounded T (also connects to Pin A on ALDL connector)
[B10] Secondary Cooling Fan Relay DKBL/W
[B14] 2nd, 3rd and 4th gear switches (auto), 4th gear LBL
[B16] Cruise Control System P
[B17] Grounded B/W (jumped to [B6] )
[B18] TPS B
[B19] 2nd, 3rd and 4th gear switches (auto), 3rd gear DKG
[B20] 2nd, 3rd and 4th gear switches (auto), 2nd gear W
[B21] A/C system DKG/Y
[B22] Grounded B/W
Connector [C] is Green
[C1] A/C system DKG
[C2] TPS GY
[C3] PS DKBL
[C5] Distributor/Opti-Spark Module B/R
[C6] HOT at ALL times (jumped to C17) O
[C7] MAP Sensor GY
[C8] Knock Sensor(s) DKBL
[C9] Distributor/Opti-Spark Module B/PK
[C11] A/C Pressure Sensor GY/R
[C12] ECM Power (HOT in start and run) PK/B 3A
[C14] Distributor/Opti-Spark Module P/W
[C15] Oil Temp Sensor DKG
[C17] HOT at ALL times (jumped to C6) O
[C18] Distributor/Opti-Spark Module Y
[C21] MAP Sensor LG
[C22] Manifold Air Temp Sensor T
Connector [D] is Brown
[D1] VSS P
[D4] ALDL and Serial Data Connector T (connects to Pin M on ALDL connector)
[D6] O2 Sensor (left) P
[D7] Fuel Pump Relay DKG/W
[D8] VSS Output DKG/W
[D10] Fuel Injectors 2, 4, 6 & 8 DKG (connect other lead off injectors PK/B to HOT in start and run 10A)
[D11] Fuel Injectors 1, 3, 5 & 7 DKBL (connect other lead off injectors PK/B to HOT in start and run 10A)
[D12] VSS Y
[D15] ALDL and Serial Data Connector T
[D20] ALDL and Serial Data Connector W/B (connects to Pin B on ALDL connector)
[D22] O2 Sensor (right) P
Old 04-13-2008, 09:54 PM   #7
Redeasysport
CF Senior Member
Well good luck with your project.
Old 04-14-2008, 01:01 AM   #8
Eddie & the Cruisers
CF Senior Member
Eddie & the Cruisers's Avatar
Send a message via Yahoo to Eddie & the Cruisers
ECM/PCM -they are just computers that control the electronic sensors. Some are reprogrammable on the car and some require being erased before reburning a new set of commands to them. Even C.A.T.S. Tuner software refers to them as ECM's.
On the newer ones, just call em a PECM. Lighten up!
Eddie & the Cruisers is offline   Reply With Quote
Old 04-14-2008, 12:26 PM   #9
mechanic58
Junior Member
lol...PCM, ECM....its really a moot point for me. Semantics. The schematic that I had for this particular computer had it identified as the "Powertrain Control Module", hence the language I used to describe it. I really don't care WHAT it is called....lol.
Thanks again for all the help guys, I appreciate it. The guy with the Autozone link is what helped me the most. I still can't believe they had that schematic...lol. (and for the record, I have verified that it was in fact correct. The wire count, color code and pin locations were all correct for ECM 16159278)
Old 03-11-2012, 01:01 AM   #10
EagleMark
Junior Member
Little late but all the EFI wiring diagrams for that year are here:
http://www.gearhead-efi.com/Fuel-Inj...mation-DA2-DA3
EagleMark is offline   Reply With Quote
Old 03-11-2012, 03:44 AM   #11
mechanic58
Junior Member
Just a TAD late...for sure.
Reload this Page '93 LT1 PCM Pinout diagram
Tags
16159278, 93, c4, computer, corvette, diagram, diagrams, location, lock, lt1, optispark, pcm, pinout, vapor, wiring
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
