First broken parts of the year
Old 04-10-2008, 04:19 PM
black_89_vette
black_89_vette's Avatar
Default First broken parts of the year
1989 fully forged 383, AFR 195 Elim, 230/230 0.598", ZF6, McLeod Street Twin.
I broke (at least) the rear spindle in my car. The mechanic said it was at least that and wasn't sure if it could also possibly be the rear hub and inner bearings.
He says (before he takes it apart) it appears to broken like this.
What are the odds that it's just the spindle and not the bearings. This happened during a "fun launch" in front of a friend and didn't see any rpms after breakage cuz I got right out of it.
Old 04-10-2008, 04:31 PM
88BlackZ-51
88BlackZ-51's Avatar
Not a good start to the year.
What rpm did you launch at? I am suprised you broke something on the street with street tires.
Old 04-10-2008, 04:34 PM
black_89_vette
I was bringing up the revs, and not too high either. It wasn't a high rpm thing. I'm guessing somwhere around 2500-3000 probably. Didn't leave any black marks either cuz as soon as I was letting out the clutch, I hear some unhappy noises, so the clutch immediately went right back to the floorboards.
Old 04-10-2008, 04:35 PM
Iroc57
Iroc57's Avatar
I guess the motor is just about right
Here's to a hopefully easy fix
Old 04-10-2008, 04:37 PM
88BlackZ-51
Welcome to the Mcleod days.
Old 04-10-2008, 04:41 PM
fredk
fredk's Avatar
You better look at Tom's Differentials he sells tough spindles, you don't have to ask me how I know. If your lucky you didn't screw the bearing and the wheel speed sensor. I wasn't lucky.
Fred
Old 04-10-2008, 07:04 PM
RichS
RichS's Avatar
Prolly lookes like this.
Old 04-10-2008, 07:11 PM
DDSLT5
DDSLT5's Avatar
bad luck! I'm running stock spindles - no problems yet - but I don't want to jinx myself! lol
Old 04-10-2008, 07:13 PM
88BlackZ-51
What clutch set-up?
Old 04-10-2008, 07:14 PM
DDSLT5
DDSLT5's Avatar
Originally Posted by 88BlackZ-51
What clutch set-up?
Bone stock clutch with the dual mass flywheel.
Old 04-23-2008, 04:42 PM
black_89_vette
Rich S, it looks exactly like that.
I just got back from the mechanics and saw the carnage. Well, new part in (stock replacement for now just to see if it'll do it again) and mechanic said "let me take it for a test drive and I'll call ya back".
Just got the call from the mechanic and said it also took out the ABS sensor and it was the spindle replaced along with the rear hub (I think that's what it was..).
Also he said he just got on the gas a bit and it twisted the passenger side half shaft. A few years back, I twisted the driver's side. So, now it looks like I'll be seriously thinking about firing up some Denny's Nitrous Ready half shafts.
Any input on Dennys parts and or other sturdy half shafts?
Old 04-23-2008, 07:03 PM
88BlackZ-51
Badluck Jerry!
I might be in your same vote with the brutal tq that the 421 will be making.
Changing that clutch?
Old 04-23-2008, 07:14 PM
fredk
fredk's Avatar
Get your ABS sensor from Corvette Central it is $106.00, at a GM dealers is is $190.00. There is a company in Toronto that makes halfshafts. Make a post on the Canadian section as I can't remember their name. The shortened a driveshaft for me.
Fred
Old 04-23-2008, 07:22 PM
Randy93
Randy93's Avatar
St. Jude Donor '06
Little super glue will fix that!!
Old 04-24-2008, 11:30 PM
88BlackZ-51
You installed that clutch, and now things are breaking.
Hmm!! I wonder what it is?
Old 04-24-2008, 11:37 PM
mseven
mseven's Avatar
Originally Posted by fredk
You better look at Tom's Differentials he sells tough spindles, Fred
yep, and so does EM, along w/solid spicers
http://www.tomsdifferentials.com/catalog.asp?pg=32
To First broken parts of the year
Quick Reply: First broken parts of the year
